Re: 81 Corolla won't start, diagnose electrical problem, how?
"travis" <travis.1pglbx@no-mx.forums.yourdomain.com.au> wrote in message
news:travis.1pglbx@no-mx.forums.yourdomain.com.au...[color=blue]
> When I tried to start my car one morning smoke came from under the
> dashboard and the starter motor didn't turn. Now the car turns on, all
> of the dashboard lights light up, the radio plays, etc. but there is no
> activity or sound from the starter motor. How do I diagnose this?
> I was thinking of checking the starter solenoid wire for 12V when the
> ignition key is in the 'start' position. If there's no voltage there,
> where else should I look?
>[/color]
If you check the starter solenoid wire and there is no voltage, check fuses,
circuit breakers, and fusible links.
[color=blue]
> If smoke came from under the dash, is it possible that the wire from
> the key to the starter solenoid smoked and I can just replace it with a
> wire I run myself? I looked under the dash and inside the steering
> column housing, but I didn't see any bad, discolored wires anywhere.
> Any suggestions appreciated,
> Travis
>[/color]
To check if a wire is open, use a continuity tester. If a wire is burned or
broken and has is open, replace the wire with one of the same gauge.
Ray O
correct the return address punctuation to reply
