"jor" <jor@jor.com> wrote:
[color=blue]
>I had forgotten about this post and wanted to answer Gordon's question
>regarding the mileage at which my timing belts went south. I've had three
>Camrys (83, 89 and 02). I bought the first two new. Anyhow, after thinking
>about it I realized that both times timing belt broke were on the 83. As I
>recall, it was only several thousand miles beyond 60K and 120K
>(stupid=repeating the same mistake expecting a different result). Anyhow, I
>learned my lesson (it just takes longer with some of us).
>jor (unrepentant top poster)[color=green][color=darkred]
>>>>>[/color][/color][/color]
Ok jor, thanks...I'm assumeing that they recommended changing
them at 60K by the way you worded that...I would guess that they
knew what to recommend. right?... :) Cheers.
Yea. The manual clearly states that the timing belt must be changed at 60K.
I'm thinking that I was really lucky the first time. When I was trying to
diagnose the problem on the side of the road I pulled a plug and turned the
engine over for awhile. There wasn't any compression so I figured it was
probably the belt. Had to tow the damn thing with my old pickup a 100 miles
or so to Minot, North Dakota in the middle of the winter but that's another
story...
jor
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:9p5o115j9f5p2gn4b3abtd95clcahbg7ls@4ax.com...[color=blue]
>[color=green]
>>I
>>jor (unrepentant top poster)[color=darkred]
>>>>>>[/color][/color]
> -Gord.
> (use gordon in email)[/color]
[color=blue]
>story...
>jor
>[/color]
Fun...
I had a 51 Chev in the mid fifties while I was in the RCAF, it
left me on the roadside once...
Long story short, the overhead camshaft on that car was driven at
the front by a fibre gear meshing with other gears down the front
portion of the engine (inside of course). This fibre gear had
split and you get the same effect as a broken timing chain. No
damage otherwise (except to my skinny wallet) :)
Well, the reason that you didn't have major engine damage is because Toyota,
unlike Honda, doesn't manufacture interference fit engines! This however,
is also why Honda is able to squeeze a small amount of additional horsepower
from their engines!
OldGuy
"jor" <jor@jor.com> wrote in message
news:s5ydnYkDmonzS4bfRVn-sQ@giganews.com...[color=blue]
> (stupid=repeating the same mistake expecting a different result). Anyhow,[/color]
I[color=blue]
> >>>>[/color][/color]
> Yes jor, you certainly -were- lucky with your Camrys...that can
> really do a lot of engine damage, just imagine pistons smashing
> into open valves trying to ram them toward closed!
> The gentlemen who hang around here sometimes aren't, so you need
> a thick skin..(Hint: Top posting sometimes riles them too). :)
> You're lucky that SWMBO was at the wheel!...
> Be interesting to see at what mileage they broke...you remember?
>[/color]
"Jim Simonin" <jsimonin@zianet.com> wrote in message
news:421cbf99@nntp.zianet.com...[color=blue]
> Toyota,
> horsepower
> from their engines!
> OldGuy
>[/color]
Toyota does make interference engines. The OP's car was not an interference
fit.
Ray O
correct the return address punctuation to reply
> Well, the reason that you didn't have major engine damage is because[/color]
Toyota,[color=blue]
> is also why Honda is able to squeeze a small amount of additional[/color]
horsepower[color=blue]
> from their engines!
> OldGuy[/color]
All Hondas ARE interference, most Toyotas with DOHCs aren't. However, a good
deal of the SOHCs ARE interference. I know the 3A-C used in the Tercels from
the 80's are.
Most of the recent engines (all, I should say) are not interference, and
Toyota has gone back to chains on some of their engines (thank God!)
[color=blue]
> news:s5ydnYkDmonzS4bfRVn-sQ@giganews.com...[color=green]
> > regarding the mileage at which my timing belts went south. I've had[/color][/color]
three[color=blue][color=green]
> > Camrys (83, 89 and 02). I bought the first two new. Anyhow, after[/color][/color]
thinking[color=blue][color=green]
> > about it I realized that both times timing belt broke were on the 83. As[/color][/color]
I[color=blue][color=green]
> > (stupid=repeating the same mistake expecting a different result).[/color][/color]
Anyhow,[color=blue]
> I[color=green]
> > >>>>[/color]
> >[/color]
>[/color]
On Wed, 23 Feb 2005 16:55:05 GMT, Gord Beaman <gord@islandtelecom.com>
wrote:[color=blue]
>"jor" <jor@jor.com> wrote:[/color]
>>story...[/color]
>Fun...
>damage otherwise (except to my skinny wallet) :)[/color]
They used the molded phenolic fibre cam gear because it was quiet.
So what if it also made the car rather unreliable after 30K or 50K
miles? Detroit didn't care - They wanted you to trade the car in for
a new one every year or two, three at the outside.
That's why they would do a subtle restyle of bumpers, grilles and
taillights every year, and a radical restyle of every model every
three or four - so the neighbors could tell you still had an OLD car.
It took Toyota and Datsun to give Detroit a big wake-up call to make
their cars work better and last longer, or they would soon go the way
of REO Speedwagon and Packard.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
jor (unrepentant top poster)[color=blue][color=green][color=darkred]
[color=blue]
story...
jor
>[color=green]
>>I
>>>>>>[/color][/color]
> -Gord.
[color=blue]
>story...
>jor
>[/color]
Fun...
from their engines!
OldGuy
I[color=blue]
> >>>>[/color][/color]
>[/color]
> Toyota,
> horsepower
> from their engines!
> OldGuy
>[/color]
fit.
Ray O
Toyota,[color=blue]
> from their engines!
> OldGuy[/color]
the 80's are.
[color=blue]
Anyhow,[color=blue]
> I[color=green]
> > >>>>[/color]
> >[/color]
>[/color]
wrote:[color=blue]
>>story...[/color]
>Fun...
--<< Bruce >>--
