95 camry shuts off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2005, 05:05 PM   #1 (permalink)
ed g via CarKB.com
Guest
Posts: n/a
View ed g via CarKB.com's Photo Gallery
95 camry shuts off
Whats up fellow car junkies ! need help -after idling my 95 camry 4cyl
shuts off, gives me a tough time restarting and keeps shutting off. replaced
fuel filter..... but smell fuel when trying to restart, which would lead me
to believe the pump is fine. car has 240k miles on it. My buddy told me it
might be the map sensor...
Message posted via CarKB.com
[url]http://www.carkb.com/Uwe/Forums.aspx/toyota/200506/1[/url]
Old 06-22-2005, 05:24 PM   #2 (permalink)
bobb
Guest
Posts: n/a
View bobb's Photo Gallery
Re: 95 camry shuts off
On Wed, 22 Jun 2005 22:05:33 GMT, "ed g via CarKB.com"
<forum@nospam.CarKB.com> wrote:
[color=blue]
>might be the map sensor...[/color]
if not gas, then bad ignition. When was last time u changed plugs,
rotor, wires?
Old 06-23-2005, 09:09 AM   #3 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
check the ignition coil
run the resistance tests in the haynes manual with the coil warm,
or warm it up with a hair dryer and tap it gently while testing
Old 06-24-2005, 07:41 PM   #4 (permalink)
toyotawiz
Guest
Posts: n/a
View toyotawiz's Photo Gallery
Re: Re: 95 camry shuts off
sounds like the egr valve is sticking. this is a common problem on these
camrys. But egr problems usually occur after long steady cruising. It
could also be the idle speed control. But before guessing at any of these
try cleaning the throttle body. good luck!
BB code is Off
Smilies are Off
[IMG] code is Off
