'89 Corolla strange starting problem (?ignition ?starter) - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 13 Old 03-23-2005, 07:43 PM
jyang1@caregroup.harvard.edu
Guest
Posts: n/a
Quoted: Post(s)
Hi,
I have a carbureted '89 Corolla 4A-F with 138k miles. The car's in
great condition, runs great, and is meticulously maintained.
During this winter, maybe 20% of the time on some cold days (below
40F), when I turn the key to start the car, nothing happens (e.g,. as
if the battery were dead). Sometimes I hear the beginning of a crank
and then nothing happens. The next time I turn the key, the car always
starts strong and starts immediately. Humidity has no effect. This
never happens if the engine is warm.
The battery is strong-- the car's lights are always bright-- I've
tested the voltage multiple times and it's always good-- I replaced the
battery with a new one last month anyways. No difference, as I
expected. The battery connections also look good.
Spark plugs are 20k miles old; distributor cap/spark plug wires were
replaced 40k miles ago (OEM parts); starter is original.
I guess that something in the ignition system needs to be replaced, but
how do I diagnose the problem so that I know what to replace?
Thanks,
John
post #2 of 13 Old 03-23-2005, 08:40 PM
Gordo
Guest
Posts: n/a
Quoted: Post(s)
Re: '89 Corolla strange starting problem (?ignition ?starter)
<jyang1@caregroup.harvard.edu> wrote in message
news:1111625007.500918.264020@g14g2000cwa.googlegroups.com...[color=blue]
> Hi,
> Thanks,
> John
>[/color]
I will be watching this thread with interest. My '78 has the same symptoms.
I replaced the starter, battery and both neg and pos cables. I cleaned out
the neutral safety switch on the tranny. I suspect the ignition switch as
well, but will watch for advice from posters. John, next time it does this,
try boosting it and post results. For some reason mine fires up, but it
could be that I get the switch just right, or the moons are aligned right or
some other wierd reason. I do hear the selenoid click on mine, but it
doesn't turn over.
Gordo
post #3 of 13 Old 03-23-2005, 09:08 PM
tomcas
Guest
Posts: n/a
Quoted: Post(s)
[email]jyang1@caregroup.harvard.edu[/email] wrote:[color=blue]
> Hi,
> Thanks,
> John
>[/color]
Next time this happens have someone turn the key while you whack the
starter with a hammer. It seems like the starter contacts are worn.
post #4 of 13 Old 03-23-2005, 09:31 PM
Ray O
Guest
Posts: n/a
Quoted: Post(s)
> Hi,
> Thanks,
> John[/color]
Check for worn starter contacts. If you shop around, you may be able to
find a kit.
Ray O
correct the return address punctuation to reply
post #5 of 13 Old 03-23-2005, 10:23 PM
Gordo
Guest
Posts: n/a
Quoted: Post(s)
> >snip>> John[color=blue]
> find a kit.
> Ray O
>[/color]
Would the extra juice from an extra battery overcome bad contacts? A local
shop was supposed to replace the contacts, but I am second guessing the work
now. My click-click-click from the starter does sound like bad contacts,
doesn't it?
post #6 of 13 Old 03-23-2005, 10:25 PM
Scott in Florida
Guest
Posts: n/a
Quoted: Post(s)
On Thu, 24 Mar 2005 03:23:13 GMT, "Gordo" <woodbug1@hotmail.com>
wrote:
[color=blue][color=green][color=darkred]
>> >snip>> John[/color]
>> find a kit.
>> Ray O
>>[/color]
>doesn't it?
>[/color]
That sure was the problem on my '92 Corolla...
Scott in Florida
post #7 of 13 Old 03-23-2005, 11:17 PM
Ray O
Guest
Posts: n/a
Quoted: Post(s)
"Gordo" <woodbug1@hotmail.com> wrote in message
news:Boq0e.763276$Xk.412112@pd7tw3no...[color=blue][color=green][color=darkred]
>> >snip>> John[/color]
>> find a kit.
>> Ray O
>>[/color]
> local
> work
> doesn't it?
>[/color]
Yes, extra juice from a jump can overcome marginal contacts. Other things
can cause the clicking noise so the contacts should be checked before just
going ahead and changing them out.
Ray O
post #8 of 13 Old 03-24-2005, 06:39 AM
tomcas
Guest
Posts: n/a
Quoted: Post(s)
Gordo wrote:[color=blue][color=green][color=darkred]
>>>snip>> John[/color]
>>find a kit.
>>Ray O
>>[/color]
> Would the extra juice from an extra battery overcome bad contacts?[/color]
No.
A local[color=blue]
> doesn't it?
>[/color]
post #9 of 13 Old 03-24-2005, 03:42 PM
Guest
Posts: n/a
Quoted: Post(s)
Hey Gordo,
I have a portable jump starter, but the car always starts immediately
on 2nd turn of the key, and the battery's voltage is good, so I suspect
it's not a voltage issue. If it were to not start on the 2nd try, then
I'd boost it, though suspect it wouldn't help, since the lights/etc are
bright and the voltage is good.
