O2 Sensor before or after the Catalyst - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2005, 11:54 AM   #1 (permalink)
vwu@anacomp.com
Guest
Posts: n/a
View vwu@anacomp.com's Photo Gallery
Hi all,
I have a 1997 Toyota Corolla, my Engine Check light is on and the ODBII
gave the following diagnostic report:
Scan Data:
MIL Status ON
DTC Count O2
Readiness Complete Y
Freeze Data Exists Y
Operational Data:
Readiness Monitors
Complete Yes 01
Fuel System 1
Open Loop 02
Fuel System 2
Not Supported 03
Load Value
27.8% & 27.4% 04
Freeze Frame Data:
P0133 O2 Sensor
Circuit Slow
Response (Bank 1 Sensor 1)
Fuel System 1
Closed Loop 01
Fuel System 2
Not Supported 02
Load Value
28.2 % 03
Coolant Temp
185 F 04
Trouble Codes:
1.- Trouble Codes
P0130 O2 Sensor
Circuit Malfunction (Bank 1 Sensor 1)
P0130 O2 Sensor
Circuit Slow
2.- Pending Codes
No Trouble Codes Found
O2 Sensor Tests:
1.- O2 Sensor 1
Low Volt Switch Time
0.400v 01
High Volt Switch Time
0.550v 02
Min Sensor Volt
1.275v 03
Max Sensor Volt
0.000v 04
2.- O2 Sensor 2
Min Sensor Volt
1.275v 01
Max Sensor Volt
0.000v 02
Can anybody tell me which Oxygen sensor (before or after the catalyst)
is having a problem?
Thank you,
Vance
Old 06-21-2005, 01:25 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: O2 Sensor before or after the Catalyst
<vwu@anacomp.com> wrote in message
news:1119372844.557893.158790@o13g2000cwo.googlegroups.com...[color=blue]
> Hi all,
> Scan Data:
> MIL Status ON
> DTC Count O2
> Operational Data:
> Readiness Monitors
> Complete Yes 01
> Fuel System 1
> Open Loop 02
> Fuel System 2
> Not Supported 03
> Load Value
> 27.8% & 27.4% 04
> Freeze Frame Data:
> P0133 O2 Sensor
> Circuit Slow
> Fuel System 1
> Closed Loop 01
> Fuel System 2
> Not Supported 02
> Load Value
> 28.2 % 03
> Coolant Temp
> 185 F 04
> Trouble Codes:
> 1.- Trouble Codes
> P0130 O2 Sensor
> P0130 O2 Sensor
> Circuit Slow
> 2.- Pending Codes
> O2 Sensor Tests:
> 1.- O2 Sensor 1
> 0.400v 01
> 0.550v 02
> Min Sensor Volt
> 1.275v 03
> Max Sensor Volt
> 0.000v 04
> 2.- O2 Sensor 2
> Min Sensor Volt
> 1.275v 01
> Max Sensor Volt
> 0.000v 02
> Thank you,
> Vance
>[/color]
According to the trouble codes, it is the circuit for the O2 sensor before
the catalyst.
Ray O
correct the return address punctuation to reply
Old 06-21-2005, 02:51 PM   #3 (permalink)
vwu@anacomp.com
Guest
Posts: n/a
Ray,
Thank you for your response, do you mean the following trouble codes:
1.- Trouble Codes
P0130 O2 Sensor
P0130 O2 Sensor
Circuit Slow
Is the O2 sensor located before the catalyst, how do I interpret the
above trouble code is the one before the catalyst, not the one after
the catalyst?
Thank you,
Vance
Old 06-21-2005, 05:54 PM   #4 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
On Tue, 21 Jun 2005 12:51:29 -0700, vwu wrote:
[color=blue]
> Ray,
> 1.- Trouble Codes
> P0130 O2 Sensor
> P0130 O2 Sensor
> Circuit Slow
> the catalyst?
> Thank you,
> Vance[/color]
Here:
Old 06-21-2005, 07:33 PM   #5 (permalink)
Da Ghost
Guest
Posts: n/a
View Da Ghost's Photo Gallery
I have a 97 Avalon and the bank 1 sensor 1 on my car was located after the
Cat Conv.
Old 06-22-2005, 12:37 AM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:1119383489.185092.53750@g44g2000cwa.googlegroups.com...[color=blue]
> Ray,
> 1.- Trouble Codes
> P0130 O2 Sensor
> P0130 O2 Sensor
> Circuit Slow
> the catalyst?
> Thank you,
> Vance
>[/color]
Bank 1 refers to the cylinder bank that contains cylinder #1 - in the case
of a 4 cylinder engine, there is no bank 2.
Sensor 1 refers to the sensor that is closest to the engine.
Ray O
Old 06-22-2005, 12:39 AM   #7 (permalink)
Ray O
Guest
Posts: n/a
"Da Ghost" <cham2@cox.net> wrote in message
news:Wl2ue.65242$gc6.18473@okepread04...[color=blue]
>Cat Conv.
>[/color]
I also have a 97 Avalon and according to the Factory Service Manual, Page EG
259 (PO130), Sensor 1 refers to the sensor closest to the engine.
Ray O
Old 06-22-2005, 02:09 AM   #8 (permalink)
vwu@anacomp.com
Guest
Posts: n/a
Thanks to all input's and now I know for sure to order the right O2
sensor.
Thanks again,
Vance
Ray O wrote:[color=blue]
> news:1119383489.185092.53750@g44g2000cwa.googlegroups.com...[color=green]
> > Ray,
> > 1.- Trouble Codes
> > P0130 O2 Sensor
> > P0130 O2 Sensor
> > Circuit Slow
> > the catalyst?
> > Thank you,
> > Vance
> >[/color]
> Ray O
> correct the return address punctuation to reply[/color]
Old 06-22-2005, 06:53 PM   #9 (permalink)
hachiroku
Guest
Posts: n/a
On Wed, 22 Jun 2005 00:37:25 -0500, Ray O wrote:
[color=blue]
>> Ray,
>> 1.- Trouble Codes
>> P0130 O2 Sensor
>> P0130 O2 Sensor
>> Circuit Slow
>> the catalyst?
>> Thank you,
>> Vance
>>[/color]
> Sensor 1 refers to the sensor that is closest to the engine.[/color]
Told Ya So...
BB code is Off
Smilies are Off
[IMG] code is Off
