Re: Tail lamp lens removel (Sienna tangent thread)
"Wingnut" wrote ...[color=blue]
> "dbu" wrote
>[color=green][color=darkred]
>>> I'm having trouble removing the tail lamp lens assembly on a 97
>>> avalon.[/color][/color]
>[color=green]
>> I'll tell ya how it's done on the 04 Sienna. A couple of hex screws,
>> then pull to the side and it pops off, kind of scarry the first time.
>> There is one or two pins in rubber grommets that hold it on and they
>> have to pull thru to release the lens.[/color]
> Same on my 2000 Sienna. After removing the screws, pry out carefully
> near the top front edge of the assembly. Be aware that those 2 little
> plastic pins that slip into the grommets are easily broken and dealers
> do not stock replacements. I had to jury rig mine with screws (with the
> head cut off) wrapped in cloth and pushed into the grommets.
>[/color]
I find this information useful, as I had asked this question a while back
for my 98 Sienna, without luck. I did not think of trying to slide it
sideways. There were the two nuts at the rear door's edge and that was
all that I could find. It pried out a bit, but looked like something else
was going to snap if I tried other tricks without knowing, so I stopped
there. I just want to replace backup bulbs with these brighter LEDs that
I found. I had since given up. I will try this slidey thing tomorrow.
Thanks guys.
Tomes
