Re: 1986 toyota celica heating problems
"Andrew Stephenson" <ames@deltrak.demon.co.uk> wrote in message
news:1172669666snz@deltrak.demon.co.uk...[color=blue]
> In article <d358e$45e52ce7$47c2b532$391@msgid.meganewsservers.com>
> rokigawaATtristarassociatesDOTcom "Ray O" writes:
>[color=green]
>> [...] I doubt if you can buy a resistor pack at an auto parts
>> store, but if you know how to solder, you can purchase the
>> individual resistors at an electronics store and replace them.
>> You have to look at the resistance of each resistor to find an
>> acceptable substitute.[/color]
> Make sure the resistors are constructed so as to handle whatever
> power you are asking them to dissipate. The tiny resistors that
> one finds used in low-power electronics, for example, tend to be
> good for only 1/10 to 1/4 watt (or used to be, back when I did a
> lot of that stuff). Resistors for "power" jobs should show very
> clearly what their rating is, fortunately.
> Now to calculate the power handling. If the resistors are being
> wired "in parallel" (wire at one end tied to corresponding wires
> of all other resistors, with the same at the other end) then you
> should be safe in allowing for dropping the full battery voltage
> across the resistors; of course, in practice the fan will handle
> some of it. The watts dissipated by a resistor of R ohms when V
> volts are dropped across it are V * V / R. Do this sum for each
> resistor and it will give you the individual wattage ratings.
> If the resistors are wired "in series", it gets more complicated
> than I think should be rushed through here. Parallel seems more
> likely to serve your needs.
> BTW, large power resistors are often made to be bolted to a heat
> sink. It then becomes more of a construction project. Overall,
> it is probably best to try doing it as in the existing setup.
> Ray can probably set yea/nay on this: maybe the shop manual says
> what the resistor wattage should be.
> Andrew Stephenson
>[/color]
Very good points! I was thinking more in terms of removing the bad
resistors, taking them to an electrical supply store, asking them for
suitable replacements, and re-soldering the replacements in the same
location. Hopefully, the electrical supply store would know which
replacements work.
Ray O
