Re: 91 Camry LE, Need advice re: testing and changing injectors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2007, 02:26 PM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Al Kondo" <alkon@hal-pc.org> wrote in message
news:4ahut2hcas49f2qgnt5hnvg87mnis9t6do@4ax.com...[color=blue]
>I have a 91 Camry LE with 190k miles. I have had problems with fairly
> high hydrocarbon levels when taking my emissions testing in the past
> and I suspect that it is leaking injectors or perhaps poorly spraying
> injectors. Anyway, with 190k miles on the car, I figure the injectors
> probably need inspection or, even, replacement.
> I checked out how to remove and inspect the injectors in my shop
> manual and it looks like a pretty difficult procedure. Has anyone
> ever done this? How difficult was the procedure? Also, there are a
> number of parts shown in the manual that seem to be required for the
> testing procedure. Can these parts be obtained from the local parts
> house or hardware.... or, do I have to get them from Toyota.
> I would appreciate any advice about this.
> Thanks, Al[/color]
Besides hydrocarbons (HC), it would be helpful to have readings and limits
for all of the tested gases in your state, like carbon monoxide (CO) and
oxides of nitrogen (NOx). With the additional information, it is easier to
identify potential causes and things to check out.
Before you go through the trouble to remove the fuel injectors, you may want
to try either the Toyota brand stuff that Toyota dealers sell or Chevron
Techron fuel injector cleaner.
You can check on aftermarket part availability for your car at
[url]www.autozone.com[/url] .
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
