Proactive Maintenance of a 98 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2005, 11:12 PM   #1 (permalink)
Ajanta
Guest
Posts: n/a
View Ajanta's Photo Gallery
My previous car was a used 92 Camry. Other than check air, change oil,
and change muffler when it became noisy, I did not do any proactive
maintenance. As a result a few things failed on me at most inconvenient
moments: radiator, water pump (which required changing timing belt
too), battery. As I often found myself in emergency sits, I wasn't
always able to plan where work should be done, I had to take what I
could get.
I just bought a 98 Camry with 80K miles on it. It is in great shape and
I want to keep it for at least five years, maybe until 150K. I want to
avoid my previous mistake and be proactive about maintenance, but also
not throw away any good parts that would last until 150K.
The previous owner just got a new battery. Tires are Regata 2 with 35K
miles. Because of a flat I have had them evaluated repeatedly and they
seem good for 1-2 years.
How should I approach the maintenance of this car? What should be
done and when?
Secondly, where should such work be done? I am so happy to be able tp
plan that, instead of being limited by who is near and who is open
during a holiday weekend!
Are big national chains like Sears, Pep Boys, WalMart etc any good?
CarX, Midas, Firestone? (Recommendations for places local to Chicago
are also welcome.)
I stopped at a local garage in an area where I had to kill time today.
He suggested (1) changing belts (incl timing) and (2) getting a
tune-up, even if nothing seems wrong. Is that good advice?
He was unsure about water pump: it would be $80 if done with timing
belt but a lot more if it had to be done on its own, but nothing is
wrong and it could possibly last.
Anyway, dear experts, I would be most grateful for your guidance on how
to keep this car perfectly maintained. :-)
Old 06-25-2005, 12:24 AM   #2 (permalink)
bobb
Guest
Posts: n/a
View bobb's Photo Gallery
Re: Proactive Maintenance of a 98 Camry
If still has original timing belt, change it. Then u don't have to
worry about it anymore for the remaining life of the car.
The problem with regular maintenance is, it's good only if u know what
to change, or u have a MX u can trust, or it's still under warranty.
Unknown MX tend to want to do the big jobs$ and are not willing to do
the little, bring in nothing jobs.
Old 06-25-2005, 12:54 AM   #3 (permalink)
Ajanta
Guest
Posts: n/a
Steve B. <none@none.com> wrote:
: Replacing the water pump with the timing belt on these cars is
: a very good idea as you have to remove it to get to the belt anyway
: and when it fails in the future (not if) it can take out the brand new
: belt. Gates web site shows your belt needing to be changed at 90k
: miles.
I think the cost benefit analysis is quite clear: If I don't change the
water pump and it doesn't break while I own my car, I save $100
approx; if it breaks, I lose at least $250 (one timing belt job, which
may have to be repeated anyway), and maybe more if there is other
serious damage.
So I guess I will do them both. However, the car has only 80K miles,
I think I can wait 1-2 years, or at least I spot some great sale
somewhere on this job. :-)
Thank you for the rest of your most helpful advice as well.
: Consider getting a AAA membership if you don't have one already.
Thanks. I have been wondering which national club would offer
the best value and was thinking of asking that question in another
thread.
Old 06-25-2005, 02:04 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Steve B." <none@none.com> wrote in message
news:eiopb1pd7g4sbnjrm4r2ah63v6mffqidr1@4ax.com...[color=blue]
> On Sat, 25 Jun 2005 04:12:28 GMT, Ajanta <ajanta@null.void> wrote:
>[color=green]
>>done and when?[/color]
> Look in your owners manual and follow the severe service maintenance
> schedule. If there are things you are behind on or don't know to have
> been completed then go ahead and catch them up.[/color]
Great advice!
[color=blue][color=green]
>>are also welcome.)[/color]
> I avoid the above mentioned places at all costs. Some of them can be
> good but most are not and you never know which kind you are getting.
> Ask friends and co-workers for reccomendations on an independant shop
> that is reliable and in your area.[color=green]
>>[/color][/color]
Also great advice!
>>wrong and it could possibly last.[/color]
> The fact that he was unsure about the water pump is a little troubling
> to me. Replacing the water pump with the timing belt on these cars is
> miles.
