Someone was kind enough to plow into the right side of my Cressida.
Moved the post up against the seat. I've got it bent back out most of
the way and replaced the doors. But I can't seem to get it exactly
right.
Anyone with bodyshop type knowledge know the best way to move the post
more without screwing up the roof or the floor?
gburnore@databasix dot com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
DataBasix | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ³ 3 4 1 4 2 ݳ޳ 6 9 0 6 9 ÝÛ³
Black Helicopter Repair Svcs Division | Official Proof of Purchase
Want one? GET one! [url]http://signup.databasix.com[/url]
On Fri, 11 Mar 2005 18:16:22 -0500, Gary L. Burnore wrote:
[color=blue]
> right.
> more without screwing up the roof or the floor?[/color]
Nice!!! I hope you got the name/number of the idiot!
Um, you COULD get a chain, and another car, and tug it out GENTLY! But
considering what the damage is and where it is, take it to a frame shop.
They are (almost) all laser with the correct parameters for the car
programmable into the system. It will cost you $200-500 to do this, but it
is really the best way to get everything straight.
The other method is to get your hands on a portapower and press it back
into shape; the downfall of this is that you may end up pressing the OTHER
(bracing) side of the car instead.
On Fri, 11 Mar 2005 23:31:53 GMT, hachiroku <levin@ae86.gts> wrote:
[color=blue]
>[color=green]
>> right.
>is really the best way to get everything straight.[/color]
I have to agree with Hachi, Gary - If you are looking to save money
yet have good results when you are done, bite the bullet and take it
to a local body shop with a full frame-pulling and tramming setup,
where they'll get it all straightened out properly and quickly. And
most important without doing any more damage - like you said, if you
tweak the roof or floorpan you just multiplied your problems.
But when you ask for an estimate, make sure they know you'll take
care of all the prep and paint work afterwards, and you only need them
to pull it out straight and true (and fix the welds if needed).
If you don't get the pillars (and the hinge and latch mounting pads)
back in exactly the right places, you'll play hell getting the doors
hung straight and latching easily...
Body filler, shaving, sanding, priming and painting is the easy part
- it just takes a boatload of time to do it right, or a whole lot of
experience to do it fast and right. For regular paint, even I can get
a decent finish with proper techniques - but there are certain paints
like Metallics, Pearls, Two-tones, Chroma change, etc. that you really
need to be a professional 'shooter' to match properly. Ask the body
shop if your car is one of them - you may end up doing all the body
prep, primer, spot putty and sanding work, and taking it back to them
to shoot the color coats.
(Long ago I did a quick and dirty paint patch job on my Corvair
decklid which is a metallic acrylic lacquer, and it stands out if you
look closely because the "grain" of the metal flakes doesn't match at
all. But it kept the rust away, which is all I wanted.)
If you want the repair to be reasonably invisible, you have to paint
and bake the doorjambs and door edges before you hang the doors again.
And carry that over onto the interior panels if they were messed up,
it'll slow the rust monster.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
[color=blue]
>[color=green]
>> right.
>Nice!!! I hope you got the name/number of the idiot![/color]
No, but I know it must have been a pickup or something. Hit right
between the front and back door, but didn't bend the lower frame or
the top of the car. Just the doors and the post.[color=blue]
>(bracing) side of the car instead.[/color]
Here's what I've done so far. Took off both doors the front and back
seat and the center console.
Put a 2x4 along the hump in the floor and a floor jack against that
and a pipe into the bent part. I've got it bent to within 1/2" of
where it really should be, but it appears twisted sligthly (Front in
1/2", back in 1/4".
So now I need to twist it somehow.
On Sat, 12 Mar 2005 05:27:08 GMT, Bruce L. Bergman
<blPYTHONbergman@earthlink.invalid> wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>>> right.
>to pull it out straight and true (and fix the welds if needed).[/color]
Yeah, that's probably next. But if I do it, I'll take both the doors
off again and the seats out before taking it in for the estimate.
[color=blue]
>hung straight and latching easily...[/color]
When you look at it from behind, it's concave about 1/2 inch in. And
yes, the worst part was getting the front door working correctly (Seat
belt only moves if the door is closed all the way). It works now, but
I've got to slam the door.
[color=blue]
>it'll slow the rust monster.[/color]
Heh. Should have mentioned in advance: About a year ago, I bought
another 89 Cressida that was FORD on the freeway and hauled to the
salvage yard. Paid 200 bucks for it and stripped it _BARE_. I've
already installed the new doors. Oh, btw, it's the same color too. :)
Gary L. Burnore <gburnore@databasix.com> wrote in
news:d0vdhq$9jt$1@valis.databasix.com:
[color=blue]
> 1/2", back in 1/4".
>[/color]
One technique I've seen used successfully:
Put the door back. Get a socket (or two) that fits between the post and the
door so that the door can not be shut. Now push and bounce the door hard
against the socket, which should flex the post more-or-less straight again,
at least most of the way. You're using the door as a lever and the socket
as a fulcrum, twisting the post straight again in the process.
This works well to correct the damage that's caused by allowing the wind to
fling the door open. Whether it will work in your case, I do not know.
On 12 Mar 2005 20:45:31 GMT, "TeGGer®" <tegger@istop.c0m> wrote:
[color=blue]
>[color=green]
>> 1/2", back in 1/4".
>>[/color]
>fling the door open. Whether it will work in your case, I do not know.[/color]
I'll try it with the old door when I get some time. Sounds like it
just might work. The logic is quite sound.
[color=blue]
> right.
>[/color]
Hook a chain around it to the bumper of a Tundra, stab the throttle till
its squared up.
The Second Amendment Is Americas "Original" Homeland Security!
On Thu, 17 Mar 2005 03:39:27 GMT, MDT Tech®
<liberals_are@lying_sax_shit.com> wrote:
[color=blue]
>[color=green]
>> right.
>>[/color]
>its squared up.[/color]
What a moronic idea. Of course, considering the source, I couldn't
expect much better. (Besides, the Cressida is much better built than
the new Tundra models so it'd likely just pull the bumper off.
Gary L. Burnore wrote:[color=blue]
>[/color]
Well, push the pile of shit over a cliff then.
On Fri, 18 Mar 2005 02:34:30 GMT, MDT Tech®
[color=blue]
>Gary L. Burnore wrote:[color=green]
>>[/color]
>Well, push the pile of shit over a cliff then.[/color]
I'd rather sell it. You can still get a good amount for a Tundra, even
with the bumper missing.
