Temperature related transmission whine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2005, 02:11 AM   #1 (permalink)
Dan
Guest
Posts: n/a
View Dan's Photo Gallery
I have a '95 Toyota Corolla GLI with a 4 speed automatic transmission.
Lately, it has developed a low pitched whine under load (acceleration,
climbing a hill), which I suspect is from the transmission.
The noise comes on at around 2200-2500 rpm, only at a certain
temperature range.
When the engine is cold, no noise.
After 20-25 minutes drive, noise appears, very audible.
With engine/tranny hot (after some 40-45 minutes drive), noise is gone.
Any help will be greately appreciated.
Old 06-19-2005, 01:50 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Temperature related transmission whine
"Dan" <drnwnr@hotmail.com> wrote in message
news:1119165105.573282.24570@f14g2000cwb.googlegroups.com...[color=blue]
> temperature range.
>[/color]
Was the transaxle, accessory drive belts, timing belt, etc. serviced
recently?
Check the transmission fluid and see if it looks red and is translucent or
is brown and smells burnt. If it is the latter, have the fluid replaced.
Noises are very difficult to diagnose without actually hearing them. My
recommendation is to have a pro ride with you to hear it.
Ray O
correct the return address punctuation to reply
Old 06-20-2005, 02:04 AM   #3 (permalink)
drnwnr@hotmail.com
Guest
Posts: n/a
View drnwnr@hotmail.com's Photo Gallery
None of the above servicing has been performed recently, but there was
some body repair after accident that caused damage in front. Tranny
fluid is ok. At the shop I've been told noise may come from one of the
accessories (water pump, alternator), but this doesn't make sense since
noise is there only under load.
Old 06-20-2005, 06:06 AM   #4 (permalink)
Stewart DIBBS
Guest
Posts: n/a
View Stewart DIBBS's Photo Gallery
news:1119251076.548740.195690@o13g2000cwo.googlegroups.com...[color=blue]
>... this doesn't make sense since noise is there only under load.[/color]
Actually, it makes very good sense. Alternators often whine under load, but
this is unlikely to be your problem. It could be the power steering pump
(check the level), or the cam belt tensioner bearing. At the very least the
various belts should be checked for wear and damage. Does your engine have a
two piece front pulley? If so it could be separating.
You say the trans fluid is OK. How do you know this?
Stewart DIBBS
Old 06-20-2005, 06:23 AM   #5 (permalink)
Dan
Guest
Posts: n/a
Can you explain why a belt tensioner or other accessory bearing may
whine only when accelerating or going uphill and not in idle?
What exactly is a "two piece front pulley"?
It's an automatic tranny, so it's easy to check fluid condition (with
dipstick).
Old 06-20-2005, 10:26 AM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:1119266607.156552.218080@z14g2000cwz.googlegroups.com...[color=blue]
> dipstick).
>[/color]
When accelerating or going uphill, the engine is producing more torque than
at idle.
Ray O
Old 06-20-2005, 02:35 PM   #7 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
"Dan" wrote:[color=blue]
>I have a ’95 Toyota Corolla GLI with a 4 speed automatic
>transmission.
>Lately, it has developed a low pitched whine under load[/color]
(acceleration,[color=blue]
>temperature range.
>gone.
>Any help will be greately appreciated.[/color]
Hard to be certain but it will be one of two things, the front pump or
the torque converter and in that order would be my guess.
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-Temperature-related-transmission-whine-ftopict125224.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=609874[/url]
Old 06-20-2005, 02:39 PM   #8 (permalink)
SnoMan
Guest
Posts: n/a
Re: Re: Temperature related transmission whine
"drnwnr" wrote:[color=blue]
>None of the above servicing has been performed recently, but there[/color]
was[color=blue]
>fluid is ok. At the shop I’ve been told noise may come from one
>of the
>accessories (water pump, alternator), but this doesn’t make
>sense since
Last winter a tranny of mine developed a slight noisy like this, it
was a GM 4L80E, (and the only tranny problem I have ever had in 30
plus years too) and they replaced the torque converter and the front
pump at no cost to me and said that they have had a few problem with
them. Tranny still worked fine and likley would have continued to work
too and it was not a loud noise either. Anyway after the parts change,
the noise was gone and has not returned.
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=610496[/url]
Old 06-21-2005, 01:35 AM   #9 (permalink)
Dan
Guest
Posts: n/a
I'm trying to figure out how (and if) a front collision could have
caused tranny damage like this. Before the accident there was no noise.