> When a timing belt breaks on your engine the valves can hit the
> pistons. When this happens either the valves or the piston breaks....
> either way it will cost you a small fortune so don't mess around with
> it. Check out
> [url]http://www.gates.com/brochure.cfm?brochure=2256&location_id=3487[/url]
> for a pretty good explanation and a couple of illustrations that show
> what happens.
>[/color]
On a Camry, the valves will not hit the pistons if the timing belt breaks
but the car will leave you stranded.
I recommend changing the timing belt at 90,000 miles and if you can afford a
little extra to change thw wter pump as a prevantative measure, then I'd do
it when the timing belt is changed because much of the work to change a
water pump is removing the timing belt.
Although changing a timing belt is not that difficult, Toyota dealers have
it down to a science and often have sales on timing belt replacements. I
recommend that you have the timing belt changed by a dealer.
Ray O
correct the return address punctuation to reply
Old 06-25-2005, 07:44 AM   #5 (permalink)
Guest
Posts: n/a
View 's Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote in message
news:4a265$42bd0203$180fead6$30737@msgid.meganewsservers.com...[color=blue]
> news:eiopb1pd7g4sbnjrm4r2ah63v6mffqidr1@4ax.com...[color=green]
> >[color=darkred]
> Great advice!
>[color=green][color=darkred]
> > that is reliable and in your area.[color=darkred]
> >>[/color][/color]
> Also great advice!
> > miles.
> > it. Check out
> > what happens.
> >[/color]
> I recommend changing the timing belt at 90,000 miles and if you can afford[/color]
a[color=blue]
> little extra to change thw wter pump as a prevantative measure, then I'd[/color]
do[color=blue]
> recommend that you have the timing belt changed by a dealer.[/color]
The Gates book shows the V6 to be interference, I believe, while the L4 is
not, if I read it correctly.
I would pick my mechanical service carefully. Some dealerships are crappy,
others may be pretty good. A blanket recommendation to take your car to a
dealership garage is not the best advice,
in my opinion.
Old 06-25-2005, 01:43 PM   #6 (permalink)
do_not_spam_me@my-deja.com
Guest
Posts: n/a
View do_not_spam_me@my-deja.com's Photo Gallery
Ajanta wrote:
[color=blue]
> I just bought a 98 Camry with 80K miles on it.[/color]
[color=blue]
> etc any good? CarX, Midas, Firestone? (Recommendations
> for places local to Chicago are also welcome.)[/color]
See [url]www.toyotanation.com[/url] forums for a great deal of information about
Toyotas.
A survey several years ago by Consumer Reports found CarX to be better
than the other chains, but I wouldn't take a car to any chain garage
except for very simple work where no diagnosis was needed. They're
especially bad for fuel system diagnoses, where they don't know how to
do anything but read the OBD II codes and try to fix almost every
problem with a tune-up or fuel injection flush. It's better to use a
dealer or a good independent garage very familiar with your type of car
(and where all the mechanics have gone to the factory school for your
particular vehicle model), and AAA approval is desirable since it
obligates the garage to AAA arbitration, whether or not the customer is
a member.
[color=blue]
> tune-up, even if nothing seems wrong. Is that good advice?[/color]
Considering the mileage, that's probably appropriate. But in general,
be skeptical of any garage pushes tune-ups or fuel injector flushing,
the latter actually being harmful and contraindicated by manufacturers.
If the water pump runs off the timing belt, change it along with the
timing belt.
Flush the brake fluid every 2 years as it absorbs moisture from the
air. If you flush the brakes yourself, do not pump the pedal down any
farther than it usually travels because any farther will cause the
master cylinder to be ruined, and ABS usually requires special
procedures.
Have the transmission drained and refilled, but don't allow it to be
flushed with a special machine. I believe Toyotas have a drain plug in
the transmission pan, so this is as simple as an engine oil change.
Use ordinary fluid recommended by the manufacturer, not a special
synthetic. I don't know if you can use ordinary Dexron III/Mercon in a
1998 Camry or need Toyota T-4 fluid, but don't use the wrong type.
Use only Toyota antifreeze. Don't assume that other red or pink
antifreeze is similar since the color is from dye, not from the active
ingredients, and there is no industry-wide standard to classify
antifreeze type by color (i.e., Toyota red and GM red are much more
different than Toyota red and ordinary green).
