OT: A Toyota related question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2005, 10:27 AM   #1 (permalink)
Johnny
Guest
Posts: n/a
View Johnny's Photo Gallery
If a recently recharged air conditioning system loses it's cooling ability,
what it's the most likely cause?
If a leak, then where's the most likely place for it to leak?
Could it be the compressor? Although it works for a few weeks after the
recharge.
The dealer has had the car and filled it with ultra violet dye, but could
not find any leaks.
Any ideas?
Sorry for the rare/unusual post about a Toyota vehicle in this Toyota
newsgroup rather than the popular topics about Bush.
Old 06-18-2005, 10:40 AM   #2 (permalink)
Josh
Guest
Posts: n/a
View Josh's Photo Gallery
Re: A Toyota related question
"Johnny" <n@spam.com> wrote in message
news:42b43d6f$1_2@mk-nntp-2.news.uk.tiscali.com...[color=blue]
> If a recently recharged air conditioning system loses it's cooling[/color]
ability,[color=blue]
> recharge.
> not find any leaks.
> Any ideas?
> newsgroup rather than the popular topics about Bush.[/color]
Either a leak or the compressor, and since no leaks were detected then my
best guess is the compressor.
Old 06-18-2005, 01:56 PM   #3 (permalink)
Johnny
Guest
Posts: n/a
"Josh" <nobody@noplacenowhere.never> wrote in message
news:5OicnQQx0eWO3SnfUSdV9g@ptd.net...[color=blue]
> news:42b43d6f$1_2@mk-nntp-2.news.uk.tiscali.com...[color=green]
> ability,[color=green]
>> recharge.
>> not find any leaks.
>> Any ideas?
>[/color]
Surely the compressor works (as it does so for a few weeks after a recharge)
Or can the compressor leak? and why wasn't this discovered?
Old 06-18-2005, 09:34 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> ability, what it's the most likely cause?
> recharge.
> not find any leaks.
> Any ideas?
If the AC system was properly evacuated and refilled with the proper
quantity of the proper refrigerant and system oil and a dye, and if the
system is leaking, then the dye should be visible under an ultraviolet
light.
Assuming that the dealer checked the compressor, evaporator, receiver drier,
and hoses for leaks and none were visible, then the leak may be in an area
that is not readily visible, like between the condenser and radiator,
under/back side of a hose, or the evaporator, which is under the dash. In
order to use the UV light method of finding leaks, you have to put the
vehicle on a lift so you can check the bottoms of the condenser and
compressor.
The next step is to try to find the leak with an electronic leak detector.
The most common areas where refrigerant leaks occur are the condenser and
compressor.
Ray O
correct the return address punctuation to reply
Old 06-19-2005, 06:18 AM   #5 (permalink)
Johnny
Guest
Posts: n/a
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote in message
news:c8b0f$42b4dbbe$180fead6$22469@msgid.meganewsservers.com...[color=blue]
>> recharge.
>> not find any leaks.
>> Any ideas?
> light.
> drier, and hoses for leaks and none were visible, then the leak may be in
> an area that is not readily visible, like between the condenser and
> radiator, under/back side of a hose, or the evaporator, which is under the
> dash. In order to use the UV light method of finding leaks, you have to
> put the vehicle on a lift so you can check the bottoms of the condenser
> and compressor.
> compressor.
> --[/color]
Cheers, the car will be taken do a company that deals with AC systems.
Not sure if I'll allow this muppet dealership do anything other than
standard servicing - they changed the cambelt 4 months ago and didn't change
the tensioner, and recently the tensioner failed....useless. They've
actually had the car twice filled with ultraviolet dye and twice failed to
find anything.
Old 06-19-2005, 01:55 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:42b55496$1_4@mk-nntp-2.news.uk.tiscali.com...[color=blue]
> news:c8b0f$42b4dbbe$180fead6$22469@msgid.meganewsservers.com...[color=green]
>> news:42b43d6f$1_2@mk-nntp-2.news.uk.tiscali.com...[color=darkred]
>>> recharge.
>>> could not find any leaks.
>>> Any ideas?
>> light.
>> the dash. In order to use the UV light method of finding leaks, you have
>> to put the vehicle on a lift so you can check the bottoms of the
>> condenser and compressor.
>> detector.
>> compressor.
>> --[/color]
> change the tensioner, and recently the tensioner failed....useless.
> They've actually had the car twice filled with ultraviolet dye and twice
> failed to find anything.[/color]
If the dealership has checked all of the visible areas, then the leak is in
an invisible area like the evaporator.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
