Compression test values too high - 1991 Toyota Tercel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2005, 01:09 PM   #1 (permalink)
Daniel Beardsley
Guest
Posts: n/a
View Daniel  Beardsley's Photo Gallery
1991 Toyota Tercel
Ok, I've done a compression test several times on this car in the last
week or two and I'm getting numbers that are way too high. I'm doing
it properly from what I can tell, but I must be missing something. I'm
getting between 190 and 200 PSI, which means a compression ratio of
about 13-13.5:1 which is obviously wrong.
I just replaced the head gasket and the car runs absolutely fine. I
get the car warmed up, I remove all the spark plugs, unplug the fuel
injectors, screw in the tester and crank it over for 10 seconds or so.
The compression tester lurches a bunch and the gauge goes up every
compression stroke, it slows down around 190-200 and doesn't go up much
higher. The only thing I can imagine is that fuel is getting into the
cylinder and dieseling. I don't know what to think really. I've
tested the compression tester with my air compressor and it reads
correctly (+/- 3 PSI).
Old 04-30-2005, 04:23 PM   #2 (permalink)
Jirí Lejsek
Guest
Posts: n/a
View Jirí Lejsek's Photo Gallery
Re: Compression test values too high - 1991 Toyota Tercel
These values are absolutely OK for motor in good condition. It is caused by
velocity of air which is a little compressed even in bottom dead center.
My english is a little poor so somebody may explain it better.
J. Lejsek
"Daniel Beardsley" <dbeardsl@gmail.com> píse v diskusním príspevku
news:1114880981.664294.119120@o13g2000cwo.googlegroups.com...[color=blue]
> 1991 Toyota Tercel
>[/color]
Old 04-30-2005, 05:32 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Daniel Beardsley" <dbeardsl@gmail.com> wrote in message
> 1991 Toyota Tercel
>[/color]
Pressures sound about right - correct range is probably around 80 to 215
PSI. More important is the difference between cylinders, which should not
exceed 15 PSI.
Ray O
correct the return address punctuation to reply
Old 04-30-2005, 06:13 PM   #4 (permalink)
Josh
Guest
Posts: n/a
View Josh's Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote in message
news:1bfcf$4273fa8a$180fead6$23206@msgid.meganewsservers.com...[color=blue]
> news:1114880981.664294.119120@o13g2000cwo.googlegroups.com...[color=green]
> > 1991 Toyota Tercel
> >[/color]
> exceed 15 PSI.[/color]
You mean 180? I think also the difference is not so much PSI, but more like
10% between the highest and lowest rating?
I'm not sure what this engine specs are, it does have a specific compression
rating, you will have to look this up. If it is high than you most likely
have some carbon build up. You can remove carbon with water injection or a
product called Seafoam which works really well. Being that the car is 15
years old that's probably the cause.
If you use the Seafoam just feed it into the throttle body with a spray
bottle, or let it suck it out of the bottom half of a styrofoam cup using a
vacuum line to the TB. This will produce a LOT of white smoke, so beware.
Some people also feed the Seafoam into the cylinder, install the plugs and
crank the engine a few times, let it sit for 30 minutes and start the car.
Old 04-30-2005, 07:59 PM   #5 (permalink)
Danny Beardsley
Guest
Posts: n/a
View Danny Beardsley's Photo Gallery
I just rebuilt the engine and removed the carbon buildup in the
process. The compression ratio is supposed to be 9:1 and the Chiltons
manual says a brand new engine should get about 140 -150psi.. so yeah,
it's too high.
Old 04-30-2005, 08:02 PM   #6 (permalink)
Danny Beardsley
Guest
Posts: n/a
Interesting theory, that hadn't occrured to me. Though I don't think
that the air could be compressed that much in bottom dead center, but
your theory sounds the best so far... Except that I've done
compression tests on other cars and they always come out normal (100 -
130 psi), i.e. close to their designed compression ratios.
Old 04-30-2005, 09:43 PM   #7 (permalink)
Josh
Guest
Posts: n/a
"Danny Beardsley" <dbeardsl@gmail.com> wrote in message
news:1114905585.608374.27320@f14g2000cwb.googlegroups.com...[color=blue]
> it's too high.[/color]
What exactly did you 'rebuild'? As far as somebody suggesting velocity of
the air, I highly doubt that has anything to do with it.
Old 05-01-2005, 12:12 AM   #8 (permalink)
Philip
Guest
Posts: n/a
View Philip's Photo Gallery
Danny Beardsley wrote:[color=blue]
> 130 psi), i.e. close to their designed compression ratios.[/color]
Air in the cylinder is NOT pressurized at BDC. In fact, at cranking speeds,
you have no compression until the piston moves up the cylinder sufficient to
close the intake valve. Now ... if you have your valve timing off a tooth
where the intake is closing very shortly aft BDC, then cranking compression
will be higher than normal. Normal cranking compression with the throttle
OPEN is often in the 140 to 180 psi range. Closed throttle perhaps 30 psi
less.
