Re: Coolent Level Low?
"Hachiroku ????" <Trueno@AE86.gts> wrote in message
news:ddZDh.13651$sv6.12791@trndny08...[color=blue]
> On Sat, 24 Feb 2007 09:58:32 -0500, Robert R Kircher, Jr. wrote:
>[color=green]
>> Ok checked this morning in the daylight and the resivour was empty.
>> Filled it up and looked into the radiator and it also looks empty, at
>> least empty from what I'm used to even after running the car to operating
>> tempeture.
>> Questions.
>> Shouldn't I see coolent in the radiator? I'm used to warming the car up
>> until the theromstat opens and filling the radiator until you can see
>> coolent at the top. Is this still true with this truck?
>> BTW: after driving the truck the same levels were in the resivior and the
>> heat worked. Except the rear heat. It still blows cold air. Does the
>> rear heat use the engine coolent to work or does it have its own system?[/color]
> I don't know about rear heat, so I won't venture to guess. But, the
> Overflow bottle should be at the lavels marked on the bottle, and collant
> should cover the radiator core. I believe this vehicle uses the pink
> stuff, get it from Toyota. If all they have is the diluted stuff, add it
> to the radiator cold and then start the car and wait. Add more as needed
> to fill the radiator. put some in the bottle to cover the bottom of the
> hose and close the radiator, then watch the bottle. Add until it
> stabilizes and then fill to the HOT mark and close it.
> I would look for hoses running to the rear heater. I had a Ply Grand V'Ger
> with rear heat, and one of the hoses burst and lost all the coolant from
> the engine. Luckily, since I watch the temp guage all the time, I stopped
> the engine when it look abnormal and saved myself a lot of grief!
>[/color]
Ok just to make sure I understand. Not only do I need to fill the reservoir
bottle but I should also fill the radiator until I can see fluid at the top
over the radiator core when the system is cold.
As to the kind of coolant, I read the manual and it says Ethylene Glycol.
Yes the coolant in the car is the red stuff but the only think I can get
right now is Peak which is the same Ethylene Glycol but its green. Does
that really mater? I've already filled the reservoir with the Peak stuff.
I believe the rear heater is electric and on a fuse. I've found the fuse
but it seems to be some special block instead of a normal fuse. Figures.
Rob
"A disturbing new study finds that studies are disturbing"
