new stainless steel rotors for Camry, now takes longer to stop
Thanks for the advice from this group regarding tips on rotor replacement.
Pretty straight forward except for the two caliper torque plate bolts on the
right side that were a bitch to back out. 1/2" drive breaker bar, won't
budge. 4' cheater bar, still won't budge. Finally back out after a minute
each with an impact wrench. No problem backing out the bolts on the left
rotor, go figure.
Anyway, replaced the front factory warped rotors at less than 40K miles on
wife's V6 Camry with Raybestos PG Plus stainless rotors (actually its plated
stainless) along with Raybestos Quiet Stop pads. The pulsation is gone and
replaced with very smooth stops - nice. Wife said it now takes longer to
stop. Anyone experienced with stainless steel rotors and care to comment?
Re: new stainless steel rotors for Camry, now takes longer to stop
"Fred" <xyz@abc.qed> wrote in message
news:Tr2dnU6M0PJcyzvfRVn-2g@comcast.com...[color=blue]
> the right side that were a bitch to back out. 1/2" drive breaker bar,
> won't budge. 4' cheater bar, still won't budge. Finally back out after a
> minute each with an impact wrench. No problem backing out the bolts on the
> left rotor, go figure.
> plated stainless) along with Raybestos Quiet Stop pads. The pulsation is
> gone and replaced with very smooth stops - nice. Wife said it now takes
> longer to stop. Anyone experienced with stainless steel rotors and care to
> comment?[/color]
Lots of motorcycle experience. There is less friction with SS compared to
cast iron. Bikes have SS rotors for street use and aftermarket manufacturers
make rustable replacements for racers and performance addicts.
> Pretty straight forward except for the two caliper torque plate bolts on[/color]
the[color=blue]
> rotor, go figure.
> wife's V6 Camry with Raybestos PG Plus stainless rotors (actually its[/color]
plated[color=blue]
> stop. Anyone experienced with stainless steel rotors and care to comment?[/color]
It's all in the pads. You bought a 'quite' pad which is probably a softer
pad, meaning it will wear fast, your rotor wont and stopping time may be
slower. A harder pad wont wear as fast but will eat up the rotor quicker,
and get you harder breaking. The other thing to note is that there is an
oilish film on new rotors which may take a bit to wear off. It's a good idea
to spray new Rotors down with a brake cleaner.
A Carbon Kevlar pad is harder but more rotor friendly than other pads.
Porterfield's or Axxis Metal Masters are good choices in pads. Upgrading
your brake lines to SS brake lines will also help performance.
Josh wrote:[color=blue]
> your brake lines to SS brake lines will also help performance.[/color]
?? I must say that in my experience with bike discs the softer the pad
the better the braking, and by far, but the faster the pad wear. Also
harder pads squeel more. This held true with my last car (a peugeot).
"Coyoteboy" <coyoteboyuk@hotmail.com> wrote in message
news:1118227129.099570.22830@g49g2000cwa.googlegroups.com...[color=blue]
> Josh wrote:[color=green]
> > It's all in the pads. You bought a 'quite' pad which is probably a[/color][/color]
softer[color=blue][color=green]
> > slower. A harder pad wont wear as fast but will eat up the rotor[/color][/color]
quicker,[color=blue][color=green]
> > oilish film on new rotors which may take a bit to wear off. It's a good[/color][/color]
idea[color=blue][color=green]
> harder pads squeel more. This held true with my last car (a peugeot).[/color]
<IleneDover@mailcity.com> wrote in message
news:42A6FC45.B53AFEBF@mailcity.com...[color=blue]
> That is because stainless steel does not dissipate heat nearly as
> quickly as does iron. You need different pads to compensate
> mike hunt
>[/color]
I couldn't find any reference to pad/stainless rotor combinations. Do you
know which pads to use?
[color=blue]
> Fred wrote:[color=green]
>> stop. Anyone experienced with stainless steel rotors and care to comment?[/color][/color]
news:Q4-dnUk4E6zWuzrfRVn-rQ@comcast.com...[color=blue]
> news:42A6FC45.B53AFEBF@mailcity.com...[color=green]
> > mike hunt
> >[/color]
> know which pads to use?[/color]
"Josh" <nobody@noplacenowhere.never> wrote in message
news:QzmdnYYYH-9TtDrfUSdV9g@ptd.net...[color=blue]
> news:Q4-dnUk4E6zWuzrfRVn-rQ@comcast.com...[color=green]
>> news:42A6FC45.B53AFEBF@mailcity.com...[color=darkred]
>> > mike hunt
>> >[/color]
> A carbon/kevlar/ceramic pad.
>[/color]
Raybestos Quiet Stop pads used on the stainless rotor is ceramic. Don't know
anything about carbon or kevlar.
If it were me looking I would search the wed site of the rotor
manufactures for the correct pad application.
mike hunt
Fred wrote:[color=blue]
> > mike hunt
> >[/color]
>[color=green]
> > Fred wrote:[color=darkred]
> >> stop. Anyone experienced with stainless steel rotors and care to comment?[/color][/color][/color]
<MajorDomo@mailcity.com> wrote in message
news:42A761D5.E3C795F6@mailcity.com...[color=blue]
> mike hunt
>[/color]
If it were me, I'd use OEM pads and rotors and be done with it.
Ray O
correct the return address punctuation to reply
On Wed, 08 Jun 2005 16:44:12 -0500, Ray O wrote:
[color=blue]
> news:42A761D5.E3C795F6@mailcity.com...[color=green]
>> mike hunt
>>[/color]
> If it were me, I'd use OEM pads and rotors and be done with it.[/color]
On Wed, 08 Jun 2005 13:27:58 -0400, Josh wrote:
[color=blue]
>> > mike hunt
>> >[/color]
> A carbon/kevlar/ceramic pad.[/color]
Sounds expensive to me. Are we running at Monte Carlo this weekend?
"hachiroku" <Trueno@ae86.gts> wrote in message
news:_4Lpe.2571$2H2.1329@trndny08...[color=blue]
>[color=green]
>> news:42A761D5.E3C795F6@mailcity.com...[color=darkred]
>>> mike hunt
>>>[/color]
> Probably much cheaper?
> The Relentless Pursuit Of Conception...
>[/color]
Aftermarket might be cheaper initially, but by the time you're done with the
ceramic/kevlar wunderstuff that everyone is recommending so that the OP's
Camry will stop, you would have spent a lot more money. Aftermarket pads
can be a PITA (as opposed to PETA) to install and in my experience, parts
stores give you the wrong part half the time, where a dealer parts
department gets it right most of the time.
A friend always uses aftermarket pads and rotors, and whenever I change pads
on his Camry it takes me 45 minutes to an hour or more where I can do them
on the Avalon in less than half an hour with OEM parts. It might be my
snobby pro-OEM parts attitude but I like OEM brake parts.
Ray O
> What was the pad material?
On the bikes - various,i couldnt be precise but visually similar pad
material with varying surface hardnesses-notably a few different grades
of EBC pads.
I also assume its similar on bike rim-brakes - magura HS33 hydraulic
rim brakes i had ran two types of pad material for normal use - red and
black. Reds weres soft, stopped faster and wore out at about twice the
rate.
I'm presuming there is FAR more to it than just pad hardness, as two
similarly hard materials can have totally different friction
co-efficients.
