Re: Celica Clutch Burning Smell - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2007, 08:53 AM   #1 (permalink)
Stewart DIBBS
Guest
Posts: n/a
View Stewart DIBBS's Photo Gallery
<bdelaney820@hotmail.com> wrote in message
news:1172364197.867292.249270@j27g2000cwj.googlegroups.com...[color=blue]
>I just bought a 2000 Celica, ...Whenever you give the car
> more than the adequate amount of gas to get it moving, i experience
> the burning smell as well...I still have a 30 day warranty on the car[/color]
Yes, your clutch has to be replaced, AND the flywheel machined to get it
flat again. Do not let anyone tell you different. Carefully read the terms
of your 30 day warranty, to see what is actually covered. Its not impossible
that the clutch is excluded, along with a whole lot of other stuff. Used car
warranties are notorious for covering things that almost never happen (eg
catastrophic internal failure that causes something to make its way out of
the engine or trans), and excluding those that mostly do (eg timing belts,
and "normal" auto transmission failures).
Replacing the clutch is not a particularly difficult job. A decent rebuilt
parts kit is about $250, flywheel machining about $80, and 4-5 hours labour.
The engine does NOT have to come out of the car: just remove the axles and
drop the transmission.
SD
Old 02-27-2007, 04:15 PM   #2 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
Stewart DIBBS mumbled incoherently to the rest of alt.autos.toyota:
[color=blue]
> news:1172364197.867292.249270@j27g2000cwj.googlegroups.com...[color=green]
>[/color]
Depends how bad the OPs driving is - if the clutch doesnt slip in 5th with
the foot to the floor its likely just bad clutch/throttle control.
BB code is Off
Smilies are Off
[IMG] code is Off
4WD Hi burning smell... Nicky9 2nd Generation (2005+) 16 02-15-2007 08:58 AM
Burning smell from Heater Vent / Door Well. 98 Camry LE zagman 3rd & 4th Generation (1992–1996 & 1997–2001) 5 04-08-2006 01:32 PM
