Re: Bigger alternator?
"Mama Bear" <MamaBear@No-Spam.noo> wrote in message news:Xns98E7D51BF5543Mama@216.196.97.142...[color=blue]
> Are bigger ( higher capacity ) alternators very expensive and hard to find
> for the 93 Corolla 1.8 liter EFI?
> I have an 120 VAC air cleaner in the back seat, running off an inverter,
> and when I also have the lights on at night and the rear window defroster
> on, it can start lowering the engine RPM's and making the inverter beep
> all the time, and the lights get dimmer. If I add the hazard flashers to
> the headlight usage at night, the engine RPM's go up and down with the
> flashing.
> The guy at Goodyear today says that it may just be that the alternator
> doesn't have the capacity to handle all the usage.
> AND I want to add a spotlight and a dash mounted map light, maybe even a
> laptop to the car too.
> - Mama Bear[/color]
What the heck. A home air purifier?
Even if a car had 0% air leaks and the ventilation control set on recirculate when your driving there is way to much fresh air going
in and out of the cabin for that to work. That type air purifier works 24/7 for long periods of time on the same air to do its job.
Even a home a/c system would not be able to do handle the load from that much air leaking inside.
Dan