--John[color=blue][color=green]
> > 40F), when I turn the key to start the car, nothing happens (e.g,.[/color][/color]
as[color=blue][color=green]
> > if the battery were dead). Sometimes I hear the beginning of a[/color][/color]
crank[color=blue][color=green]
> > and then nothing happens. The next time I turn the key, the car[/color][/color]
always[color=blue][color=green]
> > starts strong and starts immediately. Humidity has no effect.[/color][/color]
This[color=blue][color=green]
> > The battery is strong-- the car's lights are always bright-- >[/color]
> I will be watching this thread with interest. My '78 has the same[/color]
symptoms.[color=blue]
> I replaced the starter, battery and both neg and pos cables. I[/color]
cleaned out[color=blue]
> the neutral safety switch on the tranny. I suspect the ignition[/color]
switch as[color=blue]
> well, but will watch for advice from posters. John, next time it[/color]
does this,[color=blue]
> try boosting it and post results. For some reason mine fires up, but[/color]
it[color=blue]
> could be that I get the switch just right, or the moons are aligned[/color]
right or[color=blue]
> some other wierd reason. I do hear the selenoid click on mine, but[/color]
it[color=blue]
> doesn't turn over.
> Gordo[/color]
post #10 of 13 Old 03-24-2005, 04:25 PM
Gordo
Guest
Posts: n/a
Quoted: Post(s)
Strange, eh? Mine won't start on the second try. Sometimes has to sit for
a bit, then it runs fine for another month, when it decides to not start
again. This is almost leading into a temperamental wife/husband story, but
that is best left alone ;)
Does your starter click? Mine does, so I think the switch is OK, unless
there is a second contact in the switch that is bad.
You could always move south?
Gordo
news:1111696965.094940.186850@l41g2000cwc.googlegroups.com...[color=blue]
> Hey Gordo,
> --John[color=green][color=darkred]
> as[color=green][color=darkred]
> crank[color=green][color=darkred]
> always[color=green][color=darkred]
> This[color=green][color=darkred]
> symptoms.[color=green]
> cleaned out[color=green]
> switch as[color=green]
> does this,[color=green]
> it[color=green]
> right or[color=green]
> it[color=green]
> > doesn't turn over.
> > Gordo[/color]
>[/color]
post #11 of 13 Old 03-24-2005, 05:16 PM
kgold
Guest
Posts: n/a
Quoted: Post(s)
[email]jyang1@caregroup.harvard.edu[/email] writes:[color=blue]
> Hi,
> how do I diagnose the problem so that I know what to replace?[/color]
If nothing happens (no crank) I can't imagine it would be the ignition
system. This sounds like a failing (original) starter to me.
Ken Goldman [email]kgold@watson.ibm.com[/email] 914-784-7646
post #12 of 13 Old 03-24-2005, 07:00 PM
radarguy1@earthlink.net
Guest
Posts: n/a
Quoted: Post(s)
I agree with those that suggest the solenoid contacts. It is
basically a floating washer that shorts two contacts each 180 degrees
apart. The washer will tilt to a limit to account for wear since the
positive side erodes from ion movement. When the limit is approaching
you get intermittant starts and each time the solenoid is operated the
washer rotates to get relatively fresh contact points and wear the
washer evenly. When the tilt gets too much you have to do surgery.
I have had this happen on both my Hondas and Toyotas since I run them
into the 300 Kmiles. I was able to replace the soft copper contact
with a home made brass one that will outlast a replacement if you
could find it. The alternative is a new starter. The last time I
checked they were about $46 at Auto Zone with a lifetime warranty.
It was just quicker for me to make the contact than to drive to the
store.
Also remember to check all the connections and make sure they are
tight, both positive and grounds. Clean battery terminals. For those
less electrically knowledgable it is the current that starts the car
not the voltage. When you boost a car you are adding to the current
not the voltage. Voltage can travel through the weakest of contacts
but you have to have a lot of contact area to conduct the maximum
current. Larger wire means you can handle greater current.
Hope this helps.
Russ
On 23 Mar 2005 16:43:27 -0800, [email]jyang1@caregroup.harvard.edu[/email] wrote:
[color=blue]
>Hi,
>Thanks,
>John[/color]
post #13 of 13 Old 03-24-2005, 07:03 PM
Gary L. Burnore
Guest
Posts: n/a
Quoted: Post(s)
On Fri, 25 Mar 2005 00:00:02 GMT, [email]radarguy1@earthlink.net[/email] top posted
like a moron and wrote:
[color=blue]
>I agree with those that suggest the solenoid contacts.[/color]
What things do?
gburnore@databasix dot com
How you look depends on where you go.
Gary L. Burnore | ۳ݳ޳ݳۺݳ޳ݳݳ޳ݳ۳
| ۳ݳ޳ݳۺݳ޳ݳݳ޳ݳ۳
DataBasix | ۳ݳ޳ݳۺݳ޳ݳݳ޳ݳ۳
| ۳ 3 4 1 4 2 ݳ޳ 6 9 0 6 9 ۳
Black Helicopter Repair Svcs Division | Official Proof of Purchase
Want one? GET one! [url]http://signup.databasix.com[/url]
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota
Gear in this thread - Powered by O'Reilly Auto Parts
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
OR
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
User Tag List
Linear Mode Linear Mode
BB code is Off
Smilies are Off
[IMG] code is Off
