My expertise in baking went up a notch or two last week when I finally
perfected a simple method that compensates for differences in measurement
and temperature of ingredients and different ovens before starting.
Inserting a toothpick generally works good but I wanted something better. I
didn't want to keep opening the oven door.
The long and short of it is I insert a temperature probe into (for example)
a cupcake mold. While it's rising the internal temperature will reach 212
degrees F. and remain there. The very moment it reads 213 I remove the
cupcake pan.
If you have a digital thermometer with a braided cable probe you ought to
try this method. The only thing you need to do is establish whether it will
accurately read 212 in boiling water. It also helps to know if it will read
32 degrees in ice water.
The cakes come out like Hostess Suzie Q's but if you want more of a crust
just let it stay in the oven about a minute more.
I guarantee you, people in your home will be fighting over them.
Most meters, digital and analog are not linear, center scale is usually
the most accurate. We have a dial thermometer which works well for the
turkey. I know for sure the oven dial is not accurate. When set to 400
deg. it's usually way too hot inside the oven, much higher than the dial
thermometer reads.
My chili was super hot, almost poisonous....I added extra Cayenne
pepper, nobody ate from my batch, heh heh.
So it is not really necessary to have an accurate thermometer. The
critical thing to look for is when the temp rise stops and then resumes,
at whatever the temperature the thermometer is reading. In other words,
the calibration of the thermometer does not matter all that much, just how
the reading moves.
Tomes
Today's batch didn't fair as well as the first batch of cupcakes. It called
for an oven temperature of 325 instead of 350, and I'm using a brand new
Chicago Metallics commercial grade 12 cupper. So, I guess it's back to the
drawing board.
The vanilla cup cakes are delicious and if you didn't know better you'd
swear I had pumped a creamy filling into them. Still edible but have to keep
them refrigerated.
mark_