Old 05-01-2005, 03:06 PM   #9 (permalink)
Danny Beardsley
Guest
Posts: n/a
I didn't rebuild the whole engine, but I did completely tear apart the
head and replaced all gaskets and seals (head gasket, valve stem oil
seals, intake gasket, exhaust gasket, ...) While I had the head off I
removed the carbon on the head and on top of each piston.
Old 05-01-2005, 06:34 PM   #10 (permalink)
noneyabusiness
Guest
Posts: n/a
View noneyabusiness's Photo Gallery
On 30 Apr 2005 10:09:41 -0700, "Daniel Beardsley"
<dbeardsl@gmail.com> wrote:
[color=blue]
>1991 Toyota Tercel
>correctly (+/- 3 PSI).[/color]
Are you sure your calculations for the ratio are correct?
Does it seem to have a lot more power than before the rebuild? <g>
What octane gas are you running?
If you use the lowest available does it ping a lot?
Old 05-01-2005, 07:08 PM   #11 (permalink)
Danny Beardsley
Guest
Posts: n/a
I don't see why they wouldn't be correct, unless "compression ratio"
doesn't really mean what I think it means.
It runs a tad better, but not enough to justify the compression I'm
seeing, 13:1 is akin to putting a turbo on.
I'm using 87 regular. No, it sounds/runs beautifully.
Old 05-01-2005, 11:18 PM   #12 (permalink)
Ray O
Guest
Posts: n/a
"Josh" <nobody@noplacenowhere.never> wrote in message
news:NIGcnfIXUejPn-nfUSdV9g@ptd.net...[color=blue]
> news:1bfcf$4273fa8a$180fead6$23206@msgid.meganewsservers.com...[color=green]
>> news:1114880981.664294.119120@o13g2000cwo.googlegroups.com...[color=darkred]
>> > 1991 Toyota Tercel
>> >[/color]
>> not
> like
> 10% between the highest and lowest rating?[/color]
Oops, typo - I meant to say 180. The problem with using a percentage
difference between the highest and lowest rating is that the allowable
difference varies with compression. 10% is a fair rule of thumb, 5 to 10
PSI difference is acceptable, 15 PSI difference is at the high end of
aceptable, whether it is a high compresison engine or not.
[color=blue]
> compression
> years old that's probably the cause.[/color]
Since the OP replaced the head gasket, I would hope that whoever did the
work would not put it back together with a heavy crbon buildup on the
pistons or valves.[color=blue]
>[/color]
Ray O
Old 05-01-2005, 11:21 PM   #13 (permalink)
Ray O
Guest
Posts: n/a
"Philip" <1chip-state1@earthlink.n0t> wrote in message
news:VGYce.2383$7F4.66@newsread2.news.atl.earthlink.net...[color=blue]
> Danny Beardsley wrote:[color=green]
> speeds, you have no compression until the piston moves up the cylinder
> sufficient to close the intake valve. Now ... if you have your valve
> timing off a tooth where the intake is closing very shortly aft BDC, then
> cranking compression will be higher than normal. Normal cranking
> compression with the throttle OPEN is often in the 140 to 180 psi range.
> Closed throttle perhaps 30 psi less.
>[/color]
Did someone machine the heads or did you use a non-OEM head gasket? Either
could account for higher compression.
If the engine runs properly without pinging, performance is good, and you do
not have excessive difference in compression between cylinders, I'd say
drive it.
Ray O
Old 05-02-2005, 01:42 AM   #14 (permalink)
noneyabusiness
Guest
Posts: n/a
On 1 May 2005 16:08:04 -0700, "Danny Beardsley" <dbeardsl@gmail.com>
wrote:
[color=blue]
>doesn't really mean what I think it means.[/color]
I only asked because I am ignorant of how to get the compression ratio
from the PSI produced in a cylinder.
[color=blue]
>seeing, 13:1 is akin to putting a turbo on.[/color]
Or using the wrong gasket <g>
(Can you actually get a change of 4 or 5 to 1 from a gasket??!)
[color=blue]
>I'm using 87 regular. No, it sounds/runs beautifully.[/color]
Then as someone else suggested: Just drive it!
Seriously, if you had 13:1 ratio it should ping like hell on 87 octane
(Does a 91 Tercel have a knock sensor?).
In any event, good luck with the rebuilt engine.
Old 05-02-2005, 01:00 PM   #15 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
You are doing something wrong, but the good news is you are doing the same
thing worng repeatedly and the test results are that all cylinders are
within as narrow range, and this is good.
> 1991 Toyota Tercel
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
