Rear brake problem "94 Corolla. Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2005, 06:40 PM   #1 (permalink)
Bill
Guest
Posts: n/a
View Bill's Photo Gallery
Hello:
I'm finishing a replacement of rear brake hoses, cylinders, shoes and drums
on my '94 Corolla. I can't seem to get the drums on now without a lot of
force. I don't want to keep banging them on and cause damage to the shoes
or the wheel studs or the drums. It looks like the shoes are on correctly
(on the anchor and in the cylinder) and the adjuster is seated at it's
lowest point, parking brake is off. The drums go over the shoes about 1/3
of the way with some banging and then stop. The Toyota manual says put the
drum on and work the parking brake handle and then take the drum off and
measure the clearance between drum and shoes and then put it back on and
bleed the system. I can't do that at this point. I could use some help and
it would be appreciated.
Thanks,
Bill
Old 06-18-2005, 07:19 PM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Rear brake problem "94 Corolla. Help
On Sat, 18 Jun 2005 23:40:45 +0000, Bill wrote:
[color=blue]
> Hello:
> Thanks,
> Bill[/color]
Well, I'm a Backyard Gumby, so I just bang 'em on. Obviously you have
checked the clearacnes and that the shoes are seated properly and not
canted one way or the other.
New drums w new shoes can be a bitch to put on. I see the guys n the shop
banging them on with a rubber hammer.
Old 06-18-2005, 10:03 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Bill" <concan@nowhere.com> wrote in message
news:Xns9679C82EE4D57p9e36jx@216.168.3.50...[color=blue]
> Hello:
> drums
> the
> Thanks,
> Bill[/color]
You did do one side at a time so you can compare with the other, right?
Are you sure that the adjuster is fully retracted and no threads are
visible?
Are the cylinders fully retracted?
Are the shoes and drums OEM or aftermarket?
Are the shoes oriented properly (leading and trailing)?
Is the parking brake handle and cable fully retracted (off)?
Is the hold down spring seated properly?
Ray O
correct the return address punctuation to reply
Old 06-19-2005, 12:10 AM   #4 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sat, 18 Jun 2005 23:40:45 -0000, Bill <concan@nowhere.com> wrote:
[color=blue]
>it would be appreciated.[/color]
Well, if they are new drums, they shouldn't have a wear ridge on the
outer edge that can be getting in the way.
Did you compare all the new parts with the old parts closely to see
if they gave you a wrong part somewhere? Measure the drums - they
could have been bored undersized at the factory. Take the adjuster
apart to make sure the threads are clean and lubed, and it's really
cranked all the way in.
Could the drum be hanging up on something other than the shoes, like
the wheel studs or the axle center? There IS a logical reason why it
won't go together, it's all in finding it.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 06-19-2005, 09:46 AM   #5 (permalink)
Bill
Guest
Posts: n/a
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote in
news:5535c$42b4e264$180fead6$22738@msgid.meganewsservers.com:
[color=blue]
> news:Xns9679C82EE4D57p9e36jx@216.168.3.50...[color=green]
>> Hello:
>> drums
>> of force. I don't want to keep banging them on and cause damage to
>> the shoes or the wheel studs or the drums. It looks like the shoes
>> are on correctly (on the anchor and in the cylinder) and the adjuster
>> is seated at it's lowest point, parking brake is off. The drums go
>> over the shoes about 1/3 of the way with some banging and then stop.
>> and measure the clearance between drum and shoes and then put it back
>> on and bleed the system. I can't do that at this point. I could use
>> some help and it would be appreciated.
>> Thanks,
>> Bill[/color][/color]
[color=blue]
> right?[/color]
Yes, and I reassembled using the toyota diagram.
[color=blue]
> threads are visible?[/color]
No threads are visible, but this has taken the other side of the adjuster
out of it's rear base about 3/4". Is this normal?
[color=blue]
> Are the cylinders fully retracted?[/color]
The shoes are sitting is the cylinder notches and are fully inside the
boots.
[color=blue]
> Are the shoes and drums OEM or aftermarket?[/color]
Aftermarket. Auto Zone Valuecraft drums, Duralast shoes.
[color=blue]
> Are the shoes oriented properly (leading and trailing)?[/color]
When I took the new shoes out of the box I saw that there were two pairs
of identical shoes, so I just took a pair for each wheel, one for the
rear shoe and put the levers on it and used the other for the front shoe.
The toyota manual didn't say anything about specific shoe orientation.
