MR2 steering rack - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2005, 11:45 AM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: MR2 steering rack
"anon" <none@whatever.com> wrote in message
news:cvf6mr$l4$1@sparta.btinternet.com...[color=blue]
> is it possible to rebuild the MR2 steering rack (SW20 1990 Mk2 (power
> steering)) with new seals,[/color]
Yes, it is possible to rebuild a steering rack with new seals, however, the
success rate for a do-it-yourselfer is probably pretty low. The job needs
to be done very carefully in very clean conditions, almost like a doctor's
office. You will need special service tools to do the job, and the price of
the kit is probably close to the price of a replacement rack. Because of
the low success rate of rebuilding racks, most service facilities just
replace them with either new or rebuilt racks.
You will also need to do a complete 4-wheel alignment on the car when done,
equipment that most people do not have in their garage.
recently i have been experiencing strange[color=blue]
> behaviour with the steering, it tends to wander, and doesnt always
> cetralise, everything else is in A1 condition, ball joints, tyres, wheel
> alignment etc, and the car is treated with kid gloves, IE: with great care
> so its not the result of a knock etc.
> What kind of behaviour would result if one of the power steering seals
> were
> worn, it sometimes feels as though its trying to steer one way or the
> other
> on its own, although this is very slight, but nonetheless cruising at
> speeds
> between 60 - 80mph have now become less controlled.
> i can't physically feel any wear in the rack itself, the tie-rods all
> seems
> good as do the steering couplings.
> a new steering rack is around £300 uk so i don't want to replace it if i
> can
> avoid it.
> secondly, assuming its feasable to rebuild the rack does anyone know where
> i
> can get a seal kit from in the uk, or from the US if shipping is an
> option.
> many thanks for any guidance.
> regards.
> steve.
>[/color]
Worn rack seals usually result in leaks or difficult steering. Check the
condition of the u-joint(s) in the steering shaft to make sure they are not
loose, worn, or binding. Make sure there are not broken belts in any of the
tires.
You did not mention if you had the alignment checked recently, that is a
good first step to diagnosing your problem. The MR2 has a lot of positive
caster to help steering stability, and if that spec is off, you will
experience some wandering.
Ray O
correct the return address punctuation to reply
Old 02-23-2005, 05:36 AM   #2 (permalink)
anon
Guest
Posts: n/a
View anon's Photo Gallery
Thanks for your reply, I am a technician in the UK, just never actually
rebuilt a Power steering rack during my time, I wouldnt bother for a
customer, but since the cost of a new rack for the MR2 is ridiculously
overpriced compared to most power racks i would consider rebuilding it.
i guess the real poser is the cost of a repair / rebuild kit in comparison
to a new rack.
steve.
"Ray O" <rokigawa@tristarassociatesDOTcom> wrote in message
news:d2f6c$421b6859$44a4a10d$1615@msgid.meganewsservers.com...[color=blue]
> news:cvf6mr$l4$1@sparta.btinternet.com...[color=green]
> Yes, it is possible to rebuild a steering rack with new seals, however,[/color]
the[color=blue]
> office. You will need special service tools to do the job, and the price[/color]
of[color=blue]
> You will also need to do a complete 4-wheel alignment on the car when[/color]
done,[color=blue]
> recently i have been experiencing strange[color=green]
> > alignment etc, and the car is treated with kid gloves, IE: with great[/color][/color]
care[color=blue][color=green]
> > were
> > other
> > speeds
> > seems
> > can
> > avoid it.
> > secondly, assuming its feasable to rebuild the rack does anyone know[/color][/color]
where[color=blue][color=green]
> > i
> > option.
> > regards.
> > steve.
> >[/color]
> condition of the u-joint(s) in the steering shaft to make sure they are[/color]
not[color=blue]
> loose, worn, or binding. Make sure there are not broken belts in any of[/color]
the[color=blue]
> tires.
> Ray O
>[/color]
Old 02-23-2005, 12:16 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
news:cvhmbc$bqs$1@hercules.btinternet.com...[color=blue]
> to a new rack.
> steve.
>[/color]
The cost of a repair/rebuild kit for a rack should be substantially less
than for a new rack. The high price of the kit I referred to before was for
the SST kit, not the rebuild kit. IIRC, the kit consists mostly of seal
drivers.
If you're willing to invest your time and the cost of a rebuild kit and you
have access to the factory repair manual and a good set of seal drivers,
alignment rack, etc, then give it a try.
There are also several aftermarket racks available, you might want to check
those out as well.
Good luck!
Ray O
Old 03-03-2005, 10:05 PM   #4 (permalink)
fireball
Guest
Posts: n/a
View fireball's Photo Gallery
Re: Re: MR2 steering rack
"Ray O" wrote:[color=blue]
> news:cvhmbc$bqs$1@hercules.btinternet.com...[color=green]
> > Thanks for your reply, I am a technician in the UK, just[/color]
> never actually[color=green]
> > rebuilt a Power steering rack during my time, I wouldnt[/color]
> bother for a[color=green]
> > customer, but since the cost of a new rack for the MR2 is[/color]
> ridiculously[color=green]
> > overpriced compared to most power racks i would consider[/color]
> rebuilding it.[color=green]
> > i guess the real poser is the cost of a repair / rebuild kit[/color]
> in comparison[color=green]
> > to a new rack.
> > steve.
> >[/color]
> substantially less
> before was for
> mostly of seal
> drivers.
> rebuild kit and you
> seal drivers,
> want to check
> those out as well.
> Good luck!