Don't assume that most service advisors know much about cars. They're
primarily salesmen and often recommend far more maintenance than
required by the auto manufacturer or will specify outright wrong
repairs when they should instead merely describe the symptoms.
Toyota forums, such as [url]www.toyotanation.com[/url], and general auto repair
FAQs, such as at [url]www.popularmechanics.com[/url] are useful. MOTOR magazine
back issues, at [url]www.motor.com[/url], are very good about details you can't
find elsewhere. And Toyota factory manual is not only very complete
but also unusually easy to understand
Old 06-25-2005, 05:06 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
<HLS@nospam.nix> wrote in message
news:lkcve.2177$W74.1241@newssvr30.news.prodigy.com...[color=blue]
> news:4a265$42bd0203$180fead6$30737@msgid.meganewsservers.com...[color=green]
>> news:eiopb1pd7g4sbnjrm4r2ah63v6mffqidr1@4ax.com...[color=darkred]
>> >>done and when?
>> Great advice!
>>[color=darkred]
>> >>are also welcome.)
>> >>[/color]
>> Also great advice!
>>[color=darkred]
>> > miles.
>> > it. Check out
>> > what happens.
>> >[/color]
>> afford[/color]
> a[color=green]
> do[color=green]
>> have
> not, if I read it correctly.[/color]
I stand corrected! By the way, a timing belt that is getting ready to fail
will start to make a slapping noise so they generally give warning before
they fail. If you change it every 90,000 miles, then no worries.[color=blue]
> I would pick my mechanical service carefully.[/color]
I agree - see my earlier responses.
Some dealerships are crappy,[color=blue]
> in my opinion.
>[/color]
Dealerships must meet special service tool, training, equipment, and
facility requirements. They also receive a full set of factory service
manuals and new special service tools every year as well as receive every
technical service bulletin as soon as they are issued. Dealership service
departments are rated by consumers and regularly receive customer
satisfaction scores.
Independent service facilities generally do not have every special service
tool for Toyotas, do not have factory service manuals, do not have factory
trained technicians, and do not receive service bulletins as quickly as
dealers do. In fact, many do not receive service bulletins unless they do a
specific search for one.
I have no problem with most independents for simple work like oil changes,
brakes, suspension, etc. but beyond that, their knowledge and experience
tends to be generic where Toyota technicians have more specific knowledge
and experience. My recommendation was not a blanket one to take the car to
a dealership; it was for a timing belt replacement.
Ray O
Old 06-25-2005, 05:35 PM   #8 (permalink)
S.S.
Guest
Posts: n/a
View S.S.'s Photo Gallery
> I stand corrected![/color]
Actually, I believe you were initially right, and that he might have read it
incorrectly. I have a Gates document from 2001, and it says that this Camry
V6 is non-interference, like all belt-driven Toyota engines. I don't
remember if the OP mentioned what engine the car has, but both '98 Camry
engines are belt-driven non-interference engines.
[color=blue]
> they fail.[/color]
Is this true? I thought timing belts would give out with no warning at all.
Old 06-25-2005, 06:08 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
"S.S." <me@privacy.net> wrote in message
news:k2jf9q2cc32w$.dlg@ss.me-privacy-net.com...[color=blue]
>>> is
> it
> Camry
>[/color]
I believe the IMZFE engine is interference type although for many years,
Toyotas with timinb belts were non-interference.
[color=blue]
>[color=green]
>> they fail.[/color]
> all.[/color]
A timing belt can give without warning but they generally start making noise
before they do.
Ray O
Old 06-25-2005, 10:42 PM   #10 (permalink)
Guest
Posts: n/a
news:23ad4$42bdd745$180fead6$16674@msgid.meganewsservers.com...[color=blue]
> news:lkcve.2177$W74.1241@newssvr30.news.prodigy.com...[color=green]
> > news:4a265$42bd0203$180fead6$30737@msgid.meganewsservers.com...[color=darkred]
> >> >>done and when?
> >> > schedule. If there are things you are behind on or don't know to[/color][/color][/color]
have[color=blue][color=green][color=darkred]
> >> Great advice!
> >> >>are also welcome.)
> >> Also great advice!
