bumper Fix - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2005, 09:33 AM   #1 (permalink)
bobQ
Guest
Posts: n/a
View bobQ's Photo Gallery
bumper Fix
97 Avalon (Camry should be similar)
My daughter rear ended another car, similar weight. No visible damage and no
one hurt. (thankfully)
My expectation is that the front bumper shock mounts are crushed and need
replacing. Is that right?
QUESTION: how hard is this? I've done Rack and Pinion and Timing belt
repairs on this but have no experience with bumper mounts. Wife says they
hit em pretty hard. Under the hood I can see the battery slipped forward but
other than that, nothing looks wrong.
Is my assumption that the bumper uses crushable mounts that must be replaced
correct? Seems like the bumper may have pushed in and returned to the near
original position. Is there something I can measure? Any help is appreciated
Old 06-26-2005, 10:37 AM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: bumper Fix
On Sun, 26 Jun 2005 14:33:59 +0000, bobQ wrote:
[color=blue]
> original position. Is there something I can measure? Any help is appreciated[/color]
I would take it to a shop, even the dealer, and have it looked at. There
are a lot of things that can go wrong, even if it looks good.
As far as the crushable mounts, you are correct. They are something like
shock absorbers, although (for some unknown to me reason) they don't
bounce back. Common fix? Get a chain and find a strong tree, wrap the
chain around the tree and then attach to the bumper and yank them back out
again. You're on your own on this; BE CAREFUL you don't pull the bumper
right off the car!!!
Old 06-26-2005, 03:15 PM   #3 (permalink)
TeGGeR®
Guest
Posts: n/a
View TeGGeR®'s Photo Gallery
Re: bumper Fix
"bobQ" <eza9nt@verizon.net> wrote in news:r1zve.3962$4M1.2505@trnddc07:
[color=blue]
> and no one hurt. (thankfully)
> need replacing. Is that right?[/color]
Not these days. Most cars these days have an EPS ("Styrofoam") insert a
couple of inches thick between the bumper skin and the steel reinforcing
bar. It's glued to the back of the skin. The rebar is normally solidly
bolted to the body.
The old-style "crushable mounts" went out with exposed chromed-steel
bumpers.
[color=blue]
> they hit em pretty hard. Under the hood I can see the battery slipped
> forward but other than that, nothing looks wrong.
> replaced correct?[/color]
The foam crushes, yes. It normally breaks up, as well. You must buy a whole
new bumper skin, since you cannot buy the foam by itself. And then the new
skin will have to be painted and installed.
[color=blue]
> returned to the near original position. Is there something I can
>[/color]
If the damage is that hard to notice, just leave it alone. It ain't worth
worrying about.
TeGGeR®
Old 06-26-2005, 06:02 PM   #4 (permalink)
Josh
Guest
Posts: n/a
View Josh's Photo Gallery
Re: bumper Fix
"Hachiroku" <Trueno@ae86.gts> wrote in message
news:pan.2005.06.26.15.45.57.31000@ae86.gts...[color=blue]
>[color=green]
> > My daughter rear ended another car, similar weight. No visible damage[/color][/color]
and no[color=blue][color=green]
> > My expectation is that the front bumper shock mounts are crushed and[/color][/color]
need[color=blue][color=green]
> > repairs on this but have no experience with bumper mounts. Wife says[/color][/color]
they[color=blue][color=green]
> > hit em pretty hard. Under the hood I can see the battery slipped forward[/color][/color]
but[color=blue][color=green]
> > Is my assumption that the bumper uses crushable mounts that must be[/color][/color]
replaced[color=blue][color=green]
> > correct? Seems like the bumper may have pushed in and returned to the[/color][/color]
near[color=blue][color=green]
> > original position. Is there something I can measure? Any help is[/color][/color]
appreciated[color=blue]
> right off the car!!![/color]
Or a rotting tree down on your car =)
Old 06-26-2005, 07:24 PM   #5 (permalink)
hachiroku
Guest
Posts: n/a
View hachiroku's Photo Gallery
Re: bumper Fix
On Sun, 26 Jun 2005 19:02:00 -0400, Josh wrote:
[color=blue]
> news:pan.2005.06.26.15.45.57.31000@ae86.gts...[color=green]
>>[color=darkred]
> and no[color=green][color=darkred]
> need[color=green][color=darkred]
> they[color=green][color=darkred]
> but[color=green][color=darkred]
> replaced[color=green][color=darkred]
> near[color=green][color=darkred]
> appreciated[color=green]
> Or a rotting tree down on your car =)[/color]
Ya otta sell this one to Vonnage for one of their 'dumb' commercials!
Old 06-27-2005, 07:01 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: bumper Fix
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns9681A55933A20tegger@207.14.113.17...[color=blue]
>[color=green]
> bolted to the body.
> bumpers.
>[/color]
On the Avalon, the backing, foam and skin are separate parts. Look under
the bumper and you will see a bunch of bolts. Remove the bolts to remove
the skin and expose the foam.
[color=blue]
>[color=green]
> whole
>[color=green]
>>[/color]
> worrying about.
> TeGGeR®[/color]
Ray O
correct the return address punctuation to reply[color=blue]
>[/color]
Old 06-27-2005, 07:50 PM   #7 (permalink)
TeGGeR®
Guest
Posts: n/a
Re: bumper Fix
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote in
news:jPidnXC0DOEeCV3fRVn-uw@comcast.com:
[color=blue]
> news:Xns9681A55933A20tegger@207.14.113.17...[/color]
>> a couple of inches thick between the bumper skin and the steel
>> reinforcing bar. It's glued to the back of the skin. The rebar is
>> normally solidly bolted to the body.
>> bumpers.
>>[/color]
> under the bumper and you will see a bunch of bolts. Remove the bolts
> to remove the skin and expose the foam.[/color]
That's good to know. So the foam actually has a separate part number?
TeGGeR®
BB code is Off
Smilies are Off
[IMG] code is Off
