Matrix (2004) alarm issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2007, 08:17 PM   #1 (permalink)
DB
Guest
Posts: n/a
View DB's Photo Gallery
This has been happening off and on for the past six months, and it's seem to have gotten worse. Sometimes when I press the button to arm the car it locks the doors, but doesn't beep and arm the alarm. Also sometimes when I have my car armed, and I press the unlock button it unlocks the door, but doesn't give the *beep-beep* and disarm the alarm. So when I open the door the alarm goes off, and I have to try opening and closing the doors, sticking the key in the ignition, repeatedly pressing the unlock button and eventually it disarms. I took it to the dealer, and they reseated a cable, but that didn't correct the issue, and of course it worked perfectly for them. Any suggestions.
DB
Old 02-19-2007, 10:08 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Matrix (2004) alarm issue
"DB" <none@none.com> wrote in message
news:45da4bf5$0$28142$4c368faf@roadrunner.com...
DB
The next time the door unlocks but the alarm does not disarm, try inserting
the key in the door and unlocking it manually before opening the door. If
this does not work, try inserting the key in the passenger door (if it has a
passenger side key opening) and see if it works.
I suspect that the door unlock sensor for the security system is not
working.
If the alarm is activated, try inserting the key in the ignition, turning it
to the on position, then off, then back on.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
FS: 2004 Toyota Matrix XRS, New Brunswick thebarber Vehicles 0 04-20-2007 10:42 AM
Tsb Bulletin El Tano 5th & 6th Generation (2002-2006 & 2007-2011) 20 11-29-2006 01:47 PM
Remote starter for 2004 Matrix myhippocket 1st Generation (2003-2008) 4 01-11-2005 04:38 PM
04 Corolla S - Factory Alarm bradp50 Audio, Video, and Security - Tech 6 08-15-2004 11:09 PM
Factory Alarm on 2002 Honda CR-V sucks! AzimuthX General Discussion 3 08-10-2002 09:40 AM
