98 Avalon front brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2005, 06:40 PM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 98 Avalon front brakes
"Lynn Kenney" <LynnKenney@ti.com> wrote in message
news:cvd207$fih$1@home.itg.ti.com...[color=blue]
> Our car is now approaching 83K miles. It has had two complete brake jobs
> and
> I'm already starting to feel the front rotors getting out of flat. Is this
> common with Toyota? Avalon? The last time I had the brakes done, it was
> done
> strictly to correct the shaky steering wheel while braking. The brake guy
> told me at the time that this was probably the last time he could turn the
> rotors. Question: Are these simply inferior rotors? If so, suggestions for
> place and or type to get as replacements? I'm in Dallas.
> Thanks in advance for your expert advice.
>[/color]
When you say "complete" brake jobs, do you mean:
A) replace front brake pads and machine front rotors
B) replace front brake pads and replace front rotors
C) replace front and rear brake pads and machine front and rear rotors
D) replace front and rear brake pads and replace front and rear rotors
Of course, there are variations - using genuine Toyota (OEM) parts or
non-Toyota brand (aftermarket) parts.
A rotor that is machined (referred to as "turning") will have a much greater
tendency to warp than one that has not been machined because there is less
metal to absorb and dissipate heat.
Rapid brake wear and warpage can be caused by several factors. Assuming you
are using OEM parts, the most likely causes are:
The last brake job removed too much rotor material during the machining
process;
The caliper slides are frozen in place;
Operating driving habits are causing rapid wear and warpage, ie., continuous
gradual braking, going down long hills with the brakes applied, etc.
That said, 40,000 miles is not that unreasonable for brake life in urban
environments.
Ray O
correct the return address punctuation to reply
Old 02-21-2005, 10:04 PM   #2 (permalink)
LK
Guest
Posts: n/a
View LK's Photo Gallery
I've never owned a car before where I had noticable rotor problems; Sterring
wheel shake while braking. . But I've never owned a "good" car before
either. My old S10 Blazer had 187 thousand on it and it received less
attention to it's brakes than the Avalon has. Since my wife drives this car,
I'll also point out that her old Ford Windstar also didn't have these type
issues with it's brakes.
When I had the original brake service the car had 37K miles but had been
exhibiting the wheel shake for at least a couple of thousand miles.
Thanks for your responses.
"Ray O" <rokigawa@tristarassociatesDOTcom> wrote in message
news:11d2a$421a7594$44a4a10d$23462@msgid.meganewsservers.com...
> and
> done
>[/color]
process;
environments.
Ray O
Old 02-22-2005, 11:21 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
"LK" <lynnkenney@comcast.net> wrote in message
news:Dd2dnd9MfO-3PIffRVn-iA@comcast.com...[color=blue]
> Sterring
> car,
> Thanks for your responses.[/color]
A rotor that has been machined (i.e., cut, turned) is more susceptible to
warping than one that has not. Our 97 Avalon has around 95,000 miles and I
have replaced the front pads replaced twice, rear pads once, never cut or
replaced rotors. I have used only OEM pads, and made sure that the caliper
slides are free and not sticking. We have not experienced any rotor
warping.
Ray O
Old 02-22-2005, 09:50 PM   #4 (permalink)
Rick
Guest
Posts: n/a
View Rick's Photo Gallery
My '99 Sienna required brake job when it was only 25K. The symptom was
shaking violently during braking. Dealer machined the rotor and replaced the
brake pad. I replaced the front brake pads at 85K and never experience the
same problem again.
Of course, the dealer said the rotor warpped because of the bad driving
habit. I believe that just a lie. Dealers always lie to make you pay even it
is listed on the TSB.
> Our car is now approaching 83K miles. It has had two complete brake jobs[/color]
and[color=blue]
> common with Toyota? Avalon? The last time I had the brakes done, it was[/color]
done[color=blue]
>[/color]
Old 03-02-2005, 11:08 PM   #5 (permalink)
=?ISO-8859-1?Q?MDT_Tech=AE?=
Guest
Posts: n/a
View =?ISO-8859-1?Q?MDT_Tech=AE?='s Photo Gallery
Rick wrote:
[color=blue]
> same problem again.
> is listed on the TSB.[/color]
Can you direct me to this TSB please?
Warped rotors can be from severla things, poor driving habits is one of
them.
Old 03-04-2005, 11:39 PM   #6 (permalink)
Lynn Kenney
Guest
Posts: n/a
View Lynn Kenney's Photo Gallery
Our car is now approaching 83K miles. It has had two complete brake jobs and
common with Toyota? Avalon? The last time I had the brakes done, it was done
Old 03-04-2005, 11:39 PM   #7 (permalink)
Z
Guest
Posts: n/a
View Z's Photo Gallery
Lynn Kenney wrote the following on 2/21/2005 11:24 AM:[color=blue]
>[/color]
For what it's worth, I've got a '98 Avalon that I bought with 20K miles,
and it now has 61K. I've never done any repairs or replacement of
brakes so far.
(I'd better go take a hard look at 'em!) I've never had any rotor warp
symptoms.
Of course, everybody's driving style and circumstances are different.
I would think you might want to get your brake calipers checked to make sure
they aren't holding pad against rotor when not requested by you.
If I needed rotors I would probably get Toyota replacements just to
avoid problems,
but I'm still in that mode of trying to use all-Toyota parts.
Old 03-04-2005, 11:40 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
> and
> done
>[/color]
process;
environments.
Ray O
Old 03-04-2005, 11:40 PM   #9 (permalink)
LK
Guest
Posts: n/a
> and
> done
>[/color]
process;
environments.
Ray O
Old 03-04-2005, 11:40 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
> Sterring
> car,
warping.
Ray O
Old 03-04-2005, 11:40 PM   #11 (permalink)
Rick
Guest
Posts: n/a
same problem again.
and[color=blue]
done[color=blue]
>[/color]
Old 03-04-2005, 11:44 PM   #12 (permalink)
Guest
Posts: n/a
Rick wrote:
[color=blue]
> same problem again.
them.
BB code is Off
Smilies are Off
[IMG] code is Off
