Ignition Wire , Starter , AC problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2007, 09:09 AM   #1 (permalink)
vivekian
Guest
Posts: n/a
View vivekian's Photo Gallery
Hi,
My friend who owns a 1998 Toyota Corolla driven 120000 miles recently
had problems with his car starting up. Seems like the starter was
broken, although he stretched the car for a few days this way.
Recently, when he was driving the car wouldnt stop firing and even if
he tried would not shut down. Eventually the ignition wire burnt out
leaving a lot of smoke behind.
The car technitian said that the malfunctioning starter caused the
ignition wire to burn out and replaced both of them. This was fine,
but there is another problem now where when the AC is started , the
compresser locks and the engine stops.
Was just wondering if someone can point to what could be the problem
here or any pointers would be helpful.
Thanks,
vivekian
Old 03-07-2007, 07:34 AM   #2 (permalink)
vivekian
Guest
Posts: n/a
Re: Ignition Wire , Starter , AC problems
On Mar 6, 1:40 pm, "Ph@Boy" <u...@example.net> wrote:[color=blue]
> vivekian wrote:[color=green]
> > Hi,[/color]
>[color=green]
> > leaving a lot of smoke behind.[/color]
>[color=green]
> > compresser locks and the engine stops.[/color]
>[color=green]
> > here or any pointers would be helpful.[/color]
>[color=green]
> > Thanks,
> > vivekian[/color]
> Are you certain that the AC compressor is frozen, or by pushing the
> accelerator pedal a bit to increase engine speed can you keep it
> running? Do you hear any "belt squeal"? It could be that the engine rpm
> is not being increased when the compressor is started and that stalls
> the engine. Please provide a bit more information.[/color]
Havnt tried that as yet, but i will ask him to do that. From what i
had seen, the car was started and was in the parking gear. Now after a
few seconds when the AC was started, the compresser would lock and the
car stop subsequently. Also, the AC had not given him any problems
earlier. Its only after the burning of the ignition wire that this has
happened.
BB code is Off
Smilies are Off
[IMG] code is Off
Getting alarm to chirp procedure - here it is JJMARINE 2nd Generation (2005+) 27 07-13-2007 05:06 PM
just a thought on the ignition starter warhorst Yaris, Vitz and Echo Forum 3 11-15-2006 11:04 AM
Help please!! Ignition problems!! stgranger MR2 Forum 6 07-16-2005 10:34 PM
Basic Amp Install Instructions Phi Audio, Video, and Security - Tech 11 04-06-2005 03:25 PM
AC problems BoiseXJ Camry & Solara Lounge 6 05-19-2003 04:15 PM
