Re: try again - Tarago wheels
ma_twain <ma_twain@yahoo.com> wrote in news:42325C18.6050902@yahoo.com:
[color=blue]
> TeGGer® wrote:
>[/color]
[color=blue]
> Why would the poster ask specifically about Ford rims? In there a
> collaboration between Ford and Toyota?[/color]
No way. GM and Toyota, yes.
[color=blue]
> I know the Chevy Nova and
> Corolla were the same cars[/color]
To the extent that you refer to the cars concurrently produced by NUMMI,
yes. Otherwise no.
[color=blue]
> and the Matrix and Vibe are almost the
> same.
> But these are not Fords.
>[/color]
Well, the rim diameter is the same across all brands. All over the world it
is measured in inches. That leaves only three important measurements
(besides bead profile): rim width, bolt pattern, and offset.
If the bolt pattern is the same and the rim width is the same or close,
then the offset is the only variable worth mentioning. Ford 5-bolt rims
just might work. Or not. If it was me, I'd take a straight-edge and a
measuring tape to the wrecking yard and do my own measuring.
And you'd need to make sure the new non-Toyota wheels clear your brake
calipers...
TeGGeR®
