Need some assistance here, folks... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2005, 10:07 AM   #1 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
The Chrysler A/C is dead. Last fall it was making noises like marbles
rattling around in a coffee can.
I'm HOPING it is just low on gas. I want to get a can of R-134 (about a
LB) and put it in the system. I did this with my 'hachiroku', added 4 lbs
(what the 'spec' said) and it ran for two weeks before blowing the
compressor. Oops, it's only a 2.4 LB system!!! (can't remember where I got
the spec, but I guess it was wrong, eh?)
I want to add the gas slowly until (hopefully) the compressor kicks on. I
will probably have to add some oil to the system, too.
I am ASSUMING you add the gas to the High side, with the system on (????)
I don't have a manifold with guages or anything. Even with my employee
discount, it is STILL too much ($125) to spend for a system that may not
be working at all. One of the techs suggested the R-134 in a can.
Any kind of 'procedure' for this Gumby method would be appreciated. Thanks!
Old 06-12-2005, 11:44 AM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
Re: Need some assistance here, folks...
On Sun, 12 Jun 2005 14:07:36 +0000, Hachiroku wrote:
Never mind. A tech gave me instructions, said if there wasn't enough
refrigerant the compressor wouldn't turn on. Filled the system...still
didn't turn on. Crap...
[color=blue]
> Any kind of 'procedure' for this Gumby method would be appreciated. Thanks![/color]
Old 06-12-2005, 02:36 PM   #3 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
"Hachiroku" wrote:[color=blue]
> marbles
> (about a
> added 4 lbs
> the
> where I got
> kicks on. I
> system on (????)
> employee
> that may not
> can.
If the compressor was growling and making noises it is likely shot
because that is the classic sounds thay make where at end of life
cycle and sometimes they lock up too. A over charge can cause noise to
but not like what you describe. I am sorry but I do not want to give
you false hope here that there is a quick cheap fix because there is
not based on what you posted.
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-assistance-folks-ftopict124198.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=604790[/url]
Old 06-12-2005, 03:43 PM   #4 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sun, 12 Jun 2005 14:07:36 GMT, Hachiroku <Trueno@ae86.gts> wrote:
[color=blue]
>be working at all. One of the techs suggested the R-134 in a can.[/color]
No, no, no! You add to the LOW side. The big hose coming back from
the evaporator core. If you try adding to the high side (and the hose
kit is too cheap to have a check valve in it) the can will end up in
low earth orbit next to Sputnik. That is, unless you are standing in
the way at the moment it decides to launch...
And get the can with the gauge on the hose - when you hook it up you
do want to see some residual pressure in the system, even if it's not
enough for it to run. If it comes up Zero pressure (or even a vacuum)
you may have bigger problems, like a leak that's big enough to need
fixing. You can try filling it and see what happens...
The gauge will tell you roughly when it's full enough. And realize
that if the system has leaked out the compressor oil charge somehow,
it will blow up not long after putting it back in service. Just like
running your engine with no oil - doesn't matter how full the radiator
is.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 06-12-2005, 07:12 PM   #5 (permalink)
Liberals are the parasites of society
Guest
Posts: n/a
View Liberals are the parasites of society's Photo Gallery
Hachiroku wrote:[color=blue]
> I am ASSUMING you add the gas to the High side, with the system on (????)[/color]
Add it to the low side. Not the high!
[url]http://www.rightwingstuff.com[/url]
[url]http://www.gop.org[/url]
[url]http://www.townhall.com[/url]
The Second Amendment Is Americas "Original" Homeland Security!
[url]http://www.nra.org[/url]
[url]http://www.nraila.com[/url]
Old 06-12-2005, 09:45 PM   #6 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
On Sun, 12 Jun 2005 14:36:43 -0400, SnoMan wrote:
[color=blue]
> "Hachiroku" wrote:[color=green]
> > marbles
> > (about a
> > added 4 lbs
> > the
> > where I got
> > kicks on. I
> > system on (????)
> > employee
> > that may not
> > can.
> not based on what you posted.[/color]
Not a problem...I was hoping but realized that it was probably too late.
Sometimes I luck out, but not often enough...
Thanks anyway!
The Relentless Pursuit Of Conception...
Old 06-13-2005, 12:19 AM   #7 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"hachiroku" <Trueno@ae86.gts> wrote in message
news:gy5re.804$aR1.531@trndny02...[color=blue]
> On Sun, 12 Jun 2005 19:43:51 +0000, Bruce L. Bergman wrote:
>[color=green]
>>[color=darkred]
>>>got
>> the way at the moment it decides to launch...[/color]
> Thankfully, the kit came with instructions, the guy at AutoZone was
> actually knowledgable, and the compressor was marked with caps marked "H"
> & "L". No Sputniks today, thank you!!
>[color=green]
>> fixing. You can try filling it and see what happens...[/color]
> Well, there was some residual pressue so the system was not totally empty.
> But, the compressor never did kick on. New compressor time? Hmmm...$235
> for a (flaky) rebuilt one...
