sienna check engine light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2005, 09:45 AM   #1 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
2000 Sienna 82500 miles.
Last night the Check Engine light came on while I was driving. There
was about a quarter tank of gas in the car. I filled it up and
tightened the gas cap well. Told my wife about the gas cap and she
said she didn't know to click it several times. I'm hoping that is the
problem.
The light has remained on for several On/Off cycles of the van. Google
searches tell me it will clear after so many cycles but I see different
answers about that. Tomorrow I will take it to Advance Auto and get a
free OBD II scan done to find out what it is.
What should I expect to discover and how should the light be reset to
see if it returns again?
No matter what happens someone will find a way to take it too seriously.
Old 06-25-2005, 10:32 AM   #2 (permalink)
Spam Catcher
Guest
Posts: n/a
View Spam Catcher's Photo Gallery
Re: sienna check engine light
They will tell you whats up. if it was just the gas cap it would have
gone off by now. dont just have them turn it off. take it to your
dealership!
Celica00GT
Old 06-25-2005, 05:10 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"badgolferman" <REMOVETHISbadgolferman@gmail.com> wrote in message
news:xn0e3wzaa6huddn000@news.readfreenews.net...[color=blue]
> problem.
>[/color]
Although a loose gas cap is the most common cause of a check engine light,
you may have some other cause.
Yes, the light should be reset to see if it come on again.
Ray O
correct the return address punctuation to reply
Old 06-25-2005, 06:44 PM   #4 (permalink)
badgolferman
Guest
Posts: n/a
Ray O, 6/25/2005, 6:10:21 PM, wrote:
[color=blue]
> news:xn0e3wzaa6huddn000@news.readfreenews.net...[color=green]
> > There was about a quarter tank of gas in the car. I filled it up
> > and tightened the gas cap well. Told my wife about the gas cap and
> > she said she didn't know to click it several times. I'm hoping
> > that is the problem.
> > Google searches tell me it will clear after so many cycles but I
> > see different answers about that. Tomorrow I will take it to
> > Advance Auto and get a free OBD II scan done to find out what it is.
> > to see if it returns again?
> >[/color]
> light, you may have some other cause.
> Yes, the light should be reset to see if it come on again.[/color]
I have had the code scanned. P0440 Evap Emission Control System. The
code has been erased to see if it returns. In five miles I haven't
seen it yet.
The Auto Zone mechanic says it might be a charcoal canister tube leak.
If this is true, where would I find this canister and what should I
look for? Any other thoughts? Thanks.
Old 06-25-2005, 10:32 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:xn0e3xdh77138pd000@news.readfreenews.net...[color=blue]
>[color=green]
>> news:xn0e3wzaa6huddn000@news.readfreenews.net...[color=darkred]
>> >[/color]
> seen it yet.
>[/color]
Good news - an Evaporative Emission Control System trouble code is usually
caused by a loose or missing gas cap. Evaporative emissions are the vapors
that escape from the fuel tank and are controlled with a charcoal canister.
The charcoal absorbs the vapors and are then drawn off to be burned in the
engine. The fuel system is sealed and as fuel is consumed, a slight vacuum
forms. If the charcoal canister develops a leak or the hoses that lead from
the fuel tank to the canister develop a leak, the vacuum does not form and a
check engine light comes on. Of course, if the gas cap is loose, left off,
or has a bad gasket, the vacuum won't form in the tank and the check engine
light comes on.
This trouble code will eventually clear itself on its own after the vehicle
has been operated a few times after the gas cap has been tightened or you
can clear it with the code scanner.
Be sure to tighten the gas cap until it clicks several times - these
instructions are probably printed on the gas cap but few people (including
me) read the gas cap.
Ray O
Old 06-26-2005, 06:43 AM   #6 (permalink)
badgolferman
Guest
Posts: n/a
Ray O, 6/25/2005, 11:32:37 PM, wrote:
[color=blue]
> news:xn0e3xdh77138pd000@news.readfreenews.net...[color=green]
> >[color=darkred]
> >> > and tightened the gas cap well. Told my wife about the gas cap[/color][/color]
> and >> > she said she didn't know to click it several times. I'm
> hoping >> > that is the problem.[color=green][color=darkred]
> >> > Advance Auto and get a free OBD II scan done to find out what it[/color][/color]
> is. >> >[color=green][color=darkred]
> >> > What should I expect to discover and how should the light be[/color][/color]
> reset >> > to see if it returns again?[color=green][color=darkred]
> > The code has been erased to see if it returns. In five miles I
> > haven't seen it yet.
> > leak. If this is true, where would I find this canister and what
> > should I look for? Any other thoughts? Thanks.
> >[/color]
> usually caused by a loose or missing gas cap. Evaporative emissions
> are the vapors that escape from the fuel tank and are controlled with
> a charcoal canister. The charcoal absorbs the vapors and are then
> drawn off to be burned in the engine. The fuel system is sealed and
> as fuel is consumed, a slight vacuum forms. If the charcoal canister
> develops a leak or the hoses that lead from the fuel tank to the
> canister develop a leak, the vacuum does not form and a check engine
> light comes on. Of course, if the gas cap is loose, left off, or has
> light comes on.
> vehicle has been operated a few times after the gas cap has been
> tightened or you can clear it with the code scanner.
> (including me) read the gas cap.[/color]
Thanks for your input, Ray. I am confident your diagnosis is correct.
Toyotas seem to be self-healing in most cases.
Old 06-27-2005, 12:33 PM   #7 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
IF the trouble was that the gas cap was not secured, then you should get
codes in the family of P0440.
> problem.
> No matter what happens someone will find a way to take it too seriously.[/color]
Old 06-27-2005, 12:36 PM   #8 (permalink)
Jeff Strickland
Guest
Posts: n/a
>[color=green]
> > >[/color]
> seen it yet.
>[/color]
P0440 is the code that you should see if the gas cap is not fitted securely.
The guys at AutoZone did you right, they reset the code and sent you on your
way.
Old 06-27-2005, 01:44 PM   #9 (permalink)
badgolferman
Guest
Posts: n/a
Jeff Strickland, 6/27/2005, 1:36:32 PM,
<T6-dnR8hbPBWpV3fRVn-ow@ez2.net> wrote:
[color=blue]
> >[color=darkred]
> > > > up and tightened the gas cap well. Told my wife about the gas
> > > > cap and she said she didn't know to click it several times.
> > > > I'm hoping that is the problem.
> > > > it is.
> > > > reset to see if it returns again?
> > > engine light, you may have some other cause.
> >[/color]
> securely.
> on your way.[/color]
Actually it was a girl holding the scanner...
No matter what happens, someone will find a way to take it too
seriously.
Old 06-28-2005, 03:01 PM   #10 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:xn0e3zypshagou002@news.readfreenews.net...[color=blue]
>[color=green]
> > securely.
>[/color]
Even better.
BB code is Off
Smilies are Off
[IMG] code is Off
