Re: I have a flat tire and it =?windows-1252?Q?won=92t_come_?==?windows-1252?Q?off!!_=9204_Corolla=2E?= - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-14-2007, 12:38 PM   #1 (permalink)
Ph@Boy
Guest
Posts: n/a
View Ph@Boy's Photo Gallery
beastmaster wrote:[color=blue]
> I know, I know. You’re saying to yourself, "This guy has to be
> kidding, right? He can’t even change a tire?" Well, let me elaborate
> before we start jumping to conclusions about my intelligence...
> I have an ’04 Corolla S. Earlier in the evening today, after I got out
> of class, I noticed that I had a flat. I’ve changed tires before, but
> this is my first flat with this car. I jacked up the car, took the
> five lug nuts off, tried to pull the tire off, but it wouldn’t budge.
> I took the tire iron and tried to pry it off. No luck. My only guess
> is that there is another nut in the center hub of the wheel, but I
> can’t get to it because there’s a cap over it.
> I was able to find someone with an air pump, and inflated my tire
> enough so that I could make it to the store and pick up some
> Fix-a-Flat. I’m due to have the tires changed, so I’ll have this taken
> care of tomorrow, but I’d like to know for future reference how to get
> a tire off of my car!
> Has anyone else experienced this? Maybe you work at a shop and have
> dealt with this issue. Please, I’m really confused.
>[/color]
Not unusual. Your driving conditions and time have corroded the wheels
to the hubs. I have had the same issues with other vehicles. Sometimes I
use a small sledge hammer and placing a wood board against the inside of
the rim with vehicle supported by my hoist. Other times I've had to
resort to a large slide hammer. If you try this yourself be patent and
careful not to strike so hard that you take a chance bending a rim. I
have had good luck using anit-seize lubricant between the rim and hub
prior to reassembly. You might want to check all the wheels on your car.
IMHO. Good luck.
BB code is Off
Smilies are Off
[IMG] code is Off
