Re: 95 corolla stumbles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2007, 11:35 AM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Stef Caunter" <stef@caunter.ca> wrote in message
news:Pine.BSF.4.64.0702270931110.8676@tj.pnhagre.pn...[color=blue]
> New to me 4a-fe, 95 corolla manual, stumbled a bit under load in pretty
> wet slushy conditions yesterday, otherwise fine.
> The usual suspects would be plug wires, cap and rotor. I don't have a
> Haynes yet, and my experience is limited to carbureted Volvo motors; does
> this motor have a serviceable cap and rotor?
> The fact this was under load might point to vacuum I suppose. Is there a
> usual diagnosis for this? I just don't know all the fixes yet.
> I've read up on these motors, and apparently they use oil (PO said it was
> consuming oil). None is being obviously burned so I suppose it is getting
> by the rings.
> -Stefan
> (95 Corolla 4a-fe 5 speed, power nothing)[/color]
I am pretty sure that the 4A-FE motor has a serviceable cap and rotor. Some
aftermarket ignition parts can cause the symptoms you are describing, and
rather than experiment with which ones work and do not work, your best bet
is to stick to OEM (Denso) cap, rotor, and wires and Denso or NGK plugs.
A vacuum leak would probably cause the same symptoms regardless of road
conditions, and since the problem appears to be related to wet conditions,
I'd start by looking at ignition parts.
Ray O
Old 02-27-2007, 11:51 AM   #2 (permalink)
Truckdude
Guest
Posts: n/a
View Truckdude's Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:5054c$45e46c0e$44a4a10d$26091@msgid.meganewsservers.com...[color=blue]
> news:Pine.BSF.4.64.0702270931110.8676@tj.pnhagre.pn...[color=green]
>> by the rings.
>> -Stefan
> Some aftermarket ignition parts can cause the symptoms you are describing,
> and rather than experiment with which ones work and do not work, your best
> bet is to stick to OEM (Denso) cap, rotor, and wires and Denso or NGK
> plugs.
> Ray O
>[/color]
Yes, it does.
FWIW, I have always used aftermarket ignition parts on my 4A-FE with no
problem at all.
BB code is Off
Smilies are Off
[IMG] code is Off
95' Corolla, questions regarding gas mileage Blek Archived Corolla threads 8 03-18-2011 07:15 PM
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 05:19 PM
95 Corolla Idling Young James Archived Corolla threads 2 04-12-2007 11:33 PM
New Member - 95 Corolla Young James Archived Corolla threads 6 03-14-2007 08:39 AM
95 Corolla Short Ram Intake (Ebay) Ukrainian102 Archived Corolla threads 13 09-14-2004 08:12 AM
