1997 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-14-2005, 06:50 PM   #1 (permalink)
Brian Dickinson
Guest
Posts: n/a
View Brian Dickinson's Photo Gallery
1997 corolla
I am trying to replace a brake light in my wife's car.
I removed the 2 screws( nuts) visible on out side houseing, I then
opened the trunk and removed the trunk lining, and finally I removed
the brass nut in the center of the housing. Light assembly still will
not slide off. I noticed 2 black "plugs" that move when I move the
housing, but I can not find a way to removed the plugs !!! HELP !!
Old 06-14-2005, 07:06 PM   #2 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
Re: 1997 corolla
On Tue, 14 Jun 2005 19:50:41 -0400, Brian Dickinson
<briandickinson@sympatico.ca> wrote:
[color=blue]
>housing, but I can not find a way to removed the plugs !!! HELP !![/color]
As I recall you pull it to the side and it slides off...
You have to put a bit of muscle in it...
Scott in Florida
Old 06-14-2005, 07:10 PM   #3 (permalink)
Learning Richard
Guest
Posts: n/a
View Learning Richard's Photo Gallery
Re: 1997 corolla
Scott in Florida wrote:[color=blue]
>[color=green]
>[/color]
I got 'em off by using a shop rag, and a flathead as a lever... gently
pried until they popped out. Those two pins snap in.
[color=blue]
> Scott in Florida[/color]
Old 06-14-2005, 09:20 PM   #4 (permalink)
Learning Richard
Guest
Posts: n/a
Re: 1997 corolla
Learning Richard wrote:[color=blue]
> Scott in Florida wrote:[color=green]
> >[color=darkred]
> >[/color]
>[/color]
Oh yeah... forgot to mention, if the assembly is the same as my '95
(and it looks like it is, though they swapped the turn signal lens),
you need to put the shop rag btw the taillight assembly and the car,
and pry it on the side... the light backs straight out. Those two pins
you see inside the car are perp. to the actual pins on the light
assembly... the pins on the assembly itself are male.
[color=blue][color=green]
> > Scott in Florida[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
