Re: 04 corolla not starting tried everything I could think of
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:4b306$45ebc47a$47c2b532$26252@msgid.meganewsservers.com...[color=blue]
> "gsx600" <none@000.com> wrote in message
> news:980636_5435e122639a7035d452f75a62cd88c6@autoboardz.com...[color=green]
>>I have an 04 corolla it was rolled over into some snow, now it will
>> not start. I have a good battrey and it is getting plenty of power. I
>> am only geting some of the dash lights like oil and door open, but not
>> check engine light, (at any time). I have checked all fuses, I have
>> swapped relays, the starter is good. the car will not even attemt to
>> start. I was told that the car should start even if the ecu is not
>> working correctly, the computer is the last thing I can think of but I
>> was hopeing maybe someone had some input before I buy one. need some
>> ideas please help
>>[/color]
> Start with the basics - air, fuel, and spark at the appropriate time.
> Whether the car will start or not with a bad ECU depends on what is wrong
> with the ECU.
> Ray O
> (correct punctuation to reply)[/color]
Does it have a fuel pump cutoff that needs to be reset, and since you said
it rolled over, did the fluids drain out of the battery? Did any wiring
pull loose?
