When cold your car should idle considerably higher than when warm - like
1200-1330 vice normal of 900 RPM. Is it doing that?
"Keith Wickline" <KWickline123@webtv.net> wrote in message
news:7290-4220B656-642@storefull-3132.bay.webtv.net...[color=blue]
> Got a problem that I could use some help with.
> I have a 95 Corolla, 4-cyl, automatic, 125k miles.
> My problem is when I first start the car in cold weather. For the
> first 5 minutes the engine has a vibration (enough to rattle the dash)
> that goes away as the car warms up. The colder the outside temperature
> the worse the vibration is.
> Once warm the car runs smooth. This is at idle and in park. Never a
> check engine light.
> Replaced wires, plugs, cap, all motor mounts, and injector cleaner.
> Anyone have any suggestions?
> TIA
>[/color]
Thank you for responding!
Yes is does idle fast when cold. I even disconnected the sensor and
the idle dropped down but still had the vibration. Two people have
inspected the car and nothing is bumping against the frame. I am at a
loss here.
Any more ideas?
> check engine light.
> TIA
>[/color]
Make sure the ignition wires are tight. Did you use OEM or aftermarket
ignition parts?
Ray O
correct the return address punctuation to reply
check engine light.
TIA
> check engine light.
> TIA
>[/color]
loss here.
Any more ideas?
> check engine light.
> TIA
>[/color]
ignition parts?
Ray O
