O/D OFF Light Flashing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2005, 11:57 AM   #1 (permalink)
Marty
Guest
Posts: n/a
View Marty's Photo Gallery
Does anyone know why my 1990 4Runner's overdrive off light would be
flashing? Where would I get the error code if there is one? My Haynes
manual only talks about the engine light error codes. Thanks.
Old 05-24-2005, 05:32 PM   #2 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: O/D OFF Light Flashing
When it flashes, it is telling you the transmission isn't happy. If you are
lucky, it means you need to add some fluid.
"Marty" <marc.baril@absu.accenture.com> wrote in message
news:1116950231.602197.24900@f14g2000cwb.googlegroups.com...[color=blue]
>[/color]
Old 05-24-2005, 06:20 PM   #3 (permalink)
Gary L. Burnore
Guest
Posts: n/a
View Gary L. Burnore's Photo Gallery
On 24 May 2005 08:57:11 -0700, "Marty" <marc.baril@absu.accenture.com>
wrote:
[color=blue]
>manual only talks about the engine light error codes. Thanks.[/color]
There's a connector under the hood that a dealer or shop can use to
test your system. You can do this to check it:
Turn the key OFF.
Get a paper clip or small wire and jumper between E1 and Te1. Turn
the key to the on (but not start or run) position. Make sure OD is on
and not off.
Count the flashes. There's a space of 1 second between parts of a
number and a space of 1.5 seconds between each numbert.
Example:
Flash -sec- Flash -sec- Flash -sec- Flash -sec -flash -sec- Flash -
1.5 sec
That's a 6.
Write the numbers down. Let us know what they say.
To reset your computer (this will erase your radio presets) remove
the negative battery cable for several minutes. (Five is good).
Re-attach the neg cable and start/drive your car. See if the light
flashes again.
gburnore@databasix dot com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
DataBasix | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ³ 3 4 1 4 2 ݳ޳ 6 9 0 6 9 ÝÛ³
Black Helicopter Repair Svcs Division | Official Proof of Purchase
Want one? GET one! [url]http://signup.databasix.com[/url]
Old 05-24-2005, 07:29 PM   #4 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
On Tue, 24 May 2005 18:20:01 -0400, Gary L. Burnore wrote:
[color=blue]
> wrote:
>[color=green]
> Turn the key OFF.
> and not off.
> Example:
> 1.5 sec
> That's a 6.
> flashes again.[/color]
He can unplug the computer itself.
The Relentless Pursuit Of Conception...
Old 05-24-2005, 08:29 PM   #5 (permalink)
Jeff Strickland
Guest
Posts: n/a
"hachiroku" <Trueno@ae86.gts> wrote in message
news:2NOke.20$Tm3.12@trndny09...[color=blue]
>[color=green]
> > wrote:
> >[color=darkred]
> > Turn the key OFF.
> > and not off.
> > Example:
> > 1.5 sec
> > That's a 6.
>[/color]
Yes, he can. But the first thing to do is the simple stuff, check the fluid
level. Low fluid can make the OD Light flash. Let me say that another way,
low fluid can make one of the transmission lights flash, I seem to recall
that it's the OD light.
Old 05-25-2005, 12:17 AM   #6 (permalink)
Marty
Guest
Posts: n/a
The flashes were 2 seconds apart indefinitely . I unplugged the
battery and it didn't stop it then I unplugged the battery for 15
minutes and it seems do have stopped. Fluid levels were fine. Thanks
everyone.
Old 05-25-2005, 12:23 AM   #7 (permalink)
Gary L. Burnore
Guest
Posts: n/a
On 24 May 2005 21:17:26 -0700, "Marty" <marc.baril@absu.accenture.com>
wrote:
[color=blue]
>The flashes were 2 seconds apart indefinitely .[/color]
Two doesnt' sound right, but if it stopped...
[color=blue]
>I unplugged the battery and it didn't stop it then I unplugged the battery for 15
>everyone.[/color]
It may return. If it does, do the jumper test.
