04 camry with oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2005, 02:38 PM   #1 (permalink)
engwar1@yahoo.com
Guest
Posts: n/a
View engwar1@yahoo.com's Photo Gallery
We have a Camry that's about a year old (2004) and we're getting drips
of oil on our driveway.
Took it to the dealer. They said that Jiffy Lube (the only place we'd
had the oil changed) just hadn't cleaned the oil off of the bottom of
the car.
Took it back to Jiffy Lube and their story was that this was a problem
with Camrys of this year and that they didn't damage the vehicle when
changing the oil.
Took it back to the dealer. They said it appeared to be just residue on
the undercarriage of the car. I know this isn't the case as every
couple of days there's a new drip on the driveway.
Before I take it back to the dealer I'm curious as to whether anyone is
aware of an existing problem with this year of CAMRY.
I'm trying to determine if Jiffy Lube's story is bullsh*t or not. If
there is a history of trouble with this make/model then I want it fixed
under warranty. If not then I think Jiffy Lube should cover the repair
costs.
But right now the dealer hasn't pointed the finger at J-Lube yet, just
said it looked like residue on the undercarriage.
Any thoughts?
Old 04-06-2005, 03:06 PM   #2 (permalink)
Mark
Guest
Posts: n/a
View Mark's Photo Gallery
Re: 04 camry with oil leak
I would make sure that Jiffy Lube replaced the gasket between the drain
plug and the pan, and that the drain plug is reasonably tight. My
Honda dealer neglected to fully tighten the plug on the family CR-V the
last time the oil was changed and made a mess on my driveway, for which
they were suitably chastised, to the tune of a free oil change.
Mark
Old 04-06-2005, 09:41 PM   #3 (permalink)
Steve Henderson
Guest
Posts: n/a
View Steve Henderson's Photo Gallery
Mark wrote:[color=blue]
> Mark
>[/color]
I have to ask specifically for the quick-lube places to catch / clean
the area around my oil filter on my '02 Avalon, or I have the same
problem after every oil change. The filter is horizontal, so it
naturally leaks some oil when it's removed. If they don't put something
there to soak it up, or clean it after the job is done, I always have
some drips for a few days. Just ask them to clean up after themselves
(they all have a pressure washer around), and you'll be fine, methinks.
I also have an 04 Camry, and haven't noticed it. It's probably
determined by who does the work, and how careful they are.
Old 04-06-2005, 09:54 PM   #4 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
There are no oil leak problem on Toyota. Iffy lub is really risky for
service. The filter they installed cost them less than .25. Have your car
steam cleaned and see where its leaking or if still leaking. If you insist
dealer look at it they should charge a diagonstic fee if it isn't a warrrant
covered leak.
<engwar1@yahoo.com> wrote in message
news:1112812709.700802.31790@z14g2000cwz.googlegroups.com...[color=blue]
> the car.
> changing the oil.
> costs.
> Any thoughts?
>[/color]
Old 04-07-2005, 08:51 AM   #5 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
I agree. The problem is with Jiffy Lube, not Toyota.
On the Camry, I change my own oil - don't like anyone else to touch the
car.
On my 1977 Toyota pick up truck, I have had a quick lube place change
the oil, simply because I don't want to mess with it, and they have the
pressurized grease gun for the zerk fittings on the control arms (which
I always have to point out the upper joints so they're not overlooked).
When I had the clutch replaced, it took the owner of the transmission
shop around half an hour with a chisel and torch to remove the
transmission fill plug which had been ridiculously over tightened (by
others).
Also, I carry a supply of oil drain plug gaskets for the quick lube
place, because if they don't change it each time, it drips.
BB code is Off
Smilies are Off
[IMG] code is Off
