Overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2005, 12:28 AM   #1 (permalink)
steves_mail@email.com
Guest
Posts: n/a
View steves_mail@email.com's Photo Gallery
Overheating
We just changed the engine in my 98 Camry. The new engine is a 97. It
sounds fine but the cooling fan will not come on and it overheats. The
relays and fuses are o.k. Everything got hooked back up o.k.
Old 04-06-2005, 02:32 PM   #2 (permalink)
Henry Kolesnik
Guest
Posts: n/a
View Henry Kolesnik's Photo Gallery
Re: Overheating
I assume its the engine overheating and not the cooling fan. Have you tried
jumping the fan motor with 12 volts to see if its OK. If its OK then there
might be a thermostat in the ciccuit that has gone bad.
73
Hank WD5JFR
<steves_mail@email.com> wrote in message
news:1112761711.609562.97880@g14g2000cwa.googlegroups.com...[color=blue]
>[/color]
Old 05-03-2005, 12:36 PM   #3 (permalink)
marvinshos@yahoo.com
Guest
Posts: n/a
View marvinshos@yahoo.com's Photo Gallery
Re: Overheating
If you pull the two wire connector off at the bottom of the radiator
the two fans should come on at full speed. If they do not come on there
are two relays in the engine compartment fuse box on the drivers side
that may be bad.
Henry Kolesnik wrote:[color=blue]
> I assume its the engine overheating and not the cooling fan. Have[/color]
you tried[color=blue]
> jumping the fan motor with 12 volts to see if its OK. If its OK then[/color]
there[color=blue]
> 73
> Hank WD5JFR
> news:1112761711.609562.97880@g14g2000cwa.googlegroups.com...[color=green]
> > We just changed the engine in my 98 Camry. The new engine is a 97.[/color][/color]
It[color=blue][color=green]
> > sounds fine but the cooling fan will not come on and it overheats.[/color][/color]
The[color=blue][color=green]
> >[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
