Re: automatic transmission
On Wed, 22 Jun 2005 02:48:55 +0000, noneyabusiness wrote:
[color=blue]
> On Tue, 21 Jun 2005 18:54:53 -0400, "chasmeup" <irish_eagle@yahoo.com>
> wrote:
>[color=green]
>>I AM CONSIDERING BUYING A 1990 TOYOTA TERCEL FOUR WHEEL DRIVE AUTOMATIC,
>>THE GIRL THAT IS SELLING IT SAID THAT IT DROVE JUST FINE UNTIL SHE LET A
>>GUY TEST DRIVE IT AND THEN HE SAID IT WASN'T GOING INTO THIRD GEAR..SO SHE
>>DROVE IT BUT DIDN'T UNDERSTAND THE SHIFTING SEQUENCE..I DROVE IT AND ALSO
>>COULDN'T FEEL ANY CHANGE LIKE IT WASN'T GOING INTO THIRD GEAR...BUT LET'S
>>SAY IT'S NOT CATCHING THIRD GEAR, WOULD THIS BE A MAJOR PROBLEM OR MAYBE
>>SOMETHING SIMPLE, I HAVE BEEN TOLD THAT THIS WOULD BE A VERY RARE PROBLEM
>>IN THIS TYPE OF CAR..THANX IN ADVANCE FOR ANY ADVICE.[/color]
> Try manually shifting through the gears and see if it "catches" 3rd.
> BTW, how many miles does the car have on it?
> Is the trans fluid in good condition?
> In my recent experience with pricing the cost of fixing an 85 3spd OD
> trans for my pickup I found it might cost anywhere from $600 to $1800
> to "fix", so if anything is actually wrong with the Tercel's tranny
> you're probably in the same cost range.
> (Shout all you like...There's a lot of noise in this group!)
> <g>[/color]
Yeah, I think I might actually agree with you on this one! ;)
As far as the tranny, did anyone actually CHECK the fluid level? It may
have just leaked out (or the guy took it '4 wheelin' and hit a rock hard
or something) And generally, a Toyota AT will default to 3rd gear in case
of a problem; it will start out in 3rd and stay there. Can it be shifted
manually (as noneya suggested)?
As an aside, lookf for one with a 6-speed (5 speed with an EL that can be
accessed in 4WD) A LOT more fun!
