Re: Selecting Reverse 1995 Corolla
On Wed, 06 Apr 2005 02:15:07 +0000, W Alston wrote:
[color=blue]
> I've found its mainly when the gearbox has weight on it. When i let the
> handbreak out and roll forward a little it seems to slip in. (This is with
> the clutch in) I was just wondering is there anyway i can fix it so it goes
> straight in no mucking around.[/color]
I think you're stuck! Every single Toyota I have ever had has done this. I
never tried to look for a fix because some of them have gone well over
200,000 miles.
Try rolling the car forward a bit before shifting into reverse. This has
always worked for me. Try shifting into reverse gently and if it doesn't
go right off the bat, go into 1st and roll about an inch and try again.
Usually works for me.
[color=blue]
> "TeGGer®" <tegger@tegger.c0m> wrote in message
> news:Xns962FDF425DC37tegger@207.14.113.17...[color=green]
>> "Mr William Alston" <billalston@bigpond.com> wrote in
>> news:ogH4e.1422$5F3.522@news-server.bigpond.net.au:
>>[color=darkred]
>> > Does anyone have any suggestions to what may be causing a crunching[/color][/color]
> noise[color=green][color=darkred]
>> > when selection reverse (manual gearbox).
>> >[/color]
>> 1) You're shifting into reverse too fast or too soon
>> 2) Car is moving when you select reverse
>> 3) Wrong oil in gearbox
>> 4) Gearbox oil is very cold
>> 5) Clutch misadjusted
>> 6) Friction disc binding on splines
>> Keeping the pedal down, select 4th, then neutral again, then try reverse.
>> Does it crunch now?
>> TeGGeR®
>>[/color][/color]
