Re: Timing Belt Change Intervals - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2005, 10:18 PM   #1 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
"y_p_w" <y_p_w@hotmail.com> wrote:
[color=blue]
>Gord Beaman wrote:[color=green]
>> y_p_w <y_p_w@hotmail.com> wrote:
>>[color=darkred]
>> >Gord Beaman wrote:
>> >> "jor" <jor@jor.com> wrote:
>> >>>My 2000 Avalon book calls for it at 90,000. Not sure what an[/color][/color]
>interference[color=green][color=darkred]
>> >>>engine is?
>> >>>jor
>> >> An interference engine is one in which, if the timing belt/chain
>> >> breaks, the pistons will hit the valves as the engine 'runs down
>> >> to a stop' causing much damage to the engine. I understand from
>> >> the Toyota experts here that in modern Toyota engines, if they
>> >> have a 'timing belt' then they have a non-interference engine and
>> >> if they have a 'timing chain' then they have an interference
>> >> engine...Mind you, I'm NOT an expert in these engines but that's
>> >> what I gather here. YMMV. :)
>> >Isn't there the one-in-a-trillion chance that if the timing
>> >mechanism breaks, the pistons and valves miraculously move at
>> >the same exact rate and never slam into each other? ;-)[/color]
>> No, the valves STOP and the pistons DON'T... (big difference in
>> their inertia) :)[/color]
>Whoops. Forgot the whole thing about valves being attached to
>springs. I was thinking of the whole "Give a bunch of chimpanzees
>some typewriters and enough time, and they'll produce the complete
>works of Shakespeare" cliche.[/color]
Well, actually the springs play no part in the damage at
all...all they do is 'close' the valve as the tappet/push
rod/hydraulic lifter and cam allow them to. So when the piston
contacts the valve head it's a 'rock and a hard place' kind of
contact...the kind that costs big bux...and yes, I know where
you're coming from but I'd think that there's no chance of that
happening because of the large difference in inertia between the
cam shaft(s) on one hand and the rest of the engine on the other.
I'd think that the camshafts would stop almost instantly and the
rest of the engine wouldn't...
-Gord.
(use gordon in email)
Old 02-25-2005, 04:32 PM   #2 (permalink)
Stephen Bendzick
Guest
Posts: n/a
View Stephen Bendzick's Photo Gallery
Gord Beaman wrote:[color=blue]
>[color=green]
> >Gord Beaman wrote:[color=darkred]
> --[/color]
Yes, Gordon, I completely agree with you. Just on the basis of inertia
within the engine, the valve train is going to stop long before the
pistons do, as long as neither is, er... /influencing/ the other. :)
In addition, I note (to everyone) that if the belt fails, it will
probably fail during driving, not idling. In this case, the crankshaft
will be driven through the transmission, driveshaft (if any), axles, and
wheels by the entire linear inertia (forward momentum) of the car. The
rotational inertia of all these parts will also contribute to driving
the crankshaft. If the timing belt or chain in a non-interference
engine breaks at substantial speed (say 30 MPH), and if the transmission
remains engaged (and the brakes not), the difference in time between
when the valve train stops and when the pistons stop will be multiple
seconds.
Therefore, in an interference engine, the time difference will be
noticeably shorter. :)
Stephen
Old 03-04-2005, 10:40 PM   #3 (permalink)
y_p_w
Guest
Posts: n/a
View y_p_w's Photo Gallery
>[color=green]
> >Gord Beaman wrote:
> >[color=darkred]
> >>>My 2000 Avalon book calls for it at 90,000. Not sure what an[/color][/color][/color]
interference[color=blue][color=green][color=darkred]
> >>>engine is?
> >>>jor
> >> what I gather here. YMMV. :)[/color]
Old 03-04-2005, 10:40 PM   #4 (permalink)
Gord Beaman
Guest
Posts: n/a
[color=blue]
>>[color=darkred]
>> >>>engine is?
>> >>>jor
-Gord.
Old 03-04-2005, 10:42 PM   #5 (permalink)
Stephen Bendzick
Guest
Posts: n/a
>[color=green]
> --[/color]
seconds.
Stephen
BB code is Off
Smilies are Off
[IMG] code is Off
