dashboard light on 2001 corolla LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2005, 05:51 PM   #1 (permalink)
michael conner
Guest
Posts: n/a
View michael  conner's Photo Gallery
Hi all --
the lights on the dashboard (specifically the ones that light up the
speedometer) of my wife's 2001 corolla LE have gone out. whatever
lights up the "door ajar" and "low gas" indicators works. the dimmer
control to the left of the steering column has no effect.
doesn't seem to be a fuse issue, because the fuse that controls that
also controls other things that are working fine. (i think that's the
one, at least, the manual isn't very specific, it just says "meters and
gauges")
does it sound like there's a bulb that needs to be changed?
thanks in advance!
Old 06-20-2005, 06:00 PM   #2 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
Re: dashboard light on 2001 corolla LE
On Mon, 20 Jun 2005 15:51:21 -0700, michael conner wrote:
[color=blue]
> Hi all --
> gauges")
> thanks in advance![/color]
If you have NO lights at all, you have a bigger problem than a bulb.
CHECK the fuses, either by eye or buy a fuse tester; they give then to you
with fuse kits. Does ANYTHING light up at all?
Either you have a blown fuse or you have a loose connection under the
dash. It's kind of a PITA; you have to get upside down under the dash on
the driver's side and locate the connectors. Alternately you could pull
the instrument cluster, but this is almost as much of a pain (at least
you're upright...).
Check the fuses thouroughly and call me back...
Old 07-07-2005, 10:37 PM   #3 (permalink)
royroy
Guest
Posts: n/a
View royroy's Photo Gallery
"" wrote:[color=blue]
> Hi all --
> up the
> whatever
> dimmer
> controls that
> that's the
> "meters and
> gauges")
I have a 99 corrolla and have had the exact same problem! I have
checked all the fuses and they are fine...
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-dashboard-light-2001-corolla-LE-ftopict125453.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=623985[/url]
Old 07-08-2005, 12:15 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"royroy" <UseLinkToEmail@AutoForumz.com> wrote in message
news:1_623985_e52cd60b9f546feb4623d6975ecc0986@autoforumz.com...[color=blue]
> "" wrote:[color=green]
> > Hi all --
> > up the
> > whatever
> > dimmer
> > controls that
> > that's the
> > "meters and
> > gauges")
>[/color]
One or more bulbs need to be changed.
Ray O
correct the return address punctuation to reply
BB code is Off
Smilies are Off
[IMG] code is Off