> >> >>I stopped at a local garage in an area where I had to kill time[/color][/color][/color]
today.[color=blue][color=green][color=darkred]
> >> > The fact that he was unsure about the water pump is a little[/color][/color][/color]
troubling[color=blue][color=green][color=darkred]
> >> > to me. Replacing the water pump with the timing belt on these cars[/color][/color][/color]
is[color=blue][color=green][color=darkred]
> >> > and when it fails in the future (not if) it can take out the brand[/color][/color][/color]
new[color=blue][color=green][color=darkred]
> >> > miles.
> >> > pistons. When this happens either the valves or the piston[/color][/color][/color]
breaks....[color=blue][color=green][color=darkred]
> >> > it. Check out
> >> > what happens.
> >> On a Camry, the valves will not hit the pistons if the timing belt[/color][/color][/color]
breaks[color=blue][color=green][color=darkred]
> >> afford[/color]
> > a[color=darkred]
> >> little extra to change thw wter pump as a prevantative measure, then[/color][/color][/color]
I'd[color=blue][color=green]
> > do[color=darkred]
> >> have
> >> it down to a science and often have sales on timing belt replacements.[/color][/color][/color]
I[color=blue][color=green][color=darkred]
> > The Gates book shows the V6 to be interference, I believe, while the L4[/color][/color]
> I stand corrected! By the way, a timing belt that is getting ready to[/color]
fail[color=blue]
> they fail. If you change it every 90,000 miles, then no worries.[color=green]
> Some dealerships are crappy,[color=green]
> > others may be pretty good. A blanket recommendation to take your car to[/color][/color]
a[color=blue][color=green]
> > in my opinion.
> >[/color]
> satisfaction scores.[/color]
Some dealers are good, some are crap, as I said before.
[color=blue]
> and experience. My recommendation was not a blanket one to take the car[/color]
to[color=blue]
> --[/color]
" I recommend that you have the timing belt changed by a dealer."
You dont have to take it to a dealer. You want to take your car to a good
and competent
mechanic, wherever he may be. Dealers dont always provide this quality.
They SHOULD,
at the prices they charge, provide experts but unfortunately this just isnt
always the case.
Old 06-25-2005, 11:31 PM   #11 (permalink)
DTJ
Guest
Posts: n/a
View DTJ's Photo Gallery
On Sat, 25 Jun 2005 05:54:07 GMT, Ajanta <ajanta@null.void> wrote:
[color=blue]
>: miles.
>serious damage.[/color]
Where are you getting those prices? An accord costs almost $1000 to
have the timing belt and water pump done. I would assume a Toyota is
similar.
However, I have had 3 Hondas with more than 130,000 miles, none of
which showed any indication of failure for going past the 90,000 mile
mark where it should have been replaced. I am almost convinced that
timing belt replacement is, as CH says, snake oil. Besides, the quote
to do the work before and after a failure is not that different.
Old 06-25-2005, 11:49 PM   #12 (permalink)
Kiran
Guest
Posts: n/a
View Kiran's Photo Gallery
DTJ <none@nowhere.com> wrote:
: Where are you getting those prices? An accord costs almost $1000 to
: have the timing belt and water pump done. I would assume a Toyota is
: similar.
I have no experience with Hondas, but 1000 seems too much for a Camry.
For timing belt alone I have seen *dealer* ads around 200 (granted
those are promotions).
: However, I have had 3 Hondas with more than 130,000 miles, none of
: which showed any indication of failure for going past the 90,000 mile
: mark where it should have been replaced. I am almost convinced that
: timing belt replacement is, as CH says, snake oil. Besides, the quote
: to do the work before and after a failure is not that different.
There are two arguments against this. First, even if not much more
expensive, it will be much more inconvenient if done in an emergency.
If it breaks on the road, you would miss whatever you were driving to,
and could also be far away from any Toyota dealer or even a decent
garage.
Second, I know that if they say 90,000 it is not going to break at
91,000. If I want to sell my car at 100,000 or even 110,000 I might
chance it. But what if I plan to keep it until 150,000 as OP said? Or
even longer. After a point, I won't have piece of mind. And if I change
it later, I'd be spending the money anyway.
