Re: Very Strange Costco Tire Center experience (flat tire) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2007, 10:18 AM   #1 (permalink)
Mark
Guest
Posts: n/a
View Mark's Photo Gallery
Oh master of rash statements - How can believing that your tires could
go flat in a few days get you killed? If you are qualified to drive a
car, then you should be smart enough to make sure your tires are
properly inflated.
What's really dumb (not to mention dangerous for your passengers,
other drivers and pedestrians) is driving around for months in a
vehicle in which the tires deflate by 5 PSI or more *per day* - geez.
On Mar 14, 7:38 am, "JoeSpareBedroom" <dishborea...@yahoo.com> wrote:[color=blue]
> Another vote for Ray O's diagnosis. I've got serious leakage problems with
> the aluminum alloy wheels on my Tacoma, due to corrosion. They'll go from 35
> psi down to 20 in two or three days just sitting in the driveway. But, my
> mechanic never lied and said this was a situation I should accept. The
> wheels will be dealt with next week when I get new tires. And, the vibration
> you're noticing is most likely a balance issue.
> About that Costco employee who said your situation was normal: There are
> customers who will believe him, and it could get them killed. Matter of
> fact, the AAA estimates that 60% of cars are driving around with
> underinflated tires. You'll be doing others a favor if you walk into the
> store, ask to speak to the manager, and tell him/her that the guy in the
> tire department is either a habitual liar, or totally incompetent. Get that
> person fired. Write to the company's CEO, if necessary.[/color]
Old 03-14-2007, 10:56 AM   #2 (permalink)
JoeSpareBedroom
Guest
Posts: n/a
View JoeSpareBedroom's Photo Gallery
"Mark" <bogusmailmark@yahoo.com> wrote in message
news:1173885533.967832.261910@d57g2000hsg.googlegroups.com...[color=blue]
> On Mar 14, 7:38 am, "JoeSpareBedroom" <dishborea...@yahoo.com> wrote:[color=green]
>> with
>> 35
>> vibration
>> that
>[/color]
[color=blue]
> properly inflated.[/color]
"Believing" is not the issue. Actually having it happen is dangerous. Put
these facts together, and there's your answer:
1) According to my mechanic, it's not normal for corrosion-based leaks to
cause a totally flat tire in a few days. It would be good if it did, because
at least that would be immediately noticeable. But, the pressure usually
ends up in the middle somewhere, low enough that the tire doesn't work
correctly on wet or snowy roads, but not visually noticeable, hence the
advice to never say "They look fine - no need to check them".
2) Many drivers are oblivious to changes in their vehicle's performance.
They'll drive for months with 20-ish pounds in their tires. Maybe they'll
find out about the problem when they hydroplane and end up in a ditch. Or,
twice a year, when they go for an oil change, assuming their mechanic takes
a minute to check tire pressure.
60% of cars have underinflated tires.
[color=blue]
> vehicle in which the tires deflate by 5 PSI or more *per day* - geez.[/color]
It's checked every 48 hours, no matter what. There are reasons for waiting
to deal with it, which I will not go into here.
Old 03-14-2007, 11:17 AM   #3 (permalink)
JoeSpareBedroom
Guest
Posts: n/a
news:1173888442.316540.264340@l75g2000hse.googlegroups.com...[color=blue]
> On Mar 14, 11:56 am, "JoeSpareBedroom" <dishborea...@yahoo.com> wrote:[color=green]
>> "Mark" <bogusmailm...@yahoo.com> wrote in message
>>[color=darkred]
>> >> with
>> >> from
>> >> 35
>> >> my
>> >> vibration
>> >> you're noticing is most likely a balance issue.[/color]
>>[color=darkred]
>> >> are
>> >> of
>> >> the
>> >> the
>> >> that
>>[color=darkred]
>> because
>> Or,
>> takes
>>[color=darkred]
>> waiting
>> to deal with it, which I will not go into here.- Hide quoted text -
>> - Show quoted text -[/color]
>[/color]
[color=blue]
> If *believing* is not the issue, then why did you say (and I quote),
> "There are customers who will believe him, and it could get them
> killed.". Do you actually read what you post? The manager's silly
> claim didn't make the tire go flat. The claim was totally incorrect,
> but not "dangerous", as are YOUR actions continuing to drive around on
> faulty tires/wheels.
>[/color]
OK - I didn't explain that clearly. If the service writer makes the
situation sound normal, it may lead certain types of drivers to NOT get the
problem attended to quickly. So, they're driving around on soft tires. THAT
As far as my tires, I've already explained how often they're checked, so you
stop pretending not to have seen that information. Ideal pressure for these
tires (Nokian WR) is 34 on my truck. The worst case situation is that I
drive a mile to the grocery store with 29psi, if I don't have a few minutes
to pump them up at home. They've never been driven lower than that. I'm
keeping the tires on for another week because they're excellent in snow.
When the warm weather tires go on, that's when the corrosion will be dealt
with.
BB code is Off
Smilies are Off
[IMG] code is Off
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Run flat tire issues -sienna brn2rnjk1 2nd Generation (2004-2010) 9 12-29-2006 01:27 PM
Tires Feedback: Everyone please contribute. EKam Hardcore Tech and Competition 98 12-19-2006 02:05 AM
Tire mounting experience Doctor J General Discussion 12 11-07-2006 01:49 PM
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