The transmission wasn't directly hit in the accident (radiator, bumper
and hood had to be replaced).
Could it be related to a slightly bent chassis or out of spec front
alignment?
Old 06-21-2005, 10:44 AM   #10 (permalink)
Ray O
Guest
Posts: n/a
news:1119335701.115263.237520@g47g2000cwa.googlegroups.com...[color=blue]
> alignment?
>[/color]
When you are looking for advice or information, you should include all the
facts up front so you don't get irrelevant information. Has the car been
fixed yet?
A slightly bent chassis our out-of-alignment condition is unlikely to cause
a transmission whine although either condition can cause premature or uneven
tire wear. A reputable body shop will check chassis and suspension
alignment during repair.
I don't remember the design of your particular car but the if one of the
half-shafts (driveshafts) has a center support bearing that is way out of
alignment, the bearing in it could make noises. A little bit of
mis-alignment on the support bearing shouldn't make noise.
It is possible that front-end damage could cause a power steering fluid
leak, or the power steering fluid could be a little low from seepage over
time. A low fluid level in your power steering reservoir will cause it to
make a moaning/whining sound.
An over-tightened belt can make the bearings in your air conditioner
compressor, power steering pump, and/or alternator wear more quickly, which
would make moaning/whining noises.
Noises are difficult to diagnose without hearing. I recommend that you take
the car for professional diagnosis.
Ray O
Old 06-21-2005, 02:39 PM   #11 (permalink)
Comboverfish
Guest
Posts: n/a
View Comboverfish's Photo Gallery
Ray O wrote:
[color=blue]
> fixed yet?[/color]
He did in another post. I suggested pinched trans cooler line(s).
That wasn't it. I was out of good ideas at that point.
[color=blue]
> alignment, the bearing in it could make noises.[/color]
They don't. The passenger axle is just a regular CV shaft but longer.
[color=blue]
> make a moaning/whining sound.[/color]
Yup.
[color=blue]
> would make moaning/whining noises.[/color]
Yup.
[color=blue]
> the car for professional diagnosis.[/color]
Yup.
Old 06-22-2005, 12:29 AM   #12 (permalink)
Ray O
Guest
Posts: n/a
"Comboverfish" <comboverfish@yahoo.com> wrote in message
news:1119382789.260729.285010@f14g2000cwb.googlegroups.com...[color=blue]
> Ray O wrote:
>[color=green]
>> the
>> fixed yet?[/color]
>[color=green]
>[color=green]
>> over
>> to
> Yup.
>[color=green]
>> which
> Yup.
>[color=green]
>> take
> Yup.
>[/color]
The Field Technical Specialist I used to work with at the S.F. Region was
hard of hearing, due to time spent in a foxhole at Guadalcanal. (He used to
joke about the irony of working for a Japanese company after surviving that
battle). This guy could fix anything but noises - he'd always say he didn't
hear anything.
Ray O
Old 07-01-2005, 06:43 AM   #13 (permalink)
Dan
Guest
Posts: n/a
Thanks all for the inputs.
Haven't found the noise source yet.
I've been at several shops and have been told that they don't know
where this noise is coming from, but it is probably not transmission
related.
And that it will take a lot of work just to pinpoint it.
Oh, well, I guess I'll just have to live with it...
I'm just wondering what part could make such a noise only when hot and
why?
Old 07-01-2005, 09:37 PM   #14 (permalink)
SnoMan
Guest
Posts: n/a
>Haven’t found the noise source yet.
>I’ve been at several shops and have been told that they
>don’t know
>related.
>Oh, well, I guess I’ll just have to live with it...
>I’m just wondering what part could make such a noise only when
>hot and
>why?[/color]
If it is a whine that gets worse with tempature you are looking at the
power steering pump or tranny front pump. They both can make noise for
quite some time before they fail. A tranny pump noise is hard to
locate in a FWD car because everything is together in one package more
or less.
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=619197[/url]
Old 07-01-2005, 10:26 PM   #15 (permalink)
Ray O
Guest
Posts: n/a
news:1120218181.579532.276170@f14g2000cwb.googlegroups.com...[color=blue]
> related.
> why?
>[/color]
There were numerous posts offering numerous suggestions. Some possibilities
are power steering pump, alternator, AC compressor, water pump, pulley, and,
depending on the model, hydraulic cooling fan.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
