98 4runner rear seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2005, 04:48 PM   #1 (permalink)
Stude
Guest
Posts: n/a
View Stude's Photo Gallery
New to this group-- with a question. My wife's 98 4runner rear axle
started leaking on the passenger side yesterday. I usually do my own
maintenance and wonder if anyone can tell me how hard a job it is to
pull the axle and install a new seal and bearing if needed? Also
noticed a lot of pressure in the rear end when I opened the filler plug
to check fluid level. Is that normal?
Thanks ----
Old 05-23-2005, 06:39 AM   #2 (permalink)
Qslim
Guest
Posts: n/a
View Qslim's Photo Gallery
Re: 98 4runner rear seal
If the seal isn't leaking alot, you may be able to get away with just
removing the axle and replacing the seal. It's something you can probably do
with a basic set of hand tools, but you'll also need something to drive the
new axle seal into the housing. If the seal is leaking enough to where the
shoes are soaked, you will need to replace those, and if it's gotten to that
point you can bet alot of the grease has been washed out of the bearing, so
you will have trouble with that in the future.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
[url]http://www.usenet.com[/url]
BB code is Off
Smilies are Off
[IMG] code is Off
