Re: high idle
badgolferman wrote:[color=blue]
> 2000 Sienna 105K miles
> Got a tuneup today and had both valve cover gaskets replaced. Engine
> idles much higher than it did before. When warmed up and in Neutral or
> Park it hovers around 1000 RPM or just a tad higher; I am used to it
> being nearer 800 RPM. I was getting lousy gas mileage before I took it
> in and fear it will be worse now, not to mention that it just feels
> wrong.
> Rather than taking it back to the dealer is there anything I can do to
> settle it down a bit? It's a pain to make arrangements for service and
> drop-offs, etc.[/color]
They could have missed the wiring hookup at the air snorkel. I don't
know if your Sienna has that system but look for the most obvious first.
They are easy to miss if the air snorkel is removed and usually you have
to unplug that connection. That would probably illuminate the check
engine light if they forgot or missed it. Just a thought, good luck.