BTW on my Camry I changed it at 120,000 but I did change it, because of
accululating anxiety. I drive alone, or with kids, during nights,
through less populated areas, etc. I could have changed it earlier for
much less anxiety and no more money.
Old 06-26-2005, 12:25 AM   #13 (permalink)
Ray O
Guest
Posts: n/a
news:xupve.2911$Lj2.1866@newssvr12.news.prodigy.com...[color=blue]
> news:23ad4$42bdd745$180fead6$16674@msgid.meganewsservers.com...[color=green]
>> news:lkcve.2177$W74.1241@newssvr30.news.prodigy.com...[color=darkred]
>> >> >>done and when?
> have[color=green][color=darkred]
>> >> Great advice!
>> >> >>tp
>> >> >>are also welcome.)
>> >> > be
>> >> > shop
>> >> Also great advice!
> today.[color=green][color=darkred]
> troubling[color=green][color=darkred]
> is[color=green][color=darkred]
> new[color=green][color=darkred]
>> >> > miles.
> breaks....[color=green][color=darkred]
>> >> > with
>> >> > it. Check out
>> >> > show
>> >> > what happens.
> breaks[color=green][color=darkred]
>> >> afford
>> > a
> I'd[color=green][color=darkred]
>> > do
>> >> a
>> >> have
> I[color=green][color=darkred]
> fail[color=green]
>> they fail. If you change it every 90,000 miles, then no worries.[color=darkred]
>> Some dealerships are crappy,[color=darkred]
>> > to[/color][/color]
> a[color=green][color=darkred]
>> > in my opinion.
>> >[/color]
>> service
> Some dealers are good, some are crap, as I said before.[/color]
This is true, however, of the 100 or so dealerships I've personally dealt
with, I'd say 70% were technically good, another 25% were excellent, and the
remaining 5% were poor. The proportions of good, excellent, and poor
technicians who worked at the dealerships is probably about the same. Your
chances of getting good service on your Toyota at a Toyota dealer are at
least as good and probably better than your chances of getting that same
level of technical competence at an independent shop.
[color=blue]
>[color=green]
>> changes,
> to[color=green]
>> --[/color]
> and competent
> They SHOULD,
> isnt
> always the case.
>[/color]
I agree that dealers don't always provide the quality of the service that
they should, especially for the prices they charge BUT, like I said, given
an unfamiliar dealer and an unfamiliar independent shop, IMO, the dealer is
a much better bet. If you know a competent independent who charges less
than a dealership, uses quality parts, and stands behind his work, then he
may be worth going to. Our local Toyota dealer charges less than $200 for
a timing belt replacement where the independent wants closer to $300 because
it takes him longer.
Like I said, it is worth pricing the work before getting it done.
Ray O
Old 06-26-2005, 12:34 AM   #14 (permalink)
Ray O
Guest
Posts: n/a
"DTJ" <none@nowhere.com> wrote in message
news:tobsb110hnpa4pcq2ghmqqdln23gbiv85b@4ax.com...[color=blue]
>[color=green]
>>: miles.
> similar.
> to do the work before and after a failure is not that different.[/color]
Here in the Chicago suburbs, the local dealer charges around $200 for a
timing belt on a Camry and at $100 to $150 additional for a water pump.
Having to pay $1000 for a timing belt would make me think seriously about
getting another model!
On an interference engine, if the timing belt fails, the pistons can hit the
valves, causing extensive damage. People often find this hard to believe,
but the folks who make the cars probably know more about the car and the
cost benefits of performing periodic maintenance than most owners. Whether
the cost to replace the timing belt is $200 for a Camry or $1,000 for the
Accord, it is cheaper to change the timing belt before it breaks than
letting it break and having to tow for an unscheduled repair or worse, tear
down the engine for major repairs.
Ray O
Old 06-26-2005, 08:27 AM   #15 (permalink)
S.S.
Guest
Posts: n/a
DTJ wrote:
[color=blue]
> similar.
>[/color]
It should not cost $1000 to change the t-belt and water pump on an Accord.
I have a '93 Accord, and it cost only $350 to get it done at a private
mechanic who specializes in Hondas.
[color=blue]
I have heard of many instances of the belt failing past the interval, but
very few within the interval.
BB code is Off
Smilies are Off
[IMG] code is Off