Old 05-25-2005, 04:32 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Jeff Strickland" <spamcatcher@yahoo.net> wrote in message
news:c4CdndRT6twQAA7fRVn-1g@ez2.net...[color=blue]
> are
>[/color]
The ECT in the OP's vehicle does not monitor ATF levels.
Ray O
correct the return address punctuation to reply
Old 05-25-2005, 05:54 PM   #9 (permalink)
hachiroku
Guest
Posts: n/a
On Tue, 24 May 2005 17:29:55 -0700, Jeff Strickland wrote:
[color=blue]
> news:2NOke.20$Tm3.12@trndny09...[color=green]
>>[color=darkred]
>> > Turn the key OFF.
>> > and not off.
>> > Example:
>> > 1.5 sec
>> > That's a 6.
>>[/color]
> that it's the OD light.[/color]
OK, smart@ss, explain this! ;)
Supra; when I got it the O/D Off light was flashing, the tranny wouldn't
shift automatically but will go through the gears (except OD) when shifted
manually.
I removed the plug and tested it. (BTW, I was getting codes 61 & 62; S1
bad, S2 bad). I checked them with a meter; SL was OK, S1 open, S2 open. I
filled the tranny and the computer reset when I removed the plug. Also,
applying 12V to the connectors, the SL solenoid tripped, but S1 and S2 did
not. I borrowed the Dealer's plate for a weekend; NO O/D Light flashing;
ALSO no automatic shifting or O/D function!!!
What's up with that?
Old 05-25-2005, 06:34 PM   #10 (permalink)
Gary L. Burnore
Guest
Posts: n/a
On Wed, 25 May 2005 15:32:09 -0500, "Ray O"
<rokigawa@tristarassociatesDOT.com> wrote:
[color=blue]
>news:c4CdndRT6twQAA7fRVn-1g@ez2.net...[color=green]
>> are
>>[/color]
>The ECT in the OP's vehicle does not monitor ATF levels.[/color]
Neither does mine. :(
Old 05-25-2005, 06:57 PM   #11 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
Gary L. Burnore, 5/24/2005, 6:20:01 PM, wrote:
[color=blue]
> wrote:
>[color=green]
> > Haynes manual only talks about the engine light error codes.
> > Thanks.[/color]
> Turn the key OFF.
> and not off.
> Example:
> 1.5 sec
> That's a 6.
This is a very informative and helpful post. Thanks for your insight.
No matter what happens someone will find a way to take it too seriously.
Old 05-26-2005, 01:34 PM   #12 (permalink)
Marty
Guest
Posts: n/a
Gary, the flashing is back! What do you mean by E1 and Te1? I have a
Chilton manual in the mail so maybe I will soon be enlightened.
Old 05-26-2005, 03:49 PM   #13 (permalink)
Ray O
Guest
Posts: n/a
Look for a diagnostic check port under the driver's side of the dash board.
Look at the underside of the cap covering the port and there will be a
sticker that identifies the various pins in the connector. Use a paperclip
or piece of wire to connect pin E1 and Te1, then turn the ignition key to
the on position without starting the car. The OD off light will begin
flashing. The number of flashes corresponds with the trouble code. A
steady flash is normal, a series of quick flashes with pauses between them
denotes trouble codes.
Ray O
Ray Okigawa
TriStar Associates L.L.C.
Phone: 847-690-0910 Extension 17
Fax: 847-690-0916
[email]rokigawa@tristarassociates.com[/email]
news:1117128844.865301.111280@g44g2000cwa.googlegroups.com...[color=blue]
>[/color]
Old 05-30-2005, 03:11 PM   #14 (permalink)
Marty
Guest
Posts: n/a
I could not find this port. There is nothing near my fuse box with pin
holes or a cover. Only the spare fuses beside the fuse box. Am I
blind?
BB code is Off
Smilies are Off
[IMG] code is Off
