"Stephen" <stephen2718@yahoo.com> wrote in message
news:1109181279.778549.326570@f14g2000cwb.googlegroups.com...[color=blue]
> Well, all of the above things were checked out again by another
> mechanic and nothing was found. My next step will be to go to a dealer
> shop and have them look at the problem, although I know this will cost
> a lot of money to do.
>[/color]
Sorry, I missed your original list of complaints. Someone mentioned a
vacuum leak, and before going around trying to find a leak, you or a service
facility should hook up a vacuum guage and see if vacuum is out of spec.
[color=blue]
> There is one other problem that I am having that is related to all of
> the above things I mentioned.
> In the morning, when the car has been completely cooled down, when I am
> reversing out of my garage, the car almost dies every time (the RPM
> guage goes to zero and the engine sounds like it is not even on), and
> only after putting the car in drive, putting my foot on the gas gently,
> and waiting will the car go (and it starts out going really really
> slowly but I am just happy to have it moving).
> Does any of this add to the situation's clarity or does it just
> complicate things even more?
> Thanks,
> Stephen[/color]
This sounds like a bad idle air control valve.
Ray O
correct the return address punctuation to reply
[color=blue]
> Sorry, I missed your original list of complaints. Someone mentioned[/color]
a[color=blue]
> vacuum leak, and before going around trying to find a leak, you or a[/color]
service[color=blue]
> facility should hook up a vacuum guage and see if vacuum is out of[/color]
spec.
We checked this out and there did not appear to be any vacuum leaks.
[color=blue]
> This sounds like a bad idle air control valve.[/color]
I have a couple of questions so that I know exactly what to tell a
certified toyota mechanic.
Could this type of problem exist without any vacuum leaks? Could this
also be an electrical problem? Could this be a problem that is not
able to be confirmed by any computer tests? I am asking the last
question because nothing has come up on any of the computer tests yet.
"Ray O" <rokigawa@tristarassociatesDOTcom> wrote:
[color=blue]
>news:1109190313.898071.103200@f14g2000cwb.googlegroups.com...[color=green]
>>[color=darkred]
>> a[color=darkred]
>> service[color=darkred]
>> spec.
>>[color=darkred]
>> Thank you for the help Ray O.
>> Stephen
>>[/color]
>Sorry, I still don't know what type of problems you're having other than the
>engine almost dying when idling after a cold soak start so I can't tell you
>if they are likely to be related or not.
>In general, various problems can and do exist without vacuum leaks. That is
>why I suggested using a vacuum gauge to check vacuum before looking for
>leaks.
>A mistake that many people make is going to a service facility, whether it
>is a dealer, independent repair facility, or their neighbor and asking the
>facility to check a particular component, especially if the person doing the
>asking is not as knowledgeable as the person doing the checking. A much
>better way to get your car diagnosed properly is to carefully note the
>symptoms and when they occur, ambient temperature, how long it has been
>parked or idling, etc. and then carefully and completely describing the
>symptoms to the service advisor and letting the service facility make
>diagnosis and repair.
>I worked in the auto business for 15 years, and when I took my car to the
>shop to have the AC fixed, I said "AC doesn't get cool," not recharge
>refrigerant or check schrader valve or check expansion valve, etc.
>For example, going to a dealer and asking the dealer to check the idle air
>control valve is like going to a doctor with chest pains and asking the
>doctor to do exploratory surgery on the right ventricle when the doctor
>might just prescribe antacids for heartburn.
>I'll give you my educated guesses on what the cause or fix may be, but when
>you take your car to get fixed, do yourself a favor and ignore what I and
>every other poster tells you and just describe what the car is doing.[/color]
Well, the reason why I asked about specific things is that whenever I
took the car with generalizations of the problem, nothing was ever
found. And this was taking it to certified toyota mechanics. :-(
news:1109367470.827287.193720@f14g2000cwb.googlegroups.com...[color=blue]
> Thanks,
> Stephen
>[/color]
There is no formal title called "Certified Toyota Mechanic" in the U.S.
When you say "certified Toyota Mechanics" do you mean that you took the car
to a Franchised Toyota dealer? Most dealers try to hire technicians who are
trained professionals. A technician not only works on the mechanical
components of the vehicle, the tech can also work on HVAC, electrical,
electronic components, read and interpret a wiring diagram, etc.
After the technicians get some tenure, attend factory required classes, and
pass ASE certifications, they can achieve various designations. I think the
designations have changed, but it used to be Apprentice, Pro, and after at
least 5 years, Master Diagnostic Tech (MDT). The MDT's I personally knew
were all pretty sharp.
A Toyota Apprentice, Pro, or Master Diagnostic Tech must be employed by a
Toyota dealer. If you took your car to a service facility that is not a
franchised Toyota dealer, then whoever worked on your car would at best be a
former Toyota MDT.
Ray O
[color=blue]
>news:1109181279.778549.326570@f14g2000cwb.googlegroups.com...[color=green]
>> Thanks,
>> Stephen[/color]
I agree. I've had the IACV on my '97 Avalon replaced twice (37k and
102k miles) to fix the stalling-when-cold problem.
Thanks,
Stephen
[email]max-income@comcast.net[/email] wrote:[color=blue]
> On 8-Jan-2005, "Stephen" <stephen2718@yahoo.com> wrote:
>[color=green]
> > Most likely there is a leak in one of the vacuum tubes, but the[/color][/color]
auto[color=blue][color=green]
> > repair people were unable to determine which one it was. Is there[/color][/color]
any[color=blue][color=green]
> > way of knowing which leak it is, or even if I am sure that it is a[/color][/color]
leak[color=blue][color=green]
> > at all? Has anyone ever experienced anything like this?[/color]
> Take a short length of vacuum hose (or anything about that size).[/color]
Start the[color=blue]
> car, and put one end of the tube to your ear. Use the other to poke[/color]
around[color=blue]
> the vacuum hoses. When you hear a loud hiss, you've found the leak.[/color]
Cheaper[color=blue]
> than buying a stethoscope. And if you want to be sure of what you're
> hearing, disconnect a vacuum hose and listen to how it sounds.
> Every day is a good day- it's just that some are better than others.[/color]
>[/color]
[color=blue]
> Thanks,
> Stephen[/color]
Ray O
[color=blue]
a[color=blue]
service[color=blue]
spec.
[color=blue]
news:1109190313.898071.103200@f14g2000cwb.googlegroups.com...[color=blue]
>[color=green]
> a[color=green]
> service[color=green]
> spec.
>[color=green]
> Stephen
>[/color]
leaks.
Ray O
[color=blue]
>>[color=darkred]
>> a[color=darkred]
>> spec.
>>[color=darkred]
>> Stephen
>>[/color]
>leaks.
> Thanks,
> Stephen
>[/color]
former Toyota MDT.
Ray O
[color=blue]
>> Thanks,
>> Stephen[/color]
