22RE - problem - H2O in #2 cylnder and oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2005, 10:54 PM   #1 (permalink)
frankzao
Guest
Posts: n/a
View frankzao's Photo Gallery
Has any one had this problem and know how to fix it or what is going
on?
I’ve got a 92 pickup with a 22RE motor. I just rebuilt the entire
motor (bearings pistons chain head etc). I started the rebuild b/c I
was getting H2O out the tail pipe from what I thought was a blown
headgasket. I had everything redone and tested; ei the block and head
and valves. Now it is all back together and I have the SAME
problem........ It is running great no CEL, idles perfect, just I’m
getting coolant into the exhaust.
any ideas????????
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-22RE-problem-H2O-cylnder-oil-ftopict117490.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=570061[/url]
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
[url]http://www.usenet.com[/url]
Old 04-26-2005, 11:07 PM   #2 (permalink)
Andrew Stephenson
Guest
Posts: n/a
View Andrew Stephenson's Photo Gallery
Re: 22RE - problem - H2O in #2 cylnder and oil
In article <1_570061_99dad883bf12a3344d73efe59ec498f6@autoforumz.com>
[email]UseLinkToEmail@AutoForumz.com[/email] "frankzao" writes:
[color=blue]
> [water coming out of tailpipe]
> any ideas????????[/color]
This sounds normal. Combustion produces water, along with those
more notorious products. It dribbles out of most exhausts, until
they become hot enough that it emerges as invisible steam. HTH.
(BTW, one reason why short trips encourage corrosion back there.)
Andrew Stephenson
Old 04-26-2005, 11:38 PM   #3 (permalink)
TeGGeR®
Guest
Posts: n/a
View TeGGeR®'s Photo Gallery
[email]ames@deltrak.demon.co.uk[/email] (Andrew Stephenson) wrote in
news:1114571231snz@deltrak.demon.co.uk:
[color=blue]
>[color=green]
>[/color]
Except that our young feller says:
"...I’m getting coolant into the exhaust."
This appears to mean he's getting much more than just water.
TeGGeR®
Old 04-27-2005, 12:28 AM   #4 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
"TeGGeR®" <tegger@tegger.c0m> wrote:
[color=blue]
>ames@deltrak.demon.co.uk (Andrew Stephenson) wrote in
>[color=green]
>>[color=darkred]
>>[/color]
>This appears to mean he's getting much more than just water.[/color]
Perhaps he just thinks it's coolant (unless his coolant IS just
water?)
He DOES call it H2O, doesn't he? (sounds like water to me)
-Gord.
"I'm trying to get as old as I can,
and it must be working 'cause I'm
the oldest now that I've ever been"
Old 04-27-2005, 01:09 AM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"frankzao" <UseLinkToEmail@AutoForumz.com> wrote in message
news:1_570061_99dad883bf12a3344d73efe59ec498f6@autoforumz.com...[color=blue]
> on?
> I've got a 92 pickup with a 22RE motor. I just rebuilt the entire
> problem........ It is running great no CEL, idles perfect, just I'm
> any ideas????????
>[/color]
When you originally pulled the head, did the HG show signs of leaking? How
were the block and head tested?
Were the tops of the pistons real clean? Was there coolant in the oil or
vice versa before the rebuild or now? Are coolant and engine oil levels
going up or down before the rebuild or now? If you pull the plugs, can you
smell coolant on any of them? Have you run the engine long enough after the
rebuild to get rid of any residual coolant in the exhaust?
Ray O
correct the return address punctuation to reply
Old 04-27-2005, 12:37 PM   #6 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Water in the cylinder and the oil is a sign of a blown head gasket. You
should have overheating problems too. If you don't have overheating problems
now, you will soon.
If you get water out the tail pipe on initial start up in the morning, or
anytime of day, then this is condensation that is being blown out. This is
not a problem.
I replied to the Subject line, then read the entire post. I see no reference
in your post to water in the engine or the oil, it's just in the exhaust
pipe as far as I can see. If this is accurate, then you have no worries,
except that the condensation in the exhaust system can cause you to need new
exhaust parts soon. I suspect you have leaks in it already, but that is
another topic.
> on?
> any ideas????????
>[/color]
Old 04-27-2005, 12:39 PM   #7 (permalink)
Jeff Strickland
Guest
Posts: n/a
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns9644F05619D86tegger@207.14.113.17...[color=blue]
>[color=green]
> >[color=darkred]
> >[/color]
> "...I'm getting coolant into the exhaust."
>[/color]
He said "coolant", but we can't really tell if he knows it is coolant or if
it is normal water vapor that comes out when a cold engine is started.
Old 04-27-2005, 03:53 PM   #8 (permalink)
Gord Beaman
Guest
Posts: n/a
"Jeff Strickland" <spamcatcher@yahoo.net> wrote:
snip
[color=blue]
>[/color]
OR... maybe his coolant IS water?...
--Gord
(use gordon in email)
"Without detonation, your car won't
move. That's what makes engines go".