[color=blue]
> Is the parking brake handle and cable fully retracted (off)?[/color]
The handle is all the way down but how can I make sure the cable is
retracted? I noticed I was not able to move the parking brake lever back
and forth at the wheel to check that the adjuster moves (in the manual).
I had a rough time connecting the parking brake cable, I may have pull it
out a ways.
[color=blue]
> Is the hold down spring seated properly?[/color]
Shoe springs look seated well.
Unfortunatly at the present time I can't afford toyota parts.
Old 06-19-2005, 10:04 AM   #6 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Sun, 19 Jun 2005 14:46:37 -0000, Bill <concan@nowhere.com> wrote:
[color=blue]
>[color=green]
>> news:Xns9679C82EE4D57p9e36jx@216.168.3.50...[color=darkred]
>>> Hello:
>>> drums
>>> Thanks,
>[color=green]
>> right?[/color]
>[color=green]
>[color=green]
>boots.
>[color=green]
>[color=green]
>[color=green]
>out a ways.
>[color=green]
>Unfortunatly at the present time I can't afford toyota parts.[/color]
I'd be willing to throw in a few bucks to help get OEM parts for
you...
Scott in Florida
Old 06-19-2005, 10:14 AM   #7 (permalink)
Bill
Guest
Posts: n/a
Bruce L. Bergman <blPYTHONbergman@earthlink.invalid> wrote in
news:61v9b1htrkfnjnluojb94ft8ladg6dqds9@4ax.com:
[color=blue]
>[color=green]
>>drums on my '94 Corolla. I can't seem to get the drums on now without
>>a lot of force. I don't want to keep banging them on and cause damage
>>to the shoes or the wheel studs or the drums. It looks like the shoes
>>The Toyota manual says put the drum on and work the parking brake
>>handle and then take the drum off and measure the clearance between
>>drum and shoes and then put it back on and bleed the system. I can't
>>do that at this point. I could use some help and it would be
> if they gave you a wrong part somewhere?[/color]
Shoes and hardware looked the same, I will compare the drums.
[color=blue]
> Measure the drums - they could have been bored undersized at the[/color]
factory.
I will try to measure them.
[color=blue]
> Take the adjuster apart to make sure the threads are clean and lubed,
> and it's really cranked all the way in.[/color]
I took the adjusters apart cleaned and lubed them.
[color=blue]
> the wheel studs or the axle center?[/color]
I really haven't been able to get the drum in that far.
[color=blue]
> There IS a logical reason why it won't go together, it's all in
> finding it.[/color]
I hope so.
Old 06-19-2005, 10:28 AM   #8 (permalink)
Bill
Guest
Posts: n/a
Scott in Florida <JustAsk@Florida.com> wrote in
news:ha2bb1pkqacam5bbcmjsdrtp3si579i0pu@4ax.com:
[color=blue]
>[color=green]
>>[color=darkred]
>>>> Hello:
>>>> and drums
>>>> shoes are on correctly (on the anchor and in the cylinder) and the
>>>> adjuster is seated at it's lowest point, parking brake is off. The
>>>> drums go over the shoes about 1/3 of the way with some banging and
>>>> off and measure the clearance between drum and shoes and then put
>>>> it back on and bleed the system. I can't do that at this point. I
>>>> could use some help and it would be appreciated.
>>>> Thanks,
>>>> Bill[/color]
> you...[/color]
That is a wonderful gesture. I would like to exhaust all possibilitys
with what I have first. I may get back to you on that. Thanks very much.
Old 06-19-2005, 02:46 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
news:Xns967A6DA0415B17p9e36jx@216.168.3.50...[color=blue]
>[color=green]
>>> Hello:
>>> drums
>>> Thanks,
>[color=green]
>> right?[/color]
>[color=green]
> out of it's rear base about 3/4". Is this normal?[/color]
I don't think so. You mentioned that you cleaned and lubed the adjuster -
is it oriented so that the star wheel is in front of the rubber adjusting
plug on the backing plate? When the drums are installed, you should be able
to pull the oval-shaped plug and get at the star wheel from the inboard side
of the backing plate. If not, then the adjusted is installed backwards -
fore-aft.
[color=blue]
>[color=green]
> boots.
>[color=green]
> Aftermarket. Auto Zone Valuecraft drums, Duralast shoes.[/color]
Use a ruler to measure the diameter of the replacement drums and the ones
you took off.
Measure the curvature of the replacement shoes and the ones you took off to
make sure they are an exact match.
