Re: 2004 Corolla rear view mirror
On Mon, 23 May 2005 17:57:27 +0000, Gord Beaman wrote:
[color=blue]
> Rob wrote:
>[color=green]
>>My daughter's corolla has a rear view mirror (has reading lights built
>>in) that seems to vibrate (when looking into it as I drive the car at
>>30 mph or so) a bit too much. When I touch it, it seems like the
>>whole assembly is pretty tight but the mirror just vibrates enough to
>>make you eyes dizzy or annoyed if you have to stare into it as you
>>drive.
>>I was looking as the assembly and I don't see any adjustment to
>>tighten it nor to wedge anything. Is there anything I can do to try
>>to tighten it (the mirror portion) just a tad? Is a replacement the
>>only option and if so, do you know the cost for the mirror part or the
>>whole assembly?[/color]
> Sounds like it's resonant to a particular vibration in the
> vehicle which is being coupled into the mirror...(that's called
> sympathetic vibration).
> If you can get at the back of the mirror you might try gluing
> something heavy to it, that should change it's resonant
> point..luck helps in finding just where to affix the weight...[/color]
I'll bet she just needs to cut the Subwoofers back a scosche...
