Just wondering if anyone had any suggestions for a problem I'm having
with my 1990 Toyota Sera.
A few days ago whilst driving along in the nice sunshine, the fan
blowing outside air decided to stop. I'm pretty sure it stopped and
started before finally giving up the ghost.
I've taken the fan out and put a current accross it and it spins round
fine.
I've checked all the fuses (the writing is in Japanese so no idea which
is which) but they all look fine.
When you turn the switch on & off you can hear the relay clicking.
There was a relay for the A/C under the bonnet that was exactly the
same as the fan one, so I swapped them over and still no joy.
Now here's the curious thing, the A/C light on the dashboard switch
used to come on. It wouldnt blow out cold air as it needs re-gasing but
the light would still come on. Since the blower stopped the light
doesnt come on any more.
Has anyone had any similar problem (with any car)? If so did you manage
to fix it?
Right, the AC is wired to the blower, bad blower, no AC.
If this is like any Toyota, there is a resistor, right on the blower,
which is the first thing that fails. Take out this item and u will see
that it's now open. Replace.
"steggy" <steven.clark4@ntlworld.com> wrote in message
news:1119628724.599309.202040@g14g2000cwa.googlegroups.com...[color=blue]
> Hi folks,
> fine.
> to fix it?
> Thanks for your help
> Steggy[/color]
As some else suggested, check the blower resistor pack. As far as the
reason the A/C light does not come on, the A/C switch must be engaged and
the blower must be working for the A/C to work.
Ray O
correct the return address punctuation to reply[color=blue]
>[/color]
news:1119969896.677684.178740@o13g2000cwo.googlegroups.com...[color=blue]
> Anyone have any idea where the resistor pack might be located? And will
> I need to take off the whole dashboard to get at it?
> Thanks for your help guys
>[/color]
The fan resistor pack is usually located in or near the fan housing under
the passenger side of the dash.
Ray O
On Tue, 28 Jun 2005 08:02:15 -0700, steggy wrote:
[color=blue]
> Thanks for your help guys[/color]
Man I read your original post, but overlooked the model name. You have one
of those??!!
Send it to me and I will fix it for you! (just don't be TOO surprised when
you get an '83 Tercel 4WD wagon back in return...)
Can you expound a little on what it has? It kind of looks like a Paseo
(use Google to look up the cars; I know the Tercel was called something
else elsewhere, and I THINK the Paseo was called the Cynos elsewhere? Hey,
I was actually correct!)
If it was built like other Toyotas of the period, the blower motor will
NOT be a joy to remove! It will be located on the passenger's side, up
under the bottom of the dash. There is JUST (barely) enough room to remove
it without ripping out the dash,m which actually may be easier! Three
bolts secure it to it's housing, the third one is always a bitch! Once you
get the bolts out, you have to slide the blower motor and 'squirrel cage'
out. The resistor pack will probably be inside, next to the squirrel cage.
It will look like three springs on a piece of circuit card. You can get
one from your Toyota dealer, or go junkyard diving and get the whole
assembly for less (look for a low mileage car, they tend to go about
100,000 miles. You may also find that one from a Tercel or Cynos/Paseo
fits, too.)
Good luck! I hope you're a patient person!
Oh, BTW, on a very very few models (like my 1985 Celica) the resistor pack
is located at the fan switch itself, but this is VERY rare.
If you want more info on the Sera I tend to look at
[url]http://www.toyotasera.co.uk[/url] you should be able to find all the
information you want.
[color=blue]
>From what I've read the Sera was only made in Japan, and the was only[/color]
16,000 made in total.
The other day I did manage to get the blower motor out to see if it was
that, that didnt work. But it was working fine so I put it back, looks
like I'll have to try and wrestle it out again and see what I can find.
On Wed, 29 Jun 2005 07:26:02 -0700, steggy wrote:
[color=blue]
> Fixed :-D
> There was a circuit breaker right next to the relay, well it said
> "breaker" on it. Couldnt managed to open it up and push it back down
> and it worked.
> Thanks for your help again guys.
> Steg[/color]
Does this mean you WON'T be sending the car my way? :(
On Wed, 29 Jun 2005 01:26:32 -0700, steggy wrote:
[color=blue]
> information you want.[/color]
Engine Code 5E-FHE
Engine type transverse inline 4 cylinder, DOHC, 16v, cast iron block,
alloy cylinder head, belt driven, with geared camshafts.
Peak power 108bhp @ 6400 rpm
Peak torque 97 lb ft @ 5200 rpm
AHA! Basically a Tercel/Paseo/Cynos! What I thought.
I would try to shove a 4A-GE in there (128-160HP) just for kicks!
[color=blue]
>[color=green]
> Thanks for your help.
> Steg[/color]