[color=blue]
>[color=green]
>[/color]
There is a specific leading and trailing shoe, and I believe the adjusters
are specific left and right. The moving threaded part of the adjuster
should extend towards the rear of the vehicle.
[color=blue][color=green]
> out a ways.[/color]
If the parking brake cable is too tight, it will pull the shoes out. Back
off the parking brake adjuster if necessary. Peel back the boot over the
adjuster lever and make sure it it not all rusted.
[color=blue]
>[color=green]
Good luck!
Ray O
Old 06-19-2005, 03:08 PM   #10 (permalink)
Scott in Florida
Guest
Posts: n/a
On Sun, 19 Jun 2005 15:28:02 -0000, Bill <concan@nowhere.com> wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>>>>> Hello:
>>>>> and drums
>>>>> Thanks,
>>>>> Bill
>> you...[/color]
>with what I have first. I may get back to you on that. Thanks very much.[/color]
No problem. We all go thru times when the money gets tight.
Just say the word...
Scott in Florida
Old 06-19-2005, 04:17 PM   #11 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
On Sun, 19 Jun 2005 15:04:19 +0000, Scott in Florida wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>>>> Hello:
>>>> drums
>>>> Thanks,
>>>> Bill[/color]
>>[color=darkred]
>>> right?[/color]
>>[color=darkred]
>>[color=darkred]
>>boots.
>>[color=darkred]
>>[color=darkred]
>>[color=darkred]
>>out a ways.
>>[color=darkred]
> you...[/color]
Damn! All this time I've been scraping and scratching and all I had to do
was ask Uncle Scotty? DAMN!
Well, now that I know this, I want a stainless steel TRD exhaust, a new
A340 auto tranny for the Supra, some new seats for the Hachiroku, with an
engine overhaul and body work to boot.
DAMN!!!
Old 06-19-2005, 04:24 PM   #12 (permalink)
Scott in Florida
Guest
Posts: n/a
On Sun, 19 Jun 2005 21:17:05 GMT, hachiroku <hachiroku@Trueno.GTS>
wrote:
[color=blue]
>[/color]
>> you...[/color]
>DAMN!!![/color]
YOU have an unfair advantage....
You have a job at a Toy dealer.....
You don't 'need' any help...
We all have 'toys' we 'want'.....but we all don't have 'important'
things like brakes that we need....
You know I would help if you 'needed' it...
Scott in Florida
Old 06-20-2005, 08:16 PM   #13 (permalink)
Bill
Guest
Posts: n/a
news:feobb1pm5qis7g42k0pv9mtesun0hnk6bj@4ax.com:
[color=blue]
> On Sun, 19 Jun 2005 21:17:05 GMT, hachiroku[/color]
<hachiroku@Trueno.GTS>[color=blue]
> wrote:
>[color=green]
>>[/color]
>[/color]
I got the drums on finally. No Banging.
1) I had the adjusting lever stuck against the star wheel which
wouldn't let the adjuster set properly.
2 ) I did not have a proper tool to get the return spring on . A
long nose vise-grip locking pliers from Lowes helped with that.
Many thanks to those who gave suggestions you really helped me
out of a jam. The people that share their knowledge help to make
the Internet a great place.
Old 06-20-2005, 10:26 PM   #14 (permalink)
Ray O
Guest
Posts: n/a
news:Xns967BD85D1CE067p9e36jx@216.168.3.50...[color=blue]
>[color=green]
> <hachiroku@Trueno.GTS>[color=green]
>> wrote:
>>[color=darkred]
>>>[/color]
>>[/color]
> the Internet a great place.[/color]
Happy motoring!
Ray O
Old 06-21-2005, 06:30 PM   #15 (permalink)
hachiroku
Guest
Posts: n/a
On Sun, 19 Jun 2005 21:24:40 +0000, Scott in Florida wrote:
[color=blue]
> wrote:
>[color=green]
>>[/color]
>[color=green][color=darkred]
>>> you...[/color]
>>DAMN!!![/color]
> You know I would help if you 'needed' it...[/color]
Nah, I'd never ask. However, a few months ago...
I went by where I was working before this morning. They sold 3 cars in the
time I've been gone: 5-6 weeks (I can't remember...) One was a $300
Commission, one was $200, one was $250. That's $750. I've SPENT more than
that in the last 6 weeks!! (Mostly paying for Insurance before it got
cancelled...12 HOURS before it got cancelled! The last time it got
cancelled in February I DID miss the payment by 8 hours! The LAST payment
and they wouldn't accept the payment!)
BB code is Off
Smilies are Off
[IMG] code is Off