> Ray O
> correct the return address punctuation to reply[/color]
I just discovered the source of steering wheel play in my 1987 MR2--in
a location I didn’t even know was possible. So you might check to see
if this is your problem too. Everything under the front end is tight,
but the steering wheel has ~4 cm of free play. When I looked up under
the dashboard at the linkage from the steering wheel to the fireall, I
found free play between two parts of what appeared to be a single
steel rod. It is between one U-joint connected to the steering wheel
and another leading to the rack. The part consists of a ribbed steel
rod inserted into a steel sleeve. It apears the two are glued
together with some rubber compound which has deteriorated and is
falling out. Does anyone know what’s going on with this or whether it
can be fixed without replacing the entire steering wheel linkage?
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-MR2-steering-rack-ftopict104481.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=493265[/url]
Old 03-04-2005, 01:38 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
"fireball" <UseLinkToEmail@New & Used Cars Forums - AutoForumz.com> wrote in
message news:4227d096$1_3@alt.athenanews.com...[color=blue]
> "Ray O" wrote:[color=green]
> > news:cvhmbc$bqs$1@hercules.btinternet.com...[color=darkred]
> > never actually[color=darkred]
> > bother for a[color=darkred]
> > ridiculously[color=darkred]
> > rebuilding it.[color=darkred]
> > in comparison[color=darkred]
> > > to a new rack.
> > > steve.
> > >[/color]
> > substantially less
> > before was for
> > mostly of seal
> > drivers.
> > rebuild kit and you
> > seal drivers,
> > want to check
> > those out as well.
> > Good luck!
> > Ray O
> a location I didn't even know was possible. So you might check to see
> falling out. Does anyone know what's going on with this or whether it
>[/color]
The steering column is designed to collapse upon impact, referred to as an
energy absorbing steering column. The part of the column that collapses
usually looks almost like a basket weave but I've never looked closely at
the MR2's design and it may be more like a telescopic design.
The best way to find out if it can be fixed without replacing the entire
steering column is to go to a Toyota dealer and ask the service department
or ask the parts department to show you the parts drawing.
Ray O
Old 03-04-2005, 03:22 PM   #6 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
On Tue, 22 Feb 2005 10:45:17 -0600, Ray O wrote:
[color=blue]
> replace them with either new or rebuilt racks.[/color]
LOL! The success rate from some of the rebuild shops isn't so swift,
either! We had to return about 10% from our supplier! Still, better than
some alternators we were selling! (60% return rate!) Even though we had
some in stock, the boss would not sell them!
[color=blue]
>> were
>> other
>> speeds
>> seems
>> can
>> avoid it.
>> i
>> option.
>> regards.
>> steve.
>>[/color]
> tires.
> experience some wandering.[/color]
Old 03-04-2005, 09:41 PM   #7 (permalink)
c0smic
Guest
Posts: n/a
View c0smic's Photo Gallery
fireball wrote:
[color=blue]
>[/color]
There is one U-joint between the steering shaft and the rack and a Mark 1
MR2. It is held in place with set bolts. There is another U-joint above it,
but I think it’s part of the steering shaft and not replaceable without
replacing the steering shaft. It’s probably the lower U-joint that needs
replacing. Just loosen the set bolts and pull the U-joint up on the shaft
to free the bottom part and then drop it down. It’s definitely not glued
with rubber. The rubber is probably the grommet where the pinion shaft
comes through the firewall. It’s hard to get to. You will need to lay on
the floor. The only trick is to get the steering pinion and the steering
shaft in the exact position they were before you removed the U-joint. There
are about 12 splines on the U-joint. It took me a few tries to get the
steering wheel straight. I heard a popping noise when steering before the
repair.
Old 03-04-2005, 11:40 PM   #8 (permalink)
anon
Guest
Posts: n/a
MR2 steering rack
steering)) with new seals, recently i have been experiencing strange
What kind of behaviour would result if one of the power steering seals were
worn, it sometimes feels as though its trying to steer one way or the other
on its own, although this is very slight, but nonetheless cruising at speeds
i can't physically feel any wear in the rack itself, the tie-rods all seems
a new steering rack is around £300 uk so i don't want to replace it if i can
avoid it.
secondly, assuming its feasable to rebuild the rack does anyone know where i
can get a seal kit from in the uk, or from the US if shipping is an option.
regards.
steve.
Old 03-04-2005, 11:40 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
> were
> other
> speeds
> seems
> can
> avoid it.
> i
> option.
> regards.
> steve.
>[/color]
tires.
Ray O
Old 03-04-2005, 11:40 PM   #10 (permalink)
anon
Guest
Posts: n/a
to a new rack.
steve.
the[color=blue]
of[color=blue]
done,[color=blue]
> > were
> > other
> > speeds
> > seems
> > can
> > avoid it.
> > i
> > option.
> > regards.
> > steve.
> >[/color]
not[color=blue]
the[color=blue]
> tires.
> Ray O
>[/color]
Old 03-04-2005, 11:41 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
> to a new rack.
> steve.
>[/color]
drivers.
those out as well.
Good luck!
Ray O
Old 03-04-2005, 11:45 PM   #12 (permalink)
fireball
Guest
Posts: n/a
> > to a new rack.
> > steve.
> >[/color]
> substantially less
> before was for
> mostly of seal
> drivers.
> rebuild kit and you
> seal drivers,
> want to check
> those out as well.
> Good luck!
> Ray O
Old 03-04-2005, 11:47 PM   #13 (permalink)
Ray O
Guest
Posts: n/a
> > > to a new rack.
> > > steve.
> > >[/color]
> > substantially less
> > before was for
> > mostly of seal
> > drivers.
> > rebuild kit and you
> > seal drivers,
> > want to check
> > those out as well.
> > Good luck!
> > Ray O
>[/color]
Ray O
Old 03-04-2005, 11:48 PM   #14 (permalink)
c0smic
Guest
Posts: n/a
fireball wrote:
[color=blue]
>[/color]
repair.
BB code is Off
Smilies are Off
[IMG] code is Off