>[/color]
Hachi-San,
Check to see if you have power to the compressor - if not, check fuses,
circuit breakers, relays, fusible links, controls, pressure switches, etc.
If you have power to the compressor, then the compressor clutch is probably
shot.
Ray O
correct the return address punctuation to reply
Old 06-13-2005, 02:36 AM   #8 (permalink)
SnoMan
Guest
Posts: n/a
Re: Re: Need some assistance here, folks...
>Never mind. A tech gave me instructions, said if there wasn’t
>enough
>refrigerant the compressor wouldn’t turn on. Filled the
>system...still
>didn’t turn on. Crap...
>[/color]
Look for another "tech" because he gave you bad advise. If it was
grinding and growling it is shot and more or new refrigerant is just
wasted money at this stage because it will not quiet or "fix" a worn
out compressor. If you had not mentioned the noise before failure I
would have said check charge but it is pointless with a noisy
compressor.
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=604980[/url]
Old 06-13-2005, 12:49 PM   #9 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On Mon, 13 Jun 2005 01:44:44 GMT, hachiroku <Trueno@ae86.gts> wrote:
[color=blue]
>for a (flaky) rebuilt one...[/color]
Before you panic, trace through the electrical circuits and see
where you do or do not get power. It goes through (not necessarily in
this order...) the clutch to ground, but you follow the line from the
clutch back and you have a fuse for the clutch, and a low-pressure
switch on the low-side line (empty system cut-off) before you get back
to the controls on the dash.
And at the dashboard you have the temperature control slider circuit
and the "AC Amplifier" sensing the core temperature to keep the
evaporator core from icing over.
Buy one of the line techs a six-pack and have him trace that through
- and watch him do it. Troubleshooting is all in being methodical.
--<< Bruce >>--
Old 06-13-2005, 04:35 PM   #10 (permalink)
SnoMan
Guest
Posts: n/a
"Bruce L. Bergman" wrote:[color=blue]
>wrote:
>[color=green]
>>Well, there was some residual pressue so the system was not[/color]
>totally empty.[color=green]
>>But, the compressor never did kick on. New compressor time?[/color]
>Hmmm...5[color=green]
>where you do or do not get power. It goes through (not necessarily[/color]
in[color=blue]
>switch on the low-side line (empty system cut-off) before you get[/color]
back[color=blue]
> And at the dashboard you have the temperature control slider[/color]
circuit[color=blue]
> Buy one of the line techs a six-pack and have him trace that[/color]
through[color=blue]
> --<< Bruce >>--[/color]
Why are you doing all of this for NOISY compressor that sounded really
bad before it quit working???? It is not like it was working fine on
day nice a quiet and suddenly quit!! You have him looking for the
wrong fix. He needs to replace compressor and drier, vac system and
recharge and THEN it should work but it is very pointless to try to
run a compressor that was very noisy before it quit working. (Read
orginal post)
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=605639[/url]
Old 06-15-2005, 07:20 PM   #11 (permalink)
hachiroku
Guest
Posts: n/a
On Sun, 12 Jun 2005 23:19:48 -0500, Ray O wrote:
[color=blue]
> news:gy5re.804$aR1.531@trndny02...[color=green]
>>[color=darkred]
>>>>got
>>[color=darkred]
>>[/color]
> Hachi-San,[/color]
Hahahaha! Hachi-San! I like it! Kenichi-wa!
[color=blue]
> shot.[/color]
Old 06-15-2005, 07:21 PM   #12 (permalink)
hachiroku
Guest
Posts: n/a
On Mon, 13 Jun 2005 02:36:29 -0400, SnoMan wrote:
[color=blue]
>>enough
>>system...still
>>[/color]
> compressor.[/color]
But I did have one smooth out once just by adding Freon. Once. A long
time ago...in a galaxy far far away...
Old 06-15-2005, 09:28 PM   #13 (permalink)
Merritt Mullen
Guest
Posts: n/a
View Merritt Mullen's Photo Gallery
In article <DI2se.9420$Nx1.1902@trndny05>, hachiroku <Trueno@ae86.gts>
wrote:
[color=blue]
> Hahahaha! Hachi-San! I like it! Kenichi-wa![/color]
That should be "Konichi-wa", boy-san.
<grin>
Merritt
Old 06-15-2005, 09:35 PM   #14 (permalink)
SnoMan
Guest
Posts: n/a
Re: Re: Re: Need some assistance here, folks...
"hachiroku" wrote:[color=blue]
>long
>[/color]
Yes, long long ago. Freon will not fix it now sad to say based on your
observations.
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=607508[/url]
Old 06-15-2005, 11:18 PM   #15 (permalink)
hachiroku
Guest
Posts: n/a
On Thu, 16 Jun 2005 01:28:01 +0000, Merritt Mullen wrote:
[color=blue]
> wrote:
>[color=green]
> <grin>
> Merritt[/color]
Watch it, or I'll set my keyboard to Traditional Japanese
(some may remember about a year ago, I did this by accident and about 1/3
of the group couldn't read my posts...)
BB code is Off
Smilies are Off
[IMG] code is Off
