97 camry problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2005, 12:36 PM   #1 (permalink)
twostepbec
Guest
Posts: n/a
View twostepbec's Photo Gallery
97 camry problem
my 97 camry feels like it is studdering when i push on the gas peddle.
i thought it was maybe bad gas at first, so i ran down the tank,
re-filled and she was fine for about a week until she started
studdering again. And this morning on the way to work, the check
engine light came on. has this happened to anyone? and ideas on what
it could be?
thanks!
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-97-camry-problem-ftopict123929.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=603343[/url]
Old 06-10-2005, 02:30 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 97 camry problem
"twostepbec" <UseLinkToEmail@AutoForumz.com> wrote in message
news:1_603343_3bffa0465b930757f57da8027cc52fb2@autoforumz.com...[color=blue]
> it could be?
> thanks!
>[/color]
Most of the responses you receive to your post will be uneducated guesses.
The purpose of the check engine light is to tell the operator that (a)
something has malfunctioned and (b) that a trouble code is probably stored
in the electronic control unit. My recommendation is that you scan the
trouble codes in the ECU and then you will have a starting point as to the
cause of the condition.
Many auto parts stores will lend you the scanner at no charge or you can
purchase a basic OBD II scanner for less than $150.00. If you get a
trouble code for an O2 sensor and you have a V6 engine, I'd check the sensor
closest to the firewall first.
Ray O
correct the return address punctuation to reply
BB code is Off
Smilies are Off
[IMG] code is Off
