"Wayne" <wayne99@fastmail.fm> wrote in
news:1112560658.073817.77220@z14g2000cwz.googlegroups.com:
[color=blue]
> Can someone tell me which diagnostic terminals to jump for my 91
> Previa, and clue me in on a few of the common flash codes? Thanks!
>[/color]
The connector is under the driver's seat. Open it up and jump
terminals TE and E1 with a paper clip or something, turn the ignition on
then count the blinks from the Check Engine light.
For code definitions, try here:
[url]http://www.off-road.com/toyota/tech/codes/[/url]
Wayne wrote:[color=blue]
> Can someone clue me in on a few of the common (Previa) flash codes?[/color]
25, 26, and 27 are common ones that indicate problems with the oxygen
sensor. Usually it gets very slow to respond or just dies completely.
51 usually indicates the TPS wire harness right at the TPS connector is
broken. The wires usually don't look broken but the conductor(s)
inside the insulation will be broken and the insulation stretched.
OK, I get a double flash, pause, single flash. According to the
website that means 21, and my symptoms are consistant with code 21,
oxygen sensor. Heck, thats been bad for years!
My vehicle only has a few thousand miles left on it so I'm not going to
worry about it unless the dying gets worse. usually it only happens in
my driveway. Last time I priced sensors they were near $200, IIRC.
BTW, the oil light and overdrive also flashed single flashes, but I
presume those are meaningless.
> My vehicle only has a few thousand miles left on it so I'm not going[/color]
to[color=blue]
> worry about it unless the dying gets worse. usually it only happens[/color]
in[color=blue]
> Thanks![/color]
OK, I forgot about 21. It is frequently accompanied by 25 or 26 and 27
if the rear sensor is bad also. Kinda common.
Comboverfish wrote:[color=blue]
> Wayne wrote:[color=green]
> > My vehicle only has a few thousand miles left on it so I'm not[/color][/color]
going[color=blue]
> to[color=green]
> in[color=green]
> > my driveway. Last time I priced sensors they were near $200,[/color][/color]
IIRC.[color=blue][color=green]
> > BTW, the oil light and overdrive also flashed single flashes, but[/color][/color]
I[color=blue][color=green]
> > Thanks![/color]
> OK, I forgot about 21. It is frequently accompanied by 25 or 26 and[/color]
27[color=blue]
> Toyota MDT in MO[/color]
I now see that 21 isnt (necessarily?) the sensor, but could be
elsewhere in the circuit. Is there a particular place that problems are
known to develop? I'm no electrician but I can look for broken wires.
Does the 91 Previa have 2 sensors? I was only aware of the one near the
catalytic converter.
My 92 previa got 2 sensors, one in front, and one back of the catalytic
converter
"Wayne" <wayne99@fastmail.fm> a écrit dans le message de news:
[email]1112627732.588237.257150@g14g2000cwa.googlegroups.com[/email]...[color=blue]
> Comboverfish wrote:[color=green]
>> Wayne wrote:[color=darkred]
> going[color=green]
>> to[color=darkred]
>> in[color=darkred]
> IIRC.[color=green][color=darkred]
> I[color=green][color=darkred]
>> > Thanks![/color]
> 27[color=green]
>[/color]
oups wrote:[color=blue]
> My 92 previa got 2 sensors, one in front, and one back of the[/color]
catalytic[color=blue]
> converter[/color]
yeah, as soon as I posted that I crawled underneath and felt real dumb.
Doesnt matter anyway, frame will be rusted out within the year and its
been puttin' away just fine (except foe the occasional die) for years
even with a sensor problem.