"In my car, the high octane fuel detonates
better than the lower octane grades.
Fortunately for me, it doesn't PREVENT DETONATION".
-Burnore.
[color=blue]
>Yes, Detonation is a normal condition and
>it occurs every time you have ignition,[/color]
-Josh
Old 04-27-2005, 04:34 PM   #9 (permalink)
Jeff Strickland
Guest
Posts: n/a
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:a9rv61pm06rnhm440i2339c1hq7q1oaeph@4ax.com...[color=blue]
> snip
>[color=green]
> >He said "coolant", but we can't really tell if he knows it is coolant or[/color][/color]
if[color=blue][color=green]
> >[/color]
>[/color]
Well, while that is entirely possible, I suspect it is not true. Isn't
straight water in an aluminum engine a bad thing?
I suspect he is seeing normal condensation coming out of the tail pipe on
start up. I hope not, because he rebuilt the engine because of it, but based
on what we know so far, this is my guess and I'm sticking to it.
Old 04-27-2005, 05:48 PM   #10 (permalink)
Gord Beaman
Guest
Posts: n/a
[color=blue]
>news:a9rv61pm06rnhm440i2339c1hq7q1oaeph@4ax.com...[color=green]
>> snip
>>[color=darkred]
>if[color=green][color=darkred]
>> >[/color]
>>[/color]
>[/color]
That's my gut feeling too...
-Gord.
Old 04-27-2005, 06:19 PM   #11 (permalink)
Andrew Stephenson
Guest
Posts: n/a
In article <H5adnamnrfyjXfLfRVn-tg@ez2.net>
[email]spamcatcher@yahoo.net[/email] "Jeff Strickland" writes:
[color=blue]
> news:Xns9644F05619D86tegger@207.14.113.17...[color=green]
> >[color=darkred]
> > >> any ideas????????
> > > they become hot enough that it emerges as invisible steam. HTH.[/color]
> > "...I'm getting coolant into the exhaust."[/color]
> coolant or if it is normal water vapor that comes out when a
> cold engine is started.[/color]
You're right; he did; zot. My apologies if I set the dogs on the
wrong scent trail.
Andrew Stephenson
Old 04-27-2005, 07:05 PM   #12 (permalink)
Ray O
Guest
Posts: n/a
news:842071d0nflteritidanrm9o1e78lmor55@4ax.com...[color=blue]
>[color=green]
>>news:a9rv61pm06rnhm440i2339c1hq7q1oaeph@4ax.com...[color=darkred]
>>> snip
>>> >or[/color]
>>if[color=darkred]
>>>[/color]
>>based
>>[/color]
> -Gord.
>[/color]
I got the impression that the OP rebuilt the engine himself. After all, how
may people would pay to rebuild an engine that old? Assuming that the OP
rebuilt the engine him or herself, how many people who are that mechanically
inclined don't know the difference between normal condensation in the
exhaust and coolant? That's like saying a guy who built his house with his
own hands doesn't know the difference between a drywall and wood screw.
Ray O
Old 04-27-2005, 08:31 PM   #13 (permalink)
Gord Beaman
Guest
Posts: n/a
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote:
[color=blue]
>news:842071d0nflteritidanrm9o1e78lmor55@4ax.com...[color=green]
>>[color=darkred]
>>>> snip
>>>> >or
>>>if
>>>based
>>>[/color]
>> -Gord.
>>[/color]
>own hands doesn't know the difference between a drywall and wood screw.[/color]
Don't think so Ray...read his first post carefully, I think he
paid to have it done...not the brightest decision ever made by
mankind I'd say (if I'm right)
-Gord
"Old age is not for sissies"
-Art Linkletter(?)
Old 04-27-2005, 10:19 PM   #14 (permalink)
TeGGeR®
Guest
Posts: n/a
Gord Beaman <gord@islandtelecom.com> wrote in
news:a9rv61pm06rnhm440i2339c1hq7q1oaeph@4ax.com:
[color=blue]
> snip
>[color=green]
>>or if it is normal water vapor that comes out when a cold engine is
>>started.
>>[/color]
>[/color]
OR... Maybe his coolant is akka-haul. :)
TeGGeR®
Old 04-27-2005, 11:45 PM   #15 (permalink)
Ray O
Guest
Posts: n/a
news:lcb071l5m3eh9jvcu6mmchoqigiuj4s5en@4ax.com...[color=blue]
>[color=green]
>>news:842071d0nflteritidanrm9o1e78lmor55@4ax.com...[color=darkred]
>>>>> snip
>>>>> >or
>>>>if
>>>>> >started.
>>>>on
>>>>based
>>> -Gord.
>>>[/color]
>>how
>>mechanically
>>his
> -Gord
>[/color]
I've lost the first post. Anyone that would pay to overhaul an engine that
old probably wouldn't know the difference between coolant and water. Of
course, someone accepting money for the job might not be the most scrupulous
tech out there so who knows if the work was even done?
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
