@ Question About the air conditioning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2005, 03:19 PM   #1 (permalink)
m
Guest
Posts: n/a
View m's Photo Gallery
Hello There:
When I turn on the ac on my car (Year 2000), it will only work with the fan
on High (it will
function perfect). If I use low or medium fan speeds, nothing happens.
Any suggestion in the subject?
Thank you,
M
[email]nospammaltpc@mindsprin.com[/email]
(Please remove nospam to reply)
Old 03-08-2005, 03:33 PM   #2 (permalink)
DustyRhoades@mailcity.com
Guest
Posts: n/a
View DustyRhoades@mailcity.com's Photo Gallery
Re: @ Question About the air conditioning
Replace the fan switch, WBMA.
mike hunt
m wrote:[color=blue]
> Hello There:
> on High (it will
> Thank you,
> M
> (Please remove nospam to reply)[/color]
Old 03-08-2005, 03:47 PM   #3 (permalink)
m
Guest
Posts: n/a
Hello Mike:
Thank you for your reply.
I was just wondering, I replaced the battery and the same day I got this
problem with the ac, do you thing maybe this is related?
Is the fan switch right behing the little knob? Maybe I can replace it
myself.
Thank you,
M
<DustyRhoades@mailcity.com> wrote in message
news:422E0C0D.847B9A6B@mailcity.com...[color=blue]
> mike hunt
> m wrote:[color=green]
> > Hello There:
> > When I turn on the ac on my car (Year 2000), it will only work with the[/color][/color]
fan[color=blue][color=green]
> > on High (it will
> > Thank you,
> > M
> > (Please remove nospam to reply)[/color][/color]
Old 03-08-2005, 05:36 PM   #4 (permalink)
mrcheerful
Guest
Posts: n/a
View mrcheerful's Photo Gallery
"m" <onfd@aol.com> wrote in message
news:kNnXd.5719$CW2.3864@newsread3.news.atl.earthlink.net...[color=blue]
> Hello There:
> fan
> on High (it will
> Thank you,
> M[/color]
probably the speed regulator resistor pack has burnt out
Old 03-08-2005, 09:56 PM   #5 (permalink)
Tacoma Dude
Guest
Posts: n/a
View Tacoma Dude's Photo Gallery
mrcheerful . wrote:[color=blue]
>[color=green]
>>Hello There:
>>fan
>>on High (it will
>>Thank you,
>>M[/color]
>[/color]
aka the "blower resister"
Old 03-08-2005, 11:28 PM   #6 (permalink)
L.Morin
Guest
Posts: n/a
View L.Morin's Photo Gallery
There's a relay for the fan speeds. mine on my 1986 celica is near the
fan motor but on yours, i don't know. check it you can save on labor
Luc.
On Tue, 08 Mar 2005 20:19:28 GMT, "m" <onfd@aol.com> wrote:
[color=blue]
>Hello There:
>on High (it will
>Thank you,
>M
>[/color]
Old 03-09-2005, 11:14 AM   #7 (permalink)
m
Guest
Posts: n/a
Thank you all for your replies.
Yes, the blower resistor block.
Thank you again.
M
"L.Morin" <cuda@destination.ca> wrote in message
news:422e7b15.11667052@news.destination.ca...[color=blue]
> Luc.
>[color=green]
> >Hello There:
> >on High (it will
> >Thank you,
> >M
> >[/color]
>[/color]
Old 03-09-2005, 03:16 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> mike hunt
>[/color]
Mike,
What does WBMA stand for? Would be my assessment?
Ray O
correct the return address punctuation to reply
Old 03-09-2005, 11:03 PM   #9 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
On Wed, 09 Mar 2005 16:14:23 +0000, m wrote:
[color=blue]
> Thank you again.
> M
> =========================[/color]
Curiosity: Where IS it? On my older Toys, it is IN the fan housing. Not
real easy to get to!
[color=blue]
> news:422e7b15.11667052@news.destination.ca...[color=green]
>> Luc.
>>[color=darkred]
>> >Hello There:
> fan[color=green][color=darkred]
>> >on High (it will
>> >Thank you,
>> >M
>> >[/color]
>>[/color][/color]
Old 03-10-2005, 11:14 AM   #10 (permalink)
BigJohnson@mailcity.com
Guest
Posts: n/a
View BigJohnson@mailcity.com's Photo Gallery
Close enough, advise was what I meant however. ;)
mike hunt
Ray O wrote:[color=blue]
> news:422E0C0D.847B9A6B@mailcity.com...[color=green]
> > mike hunt
> >[/color]
> Mike,
> Ray O
> correct the return address punctuation to reply[/color]
Old 03-10-2005, 01:06 PM   #11 (permalink)
The Real Tom
Guest
Posts: n/a
View The Real Tom's Photo Gallery
[color=blue]
>Hello There:
>on High (it will
>Thank you,
>M
>[/color]
You could have dirty contacts.
Much easier to guess dirty contacts, rather than a burnt out resister.
Check there, you might need the switch replaced.
hth,
tom @ [url]www.BookmarkAdmin.com[/url]
Old 03-10-2005, 02:55 PM   #12 (permalink)
Ray O
Guest
Posts: n/a
<BigJohnson@mailcity.com> wrote in message
news:4230727C.A6B14FD4@mailcity.com...[color=blue]
> mike hunt
>[/color]
Thanks!
Ray O
Old 03-10-2005, 05:46 PM   #13 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
I am not clear.
The A/C and the Fan Speed are not related.
If you turn the fan speed selector from OFF, it should start on LOW, then go
to MED, then HIGH. It should do this without regard for the setting of the
A/C.
If the Fan works at all of the various speeds, but the A/C only works when
the Fan is set to HIGH, then I am not sure what the trouble is.
But if the Fan itself only works on HIGH, then there is a resistor pack that
has failed and needs to be replaced.
> Hello There:
fan[color=blue]
> on High (it will
> Thank you,
> M
>[/color]
Old 03-11-2005, 09:03 PM   #14 (permalink)
Stephen Bendzick
Guest
Posts: n/a
View Stephen Bendzick's Photo Gallery
The Real Tom wrote:[color=blue]
>[/color]
While dirty switch contacts and a burnt out resistor can theoretically
have the same effect, in practice contacts that are getting dirty will
gradually deteriorate, at first only occasionally fail to connect well
(until the switch is wiggled or moved slightly), then making
intermittent or poor connections with increasing frequency until they
eventually cease to ever connect. It's extremely uncommon for contacts
to one day be clean enough to work properly and the next day be dirty
enough not electrically connect at all. In addition, this case involves
multiple switch positions that do not work at all but one that works
normally. The odds of a few contacts in a switch suddenly going bad at
the same time but one or two being preserved are very low. Furthermore,
the one position that works, the fan high position, is the one that
would work with the resistor pack blown. Therefore, if I understand the
problem correctly (and I am assuming that the symptoms appeared all at
once together), the cause is almost certainly the resistor pack and not
the switch.
Stephen
BB code is Off
Smilies are Off
[IMG] code is Off
