Re: 97 Camry - When to replace struts?
In article <1108837006.908608.214680@z14g2000cwz.googlegroups.com>,
[email]condor_222@yahoo.com[/email] says...
[color=blue]
>Dear experts,
>I have a 97 Camry XLE with 125K miles on it.
>I'm told that I should now change the front and
>rear Macpherson struts.
>Is it time to change them? Or, how can I tell
>if the struts need changing?[/color]
You can do a visual inspection to see if any of the struts are leaking.
[color=blue]
>What differences should I feel in the handling
>after replacing them? If any?[/color]
You should end up with a smoother more controlled ride.
[color=blue]
>Do struts wear out like brakes and tires, or
>do they just work, or not, like an electrical part?[/color]
They slowly wear out. Sometimes they do completely fail if
you blow a seal. The wear is gradual so chances are you may not
notice the difference until you put new ones in.
[color=blue]
>How much do they affect your wheel alignment?[/color]
Not sure what you mean. When you change them, you should get the cars
alignment checked.
Alex
